11 Replies Latest reply on Oct 6, 2011 12:53 PM by newwoodworker
    Video Card effecting output?
    newwoodworker Level 1
      Does the video car in a computer have anything to do with the quality of the video files Premiere Pro or Encore write to an internal Blu-Ray burner? I can certaily see how the card impacts monitors and such but can it do anything to the actual files being written to the disk?
        • 1. Re: Video Card effecting output?
          the_wine_snob Level 9
          The video card should not have any effect on quality of the Exported files, or an authored disc.
          As of PrPro CS 5 (and including CS 5.5), there are other aspects of some video cards to consider, and this ARTICLE, plus its links, might be helpful.
          Now, I feel compelled to ask what problem you are encountering.
          • 2. Re: Video Card effecting output?
            As far as I know... no, the card does not do anything to the files
            • 3. Re: Video Card effecting output?
              Keep in mind that I am new this week to HD but so far it seems that what I get on disk is not as good as what I get if I plug the camera into the TV directly.
              Maybe I am just looking for a reason to buy a new video card.....
              Anyway, I will keep playing. I may have gotten a good tip on a camera setting that might do the files it generates some good as well. I have also been installing a Netgear RAID array ReadyNAS so I am back and forth between four computers all day. More playing over the next few days.
              • 4. Re: Video Card effecting output?
                Well... are you writing to a BluRay disc or a DVD disc?
                If to DVD, you do need to realize that downrezzing HD to SD for a DVD does involve a loss of quality
                What is the EXACT source of your HD files, and what are your EXACT output settings
                • 5. Re: Video Card effecting output?
                  I am away from my stuff right now but I am writing to Blu-Ray disks, the same brand as a buddy of mine that makes super-clear videos for a living. I also am using a blu-ray burner from his stock.
                  I am bringing in the files right out of my Canon XA10 that is set to the highest quality and I am generating h.264 (?) files at the highest resolution there as well. I hope that explains a bit of this anyway.
                  • 6. Re: Video Card effecting output?
                    I am shooting the footage with a Canon XA10, set on the MXP mode which I believe shoots at 1,920 X 1,080 resolution and 60 FPS. (When I bring these files onto the Premeire timeline I have to select all of them and check the "size to frame" deal or they appear magnafied.
                    I have been using theH.264 Blu-Ray preset with the 1440 X 1080i 29.97 High Quality and I have left everything else in default as it comes in Premeire.
                    I shoujld also note that I am running off the H.264videos for each segment of the Blu-Ray disk and then opening Encore and assembling the whole disk there and then burning it on an internal Blu-Ray bwriting drive.
                    I hope this is the info asked above.
                    • 7. Re: Video Card effecting output?
                      If you have the correct project setting, everything should just automatically fit correctly
                      See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666?tstart=0
                      Not at my editing computer, but I use MTS from a Canon Vixia and, with what appears to be the correct setting, my video "just fits, correctly" on the timeline http://forums.adobe.com/thread/652694?tstart=0
                      Of course, since I am going to DVD, there is a tiny bit of difference in the frames... but my DVD quality is FAR higher than when I used a DV500 card to digitize analog video from an 8mm Sony camera
                      • 8. Re: Video Card effecting output?
                        Oh crap! I've just been using the Media broswer to locate the video files and dragging them directly onto the timeline. I assummed that Premeire worked around that file format as that is all I use (the one good point for me so far....
                        I think that I have a bunch of re-editing to do...... the good news is that i am only 7 minutes or so into this project so I don't have to go jump off a bridge or anything.
                        THANKS A BUNCH! Now, back to the computer farm upstairs!
                        • 9. Re: Video Card effecting output?
                          I just started a new project, imported the files in as the video showed and the monitor output is way better already!
                          I think that they shoujld kill that media browser thing or at least how it works. It sure faked me out, or I faked it out or something happened, anyway, on to redoing this video!
                          Thanks again all.
                          • 10. Re: Video Card effecting output?
                            I've never used the Adobe media browser, so can't comment on what it does
                            I'm somewhat "old school" in doing things myself so I know what is happening, rather than any "auto-magic" routine that may work just fine, but I don't KNOW what it is doing
                            I copy the folder from the memory chip reader using Windows Explorer (after removing the memory chip from Vixia) so I put the folder exactly where **I** want it to go
                            I then open PPro and import the file(s) from that folder into my project... the 1st time I used the MTS files I started PPro with the preset for my files, saved that project as a generic name with no actual files inside, and then "forevermore" (no Ravens were harmed in writing this message) I open that blank project and do a "Save As" to create a new project
                            Having your project/sequence 100% match your video files does go a long way toward having better output
                            • 11. Re: Video Card effecting output?
                              I'm going to forget about the Media Browser and stick to the import deal.
                              i also download the mts files from the camera and dump them in a folder I make (so I know where they are also) then I Import them into Premeire and if this afternoon is any indication, my HD world just got crystal clear. I'm even impressed with the HDTV I use for a second monitor to see the preview on. Tack on sharp.
                              thanks again!
