2 Replies Latest reply on Oct 27, 2011 4:55 PM by *Q
    Problem with" Edit multiple frames" on CS5 ?
    anyoption1
      Hello,
      I'm having a problem with "Edit multiple frames" , it happened when I mark the layers and click "Edit multiple frames" then  (CS5) freeze!! I've tried it on both of my computers( XP and 7) same results!
      There is any solution ?
        • 1. Re: Problem with" Edit multiple frames" on CS5 ?
          anyoption1 Level 1
          here is more info
          Log Name:      Application
          Source:        Application Hang
          Date:          09/10/2011 17:40:40
          Event ID:      1002
          Task Category: (101)
          Level:         Error
          Keywords:      Classic
          User:          N/A
          Computer:      11081401-PC
          Description:
          The program Flash.exe version 11.0.2.489 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
          Process ID: c5c
          Start Time: 01cc869868a67f99
          Termination Time: 5
          Application Path: C:\Program Files\Adobe\Adobe Flash CS5\Flash.exe
          Report Id: 0287836a-f28d-11e0-a11e-000acd1be340
          Event Xml:
          <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
            <System>
              <Provider Name="Application Hang" />
              <EventID Qualifiers="0">1002</EventID>
              <Level>2</Level>
              <Task>101</Task>
              <Keywords>0x80000000000000</Keywords>
              <TimeCreated SystemTime="2011-10-09T15:40:40.000000000Z" />
              <EventRecordID>3959</EventRecordID>
              <Channel>Application</Channel>
              <Computer>11081401-PC</Computer>
              <Security />
            </System>
            <EventData>
              <Data>Flash.exe</Data>
              <Data>11.0.2.489</Data>
              <Data>c5c</Data>
              <Data>01cc869868a67f99</Data>
              <Data>5</Data>
              <Data>C:\Program Files\Adobe\Adobe Flash CS5\Flash.exe</Data>
              <Data>0287836a-f28d-11e0-a11e-000acd1be340</Data>
              <Binary>55006E006B006E006F0077006E0000000000</Binary>
            </EventData>
          </Event>
          • 2. Re: Problem with" Edit multiple frames" on CS5 ?
            *Q Level 3
            Please zip up your fla, change .zip to .zzz, and email to my attention at FlashAuthBetaBugs@adobe.com. I'll take a look at your file. Please also provide the steps so that I can reproduce your issue.
            Quynh
            Flash Pro, QE
