2 Replies Latest reply on Oct 8, 2011 6:04 PM by Shongrunden
    New to Flex - Need Help with this Code
    Zachary40347
      Getting NaN error... what am i doing wrong?
        • 1. Re: New to Flex - Need Help with this Code
          UbuntuPenguin Level 4
          What line are you getting the error at.  If you want to convert a string to a Number you generally have to use parseFloat( someString ).
          • 2. Re: New to Flex - Need Help with this Code
            Shongrunden Adobe Employee
            percent doesn't look like it is set to a value.  It will default to NaN and if you add anything to NaN you get NaN.
                           creationComplete="init()">
                <fx:Script>
                    <![CDATA[
                        protected function init():void
                            var num1:Number = 5;
                            var num2:Number;
                            var sum:Number = num1 + num2;
                            trace(sum);
                </fx:Script>
            </s:Application>
            You might want to initialize percent to zero.
