9 Replies Latest reply on Oct 24, 2011 11:09 AM by Shongrunden
    interactionMode in spark VGroup
    pamai
      Hi all!
      Does anyone know if it's posible use interactionMode=touch in a s:VGroup like in a s:DataGrid?  (web application)
      It works:
      <s:DataGrid id="aaa"  interactionMode="touch">
      It doesn't work:
      <s:VGroup id="aaa" interactionMode="touch" />
      Thanks!!
        • 1. Re: interactionMode in spark VGroup
          pamai Level 1
          I'm using Flex 4.5.1 SDK and it's for scroll a list of items using touch
          • 2. Re: interactionMode in spark VGroup
            pamai Level 1
            Any idea??
            Please...
            • 3. Re: interactionMode in spark VGroup
              Shongrunden Adobe Employee
              Is the VGroup inside a Scroller?  If so you need to set interactionMode="touch" on the Scroller, not the VGroup.
              • 4. Re: interactionMode in spark VGroup
                pamai Level 1
                Thanks!!
                Another question...
                I get an error when I use interactionMode=touch in some component of the application:
                aspectRatio was not found in the project
                at spark.components::Scroller/checkScrollPosition()[E:\dev\4.5.1\frameworks\projects\spark\s rc\spark\components\Scroller.as:1142]
                at spark.components::Scroller/checkScrollPositionsOnUpdateComplete()[E:\dev\4.5.1\frameworks \projects\spark\src\spark\components\Scroller.as:1237]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                It works correctly but displays this error.
                Any idea?
                • 5. Re: interactionMode in spark VGroup
                  Can you please post a small sample application that demonstrates this RTE?
                  • 6. Re: interactionMode in spark VGroup
                    pamai Level 1
                    I get the error using interactionMode="touch" in DataGrid and/or Scroller+VGroup.
                    This is the example with DataGrid:
                    <mx:Canvas xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" width="100%" height="100%" backgroundColor="#333333"
                                           horizontalScrollPolicy="off" verticalScrollPolicy="off">
                    <fx:Script>
                                        <![CDATA[
                                                  import model.CSensor;
                                                  import mx.collections.ArrayCollection;
                                                  [Bindable]
                                                  public var someSensors:ArrayCollection =  new ArrayCollection();
                                                  public function init():void{
                                                            someSensors = new ArrayCollection();
                                                            roSensor.getSensors();
                                                  public function handleFault(event: Object): void {
                      Alert.show(event.fault.faultCode + "\n" + event.fault.faultString, "Error");
                                                  public function handleResultSensors(event: Object): void {
                                                            someSensors = event.result;
                              </fx:Script>
                                   <mx:VBox left="5" top="5" right="5" bottom="5" verticalGap="5">
                                                  <s:DataGrid id="dgr_sensors" dataProvider="{someSensors}" width="100%" height="100%"  verticalScrollPolicy="on"                horizontalScrollPolicy="off" rowHeight="80" interactionMode="touch">
        <s:columns>
        <s:ArrayList>
        <s:GridColumn dataField="Name" headerText="Name" width="150"/>
        <s:GridColumn  dataField="Other" headerText="Other"/>
        </s:ArrayList>
        </s:columns>
                                                  </s:DataGrid>
                              </mx:VBox>
                              <fx:Declarations>
                                             <mx:RemoteObject id="roSensor" destination="sensorService" showBusyCursor="true" fault="handleFault(event)">
                                                            <mx:method name="getSensors" result="handleResultSensors(event)" />
                                             </mx:RemoteObject>
                              </fx:Declarations>
                    </mx:Canvas>
                    • 7. Re: interactionMode in spark VGroup
                      Your code sample doesn't compile for me.  I was unable to reproduce using this complete sample application:
                                     xmlns:s="library://ns.adobe.com/flex/spark">
                          <fx:Script>
                              <![CDATA[
                                  [Bindable]
                                  public var someSensors:ArrayCollection =  new ArrayCollection([{Name:'steve', Other:'test'},{Name:'steve', Other:'test'},{Name:'steve', Other:'test'}]);
                          </fx:Script>
                              <s:columns>
                                  <s:ArrayList>
                                  </s:ArrayList>
                              </s:columns>
                          </s:DataGrid>
                      </s:Application>
                      Can you please provide a similar complete code example that doesn't work for you?
                      • 8. Re: interactionMode in spark VGroup
                        pamai Level 1
                        This is a sample application:
                        <mx:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:mx="library://ns.adobe.com/flex/mx" width="100%" height="100%" horizontalAlign="left" verticalAlign="top" layout="absolute" pageTitle="Example" creationPolicy="all" historyManagementEnabled="false" horizontalScrollPolicy="off" verticalScrollPolicy="off">
                        <fx:Script>
                                            <![CDATA[
                                                      [Bindable]
                                  </fx:Script>
        <s:columns>
        <s:ArrayList>
        </s:ArrayList>
        </s:columns>
                                                      </s:DataGrid>
                                  </mx:VBox>
                                  <fx:Declarations>
                                                 </mx:RemoteObject>
                                  </fx:Declarations>
                        </mx:Canvas>
                        Thank you very much!!
                        • 9. Re: interactionMode in spark VGroup
                          Here is a smaller case that demonstrates this bug:
                                          xmlns:mx="library://ns.adobe.com/flex/mx">
                              <s:List width="100%" height="100%" interactionMode="touch">
                                  <s:ArrayList>
                                      <fx:String>0</fx:String>
                                      <fx:String>1</fx:String>
                                  </s:ArrayList>
                              </s:List>
                          </mx:Application>
                          It looks like you won't be able to use mx:Application with interactionMode="touch".  Can you use s:Application instead?
                          I've filed a bug for this here: http://bugs.adobe.com/jira/browse/SDK-31937
