3 Replies Latest reply on Oct 5, 2011 10:58 AM by Flex harUI
    Maven built swf throwing strange error
    CRon_007
      Hi all,
      I built my flex project (sdk 4.1)  using maven(maven -e -X install). When i tried to run the generated swf, it throws a strange error:
      VerifyError: Error #1014: Class spark.components::Application could not be found.
      When i run the flash builder generated swf, it runs without any problems. I guess there is something i missed to include in the pom.xml.
      Please let me know how to handle it. My project basically is built in flex sdk 4.1.
      Please check my pom.xml below:
      Thanks.
      pom.xml:
      <?xml version="1.0" encoding="UTF-8"?>
      <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
                <parent>
                          <artifactId>abc-application</artifactId>
                          <groupId>com.abcd.abc</groupId>
                          <version>2.50.6.a</version>
                </parent>
                <modelVersion>4.0.0</modelVersion>
                <groupId>com.visualiq.iq</groupId>
                <artifactId>CW</artifactId>
                <packaging>swf</packaging>
                <name>CW</name>
                          <repositories>
                          <repository>
                                    <id>flexmojos</id>
                                    <url>http://repository.sonatype.org/content/groups/flexgroup/</url>
                          </repository>
                          <repository>
                                    <id>maven2-repository.dev.maven.org</id>
                                    <name>Maven.org Repository for Maven</name>
                                    <url>http://repo1.maven.org/maven2/</url>
                                    <layout>default</layout>
                          </repository>
                </repositories>
                <properties>
                          <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
                </properties>
                <pluginRepositories>
                          <pluginRepository>
                            <id>flexmojos-repository</id>
                          </pluginRepository>
                          <pluginRepository>
                                    <id>flexpmd.opensource.adobe</id>
                                    <releases>
                                              <enabled>true</enabled>
                                    </releases>
                                    <snapshots>
                                    </snapshots>
                                    <name>FlexPMD repository on opensource.adobe.com</name>
                                    <url>http://opensource.adobe.com/svn/opensource/flexpmd/maven-repository/release/</url>
                          </pluginRepository>
                </pluginRepositories>
                <build>
                    <sourceDirectory>src/main/flex</sourceDirectory>
                          <testSourceDirectory>src/test/flex</testSourceDirectory>
                          <finalName>Collaboration</finalName>
                          <plugins>
                                    <plugin>
                                              <groupId>org.sonatype.flexmojos</groupId>
                                              <artifactId>flexmojos-maven-plugin</artifactId>
                                              <version>3.9</version>
                                              <extensions>true</extensions>
                                              <dependencies>
                                                <dependency>
                                                        <groupId>com.adobe.flex</groupId>
                                                        <artifactId>compiler</artifactId>
        <version>4.1.0.16076</version>
                                                        <type>pom</type>
                                                </dependency>
                                              </dependencies>
                                              <executions>
                                                        <execution>
        <id>GroupDetachedView</id>
        <goals>
        <goal>compile-swf</goal>
        </goals>
        <phase>compile</phase>
        <configuration>
        <sourceFile>GroupDetachedView.mxml</sourceFile>
        <output>target/CW/GroupDetachedView.swf</output>
        </configuration>
                                                        </execution>
                                                        <execution>
        <id>main</id>
        <goals>
        </goals>
        <configuration>
        <sourceFile>main.css</sourceFile>
        <output>target/CW/main.swf</output>
        </configuration>
                                                        </execution>
                                                        <execution>
                                                          <id>wrapper generation</id>
                                                          <goals>
        <goal>wrapper</goal>
                                                          </goals>
                                                          <configuration>
        <outputDirectory>target/CW</outputDirectory>
                                                          </configuration>
                                                        </execution>
                                              </executions>
                                              <configuration>
                                                        <sourceFile>Coll.mxml</sourceFile>
                                                        <output>target/CW/Coll.swf</output>
                                              </configuration>
                                    </plugin>
                                    <plugin>
                                              <groupId>org.apache.maven.plugins</groupId>
                                              <artifactId>maven-site-plugin</artifactId>
                                              <version>3.0-beta-3</version>
                                    </plugin>
                          </plugins>
                </build>
                <dependencies>
                          <dependency>
                            <groupId>com.adobe.flex.framework</groupId>
                            <artifactId>flex-framework</artifactId>
                            <type>pom</type>
                          </dependency>
                          <dependency>
                            <artifactId>playerglobal</artifactId>
                                    <classifier>10.1</classifier>
                            <type>swc</type>
                          </dependency>
                          <dependency>
                            <groupId>com.adobe.flexunit</groupId>
                            <artifactId>flexunit</artifactId>
                            <version>4.0-beta-2</version>
                            <type>swc</type>
                            <scope>test</scope>
                          </dependency>
                          <dependency>
                            <artifactId>datavisualization</artifactId>
                            <type>swc</type>
                          </dependency>
                          <dependency>
                                    <artifactId>spark</artifactId>
                                    <type>swc</type>
                                    <scope>external</scope>
                          </dependency>
                          <dependency>
                            <artifactId>as3corelib</artifactId>
                                    <version>1.0</version><!-- provided swc version here need to check if
                                              the right thing to do is to specify flex framework version -->
                            <type>swc</type>
                          </dependency>
                          <dependency>
                                    <artifactId>CollabSWC</artifactId>
                                    <type>swc</type>
                          </dependency>
                </dependencies>
                <reporting>
                          <plugins>
                                    <plugin>
                                              <artifactId>maven-project-info-reports-plugin</artifactId>
                                              <version>2.3.1</version>
                                    </plugin>
                                    <plugin>
                                              <groupId>com.adobe.ac</groupId>
                                              <artifactId>flex-pmd-maven-plugin</artifactId>
                                              <version>1.2</version>
                                    </plugin>
                                    <plugin>
                                              <version>4.0-beta-7</version>
                                      <reportSets>
                                              <reportSet>
                                                <id>flex-reports</id>
                                                <reports>
                                                        <report>asdoc-report</report>
                                                </reports>
                                              </reportSet>
                                      </reportSets>
                                    </plugin>
                          </plugins>
                          <outputDirectory>${project.build.directory}/../../target/site/CW</outputDirecto ry>
                </reporting>
      </project>
        • 1. Re: Maven built swf throwing strange error
          Flex harUI Adobe Employee
          It sounds like some classes are being excluded from the linker because they or their swc/rsl are listed on the external-libraries option or rsl options.  I don’t know how that translates to Maven.
          • 2. Re: Maven built swf throwing strange error
            CRon_007 Level 1
            Hi harUI,
            Thasnk for your reply...
            I ve tried to change the scope of some dependencies to 'external'. Still i get some errors. I ve added a few more dependencies now. Everytime i change the scope i get a different error. Pleaswe go through my updated pom.xml below:
                      <parent>
                      </parent>
                      <name>CW</name>
                                <repositories>
                                <repository>
                                          <id>flexmojos</id>
                                </repository>
                                <repository>
                                </repository>
                      </repositories>
                      <properties>
                      </properties>
                                <pluginRepository>
                                </pluginRepository>
                                <pluginRepository>
                                          <releases>
                                          </releases>
                                          <snapshots>
                                          </snapshots>
                                </pluginRepository>
                      <build>
                                <plugins>
                                          <plugin>
                                                    <dependencies>
                                                      <dependency>
                                                              <type>pom</type>
                                                      </dependency>
                                                    </dependencies>
                                                    <executions>
                                                              <execution>
        <goals>
        </goals>
        <configuration>
        </configuration>
                                                              </execution>
                                                              <execution>
        <id>main</id>
        <goals>
        </goals>
        <configuration>
        </configuration>
                                                              </execution>
                                                              <execution>
        <goals>
        </goals>
        <configuration>
        </configuration>
                                                              </execution>
                                                    </executions>
                                                    <configuration>
                                                              <sourceFile>abc.mxml</sourceFile>
                                                              <output>target/CW/abc.swf</output>
                                                    </configuration>
                                          </plugin>
                                          <plugin>
                                          </plugin>
                                </plugins>
                      </build>
                      <dependencies>
                                <dependency>
                                  <type>pom</type>
                                </dependency>
                                <dependency>
                                  <type>swc</type>
                                </dependency>
                                <dependency>
                                  <type>swc</type>
                                  <scope>test</scope>
                                </dependency>
                                <dependency>
                                  <artifactId>textLayout</artifactId>
                                  <type>swc</type>
                                  <scope>caching</scope>
                                </dependency>
                                <dependency>
                                  <artifactId>framework</artifactId>
                                  <type>swc</type>
                                </dependency>
                                <dependency>
                                  <type>swc</type>
                                </dependency>
                                <dependency>
                                  <type>swc</type>
                                </dependency>
                                <dependency>
                                          <type>swc</type>
                                </dependency>
                                <dependency>
                                  <artifactId>sparkskins</artifactId>
                                  <type>swc</type>
                                </dependency>
                                <dependency>
                                  <type>swc</type>
                                </dependency>
                                  <dependency>
                                  <artifactId>rpc</artifactId>
                                  <type>swc</type>
                                </dependency>
                                <dependency>
                                  <type>pom</type>
                                </dependency>
                                <dependency>
                                          <artifactId>CollaborationSWC</artifactId>
                                          <type>swc</type>
                                </dependency>
                      </dependencies>
                      <reporting>
                                <plugins>
                                          <plugin>
                                          </plugin>
                                          <plugin>
                                          </plugin>
                                          <plugin>
                                            <reportSets>
                                                    <reportSet>
                                                      <reports>
                                                      </reports>
                                                    </reportSet>
                                            </reportSets>
                                          </plugin>
                                </plugins>
                      </reporting>
            </project>
            • 3. Re: Maven built swf throwing strange error
              Sorry, I don’t know anything about Maven.  You want fewer external dependencies, not more, or at least, match up your dependencies with rsls.
