3 Replies Latest reply on Nov 10, 2006 12:00 PM by Newsgroup_User
    Button with text not sharp
    Annie_Benech Level 1
      I developed a menu using Fireworks. I used a standard button from Fireworks and entered a small text on each occurence of the button.
      Then I exported the menu to Dreamweaver.
      The problem was that the text does not seem clean (not so clean as a text edited through Dreamweaver).
      I saw on a forum that Fireworks is not a text editor. So I tried a second solution.
      I edited my menu through Fireworks but without the text. Then I exported the menu to Dreamweaver and added the text (using the div tag). The text is OK but the button is no more sensitive when the cursor is over the text.
      Is there someone who should help me on this?
      Thanks a lot
        • 1. Re: Button with text not sharp
          Level 7
          If you want the text to look like HTML text, then switch to system
          antialiasing.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Button with text not sharp
            Thanks a lot for your answer.
            I tried the different antialiasing modes. The 'clean' mode (in french 'anticrénelage net') seems the better. Nevertheless it is not so clean than in HTML mode.
            Thanks again.
            Yves Benech
            • 3. Re: Button with text not sharp
              Level 7
              > 'anticr?nelage net') seems the better. Nevertheless it is not so clean than in
              > HTML mode.
              Make sure you export in GIF rather than JPEG format.
