0 Replies Latest reply on Oct 5, 2011 9:26 PM by gordon277
    Using SimpleButton in Flex - shrinks
    gordon277
      I've been successfully using SimpleButtons in Flex that are created in CS5 and exported as an .swc library. I basically use an SWFLoader, with a slight modification for enabling/disabling. The problem that I'm having is that when I click on a button and disable it at the same time, the button shrinks. Here is my class:
          <mx:SWFLoader xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:mx="library://ns.adobe.com/flex/mx"
                    buttonMode="true">
          <fx:Script>
              <![CDATA[
                  override public function set enabled(value:Boolean):void
                      super.enabled = value;
                      invalidateProperties();
                  override protected function commitProperties():void
                      super.commitProperties();
                      if(source != null)
                          if(source.enabled != enabled)
                              invalidateSize();
                          source.enabled = enabled;
                          alpha = enabled ? 1 : .5;
                          SimpleButton(content).mouseEnabled = enabled;
                          buttonMode = enabled;
          </fx:Script>
      </mx:SWFLoader>
      Here is how I'm using it:
      <fx:Script>
              <![CDATA[
                  private function r():void
                      myButton.enabled = false;
          </fx:Script>
          <ui:FlashButton id="myButton" source="{new MySimpleButton()}" width="300" height="300" click="r()" />
      1) The problem only happens if I click on the button and disable it. If I add a second button, say "OtherButton" and it still calls r(), it will disable, but not shrink myButton
      2) I fixed this problem for ones where I don't explicitly set the width/height, by adding this code:
            invalidateSize();
      I know that invalidateSize() doesn't matter for components that have their width/height set.
      Using SimpleButtons like this overall works really well, except for this one problem. I've tried setting width/height/measuredWH/expliistWH inside commitProperties(), but couldn't solve the problem.
      Thanks a lot
