0 Replies Latest reply on Oct 5, 2011 9:41 AM by stevoad
    Adding a SWC to a exported swf via a CS Extension
    stevoad
      I'm building a extension for Flash, and I'd like to be able add a swc file to a exported swf, that is generated through my Extension. I know that in the Flash JS extension language you can export a swf using:
      fl.getDocumentDOM().exportSWF("", true);
      As part of the export process can I add a SWC file, that contains code my CS extension needs to inject into the generated swf file. I did think that I could use:
      document.externalLibraryPath
      To point to a SWC file that is added to the published swf.
      What I want to do is add meta data to the Flash file that can be accessed externally at runtime, so I mark areas of the SWF that are updated dynamically at runtime.
      Are these ideas possible?
      Stephen
