1 Reply Latest reply on Aug 10, 2006 2:41 PM by Lupus_23
    Webservices over SSL Problem
    Lupus_23
      I have a number of servers all running CF MX 6.1
      All of our sites are protected by a non-public certificate authority.
      I have been fighting with consumption of web services on just the test box.
      I have use the java keytool to import the root certificates to all of the servers. After much pain with this I have finally been able to get this to work on all machines but one. The final machine our test box still gives me the following exception:
      Message: Could not generate stub objects for web service invocation.
      Detail: Name: https://addressHere/test.cfc?WSDL. WSDL: https://addressHere/test.cfc?WSDL. java.net.SocketException: Default SSL context init failed: Invalid keystore format It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
      The key part is: Invalid keystore format
      What is the deal with this? The key tool has no problem listing, importing, and deleting certs.
      Any ideas?
