8 Replies Latest reply on Oct 10, 2011 8:42 AM by Darrell Loverin
    Maybe, identified an issue when specified parent domain for RSLs
    Romain Gi.
      Hi all,
      According to the documentation we have tried to setup the runtime-shared-library-path option to: parent.
      doc: http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf674ba-7fff.html#WS19 f279b149e7481c-64f4fc4712daa436650-7fff
      • parent — Loads the RSL into the application domain of the parent application or module.
      But in our use case it does not work. Let me explain our use case:
      An Application load a Module with name ParentModule and this parent Module will load 2 Modules: ChildModule1 and ChildModule2.
      The 2 children modules share a common RSL in parent mode: <application-domain-target>top-level</application-domain-target>
      The expected result is:
      The ParentModule should load the RSL only one times but at the end the RSL is loaded twice. We can check it in the parentModuleInfo.factory.preloadedRSLs() which should contain 1 entry but contains 2.
      The following code can help you to reproduce the issue:
      Main.mxml
                                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="creationCompleteHandler(event)">
                <fx:Script>
                          <![CDATA[
                                    import mx.events.FlexEvent;
                                    import mx.events.ModuleEvent;
                                    import mx.modules.IModuleInfo;
                                    import mx.modules.ModuleManager;
                                    import spark.modules.Module;
                                    private var moduleInfo:IModuleInfo;
                                    protected function creationCompleteHandler(event:FlexEvent):void
                                              addEventListener("EndModule1", refreshProblemLabel);
                                              addEventListener("EndModule2", refreshProblemLabel);
                                              moduleInfo=ModuleManager.getModule("../../ParentModule/bin-debug/ParentModule.swf")          ;
                                              moduleInfo.addEventListener(ModuleEvent.READY, moduleReady);
                                              moduleInfo.addEventListener(ModuleEvent.ERROR, moduleError);
                                              moduleInfo.load(new ApplicationDomain(ApplicationDomain.currentDomain),null,null,moduleFactory);
                                    private function moduleReady(e:ModuleEvent):void
                                              var module:Module= e.module.factory.create() as Module;
                                              trace("Parent Module ready");
                                              modContainer.addElement(module);
                                    private function moduleError(e:ModuleEvent):void
                                              trace("Module load error");
                                    private function getSize(myDictionary:Dictionary):int
                                              var n:int = 0;
                                              for (var key:* in myDictionary) {
                                                        n++;
                                              return n;
                                    private function refreshProblemLabel(event:Event):void
                                              problemLabel.text = "Nb loaded RSL in the parent module: " + getSize(moduleInfo.factory.preloadedRSLs) + " Should be equal to 1!" ;
                </fx:Script>
                <s:layout>
                          <s:VerticalLayout/>
                </s:layout>
                <s:BorderContainer width="300" height="200" id="modContainer" borderVisible="true" borderStyle="solid" borderColor="red"/>
                <s:Label id="problemLabel" />
      </s:Application>
      ParentModule.mxml
      <s:Module xmlns:fx="http://ns.adobe.com/mxml/2009"
                <fx:Script>
                          <![CDATA[
                                    private var moduleInfo1:IModuleInfo;
                                    private var moduleInfo2:IModuleInfo
                                    private function loadModule1():void
                                              moduleInfo1=ModuleManager.getModule("../../ChildModule/bin-debug/Module1.swf")          ;
                                              moduleInfo1.addEventListener(ModuleEvent.READY, module1Ready);
                                              moduleInfo1.addEventListener(ModuleEvent.ERROR, moduleError);
                                              var applicationDomain:ApplicationDomain = new ApplicationDomain(ApplicationDomain.currentDomain);
                                              moduleInfo1.load(applicationDomain, null, null, moduleFactory);
                                    private function module1Ready(e:ModuleEvent):void
                                              trace("Module1 ready");
                                    private function module2Ready(e:ModuleEvent):void
                                              trace("Module2 ready");
                                    protected function loadModule2():void
                                              moduleInfo2=ModuleManager.getModule("../../ChildModule/bin-debug/Module2.swf")          ;
                                              moduleInfo2.addEventListener(ModuleEvent.READY, module2Ready);
                                              moduleInfo2.addEventListener(ModuleEvent.ERROR, moduleError);
                                              moduleInfo2.load(applicationDomain, null, null, moduleFactory);
                                    private function creationCompleteHandler(event:FlexEvent):void
                                              loadModule1();
                                              loadModule2();
                </fx:Script>
                <s:layout>
                          <s:VerticalLayout/>
                </s:layout>
                <mx:VBox id="modContainer" width="300" height="200" borderColor="red"
                                                           borderStyle="solid" borderVisible="true"/>
      </s:Module>
      Module1.mxml
                            xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="creationCompleteHandler(event)">
                <fx:Script>
                          <![CDATA[
                                    import pckg.MyClass;
                                    {MyClass}
                                              var endEvent:Event = new Event("EndModule1",true);
                                              dispatchEvent(endEvent);
                </fx:Script>
                <s:Label text="Module1"/>
      </s:Module>
      Module2.mxml
                <fx:Script>
                          <![CDATA[
                                    {MyClass}
                                              var endEvent:Event = new Event("EndModule2",true);
                </fx:Script>
                <s:Label text="Module2"/>
      </s:Module>
      The shared RSL class:
      MyClass.as:
      package pckg
                public class MyClass
                          public function MyClass()
      Regards,
      Romain.
      PS: My appology for my poor english level.
        • 1. Re: Maybe, identified an issue when specified parent domain for RSLs
          Darrell Loverin Level 4
          What happens if you wait for module1 to finish loading before you load module2. Maybe when module2 is loading, the RSL has not been loaded yet causing module2 to load the RSL again.
          -Darrell
          • 2. Re: Maybe, identified an issue when specified parent domain for RSLs
            Romain Gi. Level 1
            Hi Darrell,
            In our application we are waiting but not in the sample then I will modify the sample and comeback to you
            Cheers,
            Romain.
            • 3. Re: Maybe, identified an issue when specified parent domain for RSLs
              Romain Gi. Level 1
              Hi Darrell,
              Then we have modified the sample to wait the first child module ready event and then load the second one. And the result is the same. The issue is not associated to a race condition.
              Cheers,
              Romain
              PS: the new ParentModule code:
                        <fx:Script>
                                  <![CDATA[
                                                      moduleInfo1=ModuleManager.getModule("../../ChildModule/bin-debug/Modu le1.swf")          ;
                                                      // load module 2 after module 1 loading
                                                      loadModule2();
                                                      moduleInfo2=ModuleManager.getModule("../../ChildModule/bin-debug/Modu le2.swf")          ;
                                                      loadModule1();
                        </fx:Script>
                        <s:layout>
                                  <s:VerticalLayout/>
                        </s:layout>
              </s:Module>
              • 4. Re: Maybe, identified an issue when specified parent domain for RSLs
                To reproduce the issue I'll need to know how you compiled the application and modules. Could you provoide the command lines that you used as well as the contents of any configuration files? If you used Flash Builder to compile the project could you describe the application domain settings of the application and modules (do they share the same project).
                Your question seems to be about the "parent" application domain setting but you are specifying "top-level" application domain (application-domain-target>top-level</application-domain-target>). Could you clear up how you are compiling your applications and modules.
                -Darrell
                • 5. Re: Maybe, identified an issue when specified parent domain for RSLs
                  Romain Gi. Level 1
                  Hi Darrell,
                  First of all I have done a mistake (copy/paste issue  ) we are using "parent" application-domain-target and not top-level. I'm sorry for that.
                  Our sample has been build by FlashBuilder 4.5.1. The project structure is the following:
                  +- flex-rsl                              //<- the root workspace folder
                      +- ChildModule                  //<- child application module project
                          +- src
                              +- Module1.mxml
                              +- Module2.mxml
                      +- Lib                               //<- sharedlib rsl project
                          +- src
                              +- pckg
                                  +- MyClass.as
                      +- Main                            //<- main application project
                          +- src
                              +- Main.mxml
                      +- ParentModule               //<- Parent Module project
                          +- src
                              +- ParentModule.mxml
                  Then the dependencies and configuration options:
                  ChildModule:
                  Flex 4.5.1
                  Libs link Type: External
                  lib:
                    - Source attachement: \Lib\src
                    - Link Type: Runtime shared library (RSL)
                    - RSL URL: Lib.swf
                    - force load RSL: false
                  - Application Domain: parent
                  Lib:
                  Flex 4.5.1
                  ParentModule:
                  Flex 4.5.1
                  Main:
                  Flex 4.5.1
                  That's all I think.
                  But if you want I can share my sample with you? I don't know how?
                  Romain
                  PS: If you want I can open a bug and provide you my sample in attachement
                  • 6. Re: Maybe, identified an issue when specified parent domain for RSLs
                    I could reproduce the problem and found a fix. The bug is written up as https://bugs.adobe.com/jira/browse/SDK-31808. Please see the bug for a possible work around and a patch file. Please vote for the fix.
                    -Darrell
                    • 7. Re: Maybe, identified an issue when specified parent domain for RSLs
                      Romain Gi. Level 1
                      Hi Darrell,
                      What do you think about the following patch:
                      C:\sandbox\open-sources\flex\flex-sdk-mpl-4.5.1.21328-1\frameworks>diff c:\sandbox\open-sources\flex\flex_sdk_4.5.0.2096
                      7_mpl\frameworks\projects\framework\src\mx\utils\LoaderUtil.as c:\sandbox\open-sources\flex\flex-sdk-mpl-4.5.1.21328-1\f
                      495,497c495,500
                      <             // If there is no parent, ignore the target and load into the current
                      <             // app domain.
                      <             targetModuleFactory = parentModuleFactory;
                      >               if (currentModuleFactory == parentModuleFactory)
                      >                 // app domain.
                      Romain
                      PS: Thank you for your help.
                      • 8. Re: Maybe, identified an issue when specified parent domain for RSLs
                        I'm not sure about your patch. I attached a patch file to SDK-31808. Please use that patch.
