1 Reply Latest reply on Oct 6, 2011 4:03 PM by Linda Nicholls
    image size
    idesignew
      I'm having some predicament.
      Ally used this feature to the page size of the fireworks. From 6000px to 15000 px
      __________________________________________________________________________________________ __________________________
      Fireworks CS4 Preferences.txt
      (Windows XP: C:\Documents and Settings\USERNAME\AppData\Roaming\Adobe\Fireworks CS4\English\ {file here}
      Windows Vista/7: C:\Users\USERNAME\AppData\Roaming\Adobe\Fireworks CS4\English\ {file here}
      MacOS X: { not sure where it is? }
      Then make sure Fireworks CS4 is closed.
      Open the file with Notepad or any text editor.
      Find:
      <key>MaxDocSizeInPixels</key>
      <integer>6000</integer>
      Now change the 6000 value to anything that suites you -- for example, 8000 or 10000, etc. (this is pixels, max size of canvas in Fw)
      Save the file, close.
      __________________________________________________________________________________________ ___________________________
      So far so good.
      so that by the time I create a rectangle of 15000 px. He did not create. ie, he created the rectangle was left unfilled.
      how to solve this?
        • 1. Re: image size
          Linda Nicholls Level 4
          Fireworks was developed for creating web images. You don't use images over 6000 pixels high or wide on the web. Messing around with the program defaults in the way you suggest will probably cause just the kind of problem you have experienced.
