3 Replies Latest reply on Oct 8, 2011 4:06 PM by dieselheart_
    PDF- Filename automated from labelscript (after data merge)
    dieselheart_
      Hello,
      first of all I'm quite new in javascripting... but some simular scripts I have found on the internet could provide a solution for my problem.
      What I've done is the following:  I've used Data Merge and created a 200-paged file with 1 label on each page. Each label has a labelnumber.
      What I could do is export the file - split it up in 200 different pages - rename each file to the specific labelname. Seems a lot of work and this job I need to repeat about once a month.
      I looked for a solution and came to these discussion: http://forums.adobe.com/thread/289666http://      http://forums.adobe.com/message/3178412#3178412
      What I want to create is a script that I can run every month after I have updated my 200 labels and overrides all the pdf-files of the old labels.
      With the different scripts I have found I constructed the code below.
      The script works, it prints to multiple pdf's which have the correct labelnames, export is according to the requested presets,  but the CONTENT of each label is the content of the FIRST label (first page).
      I have tried a lot of thing (trail&error) but as I said, I'm quite new to this matter...
      So.... I can use some help or advice on this one.
      Thanks in advance,
      Dheart
      function getLABEL_A(page) {
                for (var  currentTextFrameIndex=0;currentTextFrameIndex<page.textFrames.length; ++currentTextFrameIndex) { // Iterates over frames
                     if (page.textFrames[currentTextFrameIndex].label=="LABEL_A") // if label is LABEL_A..
                          return page.textFrames[currentTextFrameIndex].contents; // ..returns text frame contents
                return null; // if not found, returns null
      var LABEL_A;
           var pagesList=app.activeDocument.pages;
           for (var currentPageIndex=0;currentPageIndex<pagesList.length;++currentPageIndex) { // Iterates over pages list
                currentPage=pagesList[currentPageIndex];
                LABEL_A=getLABEL_A(currentPage);
                if (LABEL_A!=null) { // If we have a LABEL_A - PDF file name-
                      var export_preset = app.pdfExportPresets.item("[Smallest File Size]");
                     app.activeDocument.exportFile(ExportFormat.pdfType,"F:/.../"+LABEL_A+".PDF",false,export_ preset); //.. and save the file
                } else {
                     alert("Page number "+currentPageIndex+" NO LABEL_A");
                     alert(LABEL_A);
        • 1. Re: PDF- Filename automated from labelscript (after data merge)
          dieselheart_ Level 1
          Does anyone see why the code generates every label with the same content of the first page?
          Maybe this can be helpfull so I know what to look for.
          Thanks in advance!
          • 2. Re: PDF- Filename automated from labelscript (after data merge)
            Colin Flashman Adobe Community Professional
            are the label numbers consecutive and logical; or are they all over the show and more than numbers?
            there is a cheat's way to do something similar using acrobat and bridge.
            take a large PDF and go to the extract pages feature in acrobat. go from page 1 to the last page and make sure that "extract as individual pages" is turned on. a new dialog appears asking where to save this - choose a directory where to save the files to. once done, close out of acrobat.
            if indesign's data merge feature allowed exporting to specific page lengths, this would be possible to do directly in indesign; (and the dialog is there to do it) but it doesn't work. i've reported this as a bug and encourage others to do so.
            ANYWAY... next, in bridge, navigate to the folder which the single page files have been exported to. from here, go to tools options and go batch rename. from here, it is possible to completely rename or add to filenames, including sequence numbers.
            this is all i can think of i'm afraid.
            • 3. Re: PDF- Filename automated from labelscript (after data merge)
              Thx for the reply, indeed this is a solution for consecutive numbering, however, the numbering is following another 'system' and in this case the numbering is given randomly.
              Anyway, trying a lot of things,  gave me a working script!!!
              The script exports a multipaged indesign file to single-paged pdf files. The namegiving of the pdf-files is automated and follows a labelscript (textlabel) on each page.
              function getLABEL(page) {
                             if (page.textFrames[currentTextFrameIndex].label=="LABEL") // if label is LABEL..
              var LABEL;
                   var currentPage;
                        LABEL=getLABEL(currentPage);
                        if (LABEL!=null) { // If we have a LABEL PDF -file name-
                            app.pdfExportPreferences.pageRange=String(currentPageIndex+1); // set up the export range..
                              var export_preset = app.pdfExportPresets.item("[High Quality Print]");
                               app.activeDocument.exportFile(ExportFormat.pdfType,"F:// fill in destination"+LABEL+".PDF",false,export_preset); //.. and save the file
                        } else {
                             alert("Page number "+currentPageIndex+" without LABEL box");
                             alert(LABEL);
