2 Replies Latest reply on Sep 9, 2012 4:17 PM by code_away
    Getting a ReferenceError: Error #1065 at application start
    CRon_007
      Hi all,
      I'm getting the following error at the start of my application:
      ReferenceError: Error #1065: Variable mx.messaging.config::ConfigMap is not defined.
      at _ABC_FlexInit$/init()
                at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::kickOff()
                at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::preloader_completeHandler()
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.preloaders::Preloader/timerHandler()
                at flash.utils::Timer/_timerDispatch()
                at flash.utils::Timer/tick()
      I have gone through a lot of posts on various forums. Most of them say that this error usually occurs in cases like:
      • not declaring classes as 'public'
      • trying to refer something that isn't there
      • syntax error
      When i run my application, it actually runs just fine. When i try to run the swf that is generated from maven install on my application, that is when this error occurs. So i can safely say that the above mentioned cases are not the reason for this error. So why is my maven built swf throwing this error. Any help would be much appreciated.
      Thanks.
