3 Replies Latest reply on Oct 5, 2011 5:54 AM by robdillon
    NEED SOME HELP
    gkesava
      Hi all
      i have problem with some flash files the problem is
      i have to do the some modifactions in the file and i have to do the same modifactions to the rest of the files. { in photoshop we have actions so we can create one and we can use same to all outher files} i need some thing like that
      thanks
      KV
        • 1. Re: NEED SOME HELP
          robdillon Most Valuable Participant
          Flash doesn't have anything like actions. Without knowing what the modifications are that you need to perform, its difficult to prescribe a solution. It might be possible to write a .as class file that you could run on each file.
          • 2. Re: NEED SOME HELP
            gkesava Level 1
            Hi Dillon
            thanks Dillon for your help
            for the flash file frist i need to go for settings  to change in to the flash player 9 in version. after that i need to sclect all the Tgas in the library and need to update the tgas. after that i need to do some linkage to the all files in the library after that i need to expot the SWF file and change to flash player 4.
            the same job i need to do it for all the rest of the files
            thanks
            KV
            • 3. Re: NEED SOME HELP
              No, I don't think you can do any of that with Actionscript. You need to hire an intern for that work.
