4 Replies Latest reply on Oct 9, 2011 1:59 AM by ajmayjnr
    Another Date Calculation Question.
    ajmayjnr
      Hi All,
      OK, this is a continuation from here: http://forums.adobe.com/thread/906583  Basically, I need to change the form a little and therefore need a continuation of that threads result.
      Short version - I need to take a future date which is calculated by taking a result of a drop down (0-13) and using this script finding a day in the futue:
      var f = this.getField("BILLINGCYCLEDATE");
      var g1 = this.getField("DAYS");
      var g = g1.value
      var today = new Date();
      var add = today.valueOf();
      add +=1000 * 60 * 60 * 24 * g;
      var future = new Date(add);
      f.value = util.printd("mm/dd/yyy", future);
      Basically it adds a number of days to today and giving a result.
      What I need to do is take that result, add another number of days (0-13 again) to give a new date.... and I am struggling to get a result at the moment.
      So here is a real workd scenario:
      How many days from today will the contract start?  (option 0-13 days) = RESULT A.
      How many days from RESULT-A will first payment be due (option 0-13) = RESULT B.
      Does that make sense?
      Thanks for any help you might be able to provide.
      Ant
        • 1. Re: Another Date Calculation Question.
          cuerdasg
          add the same script to the new field but add the following (payday is the next 0-13 field)
          var n1=this.getField("PAYDAY");
          var n=n1.value
          and change the add+ field to
          add+=1000*60*60*24*g*n
          and finally change billingcycledate field  to reference the new payday date field.
          • 2. Re: Another Date Calculation Question.
            ajmayjnr Level 1
            Hi Mate,
            OK, this gave me a result... but it was a result of X number of days from today (rather than from the result of "RESULT-A"
            Here is what I placed in as my script.
            var f = this.getField("DirectDebit_Start");
            var g1 = this.getField("Daysuntilstart");
            var g = g1.value
            var n1=this.getField("MembershipDaysTillBilling");
            var n=n1.value
            f.value = util.printd("dd mmmm yyyy", future);
            Any thoughts on where I am going wrong?  I have tried doing a few different things but I either get no result or I get X days from today's date.
            Thanks for your help!
            • 3. Re: Another Date Calculation Question.
              cuerdasg Level 1
              Sorry its actually add+=1000*60*60*24*(g+n) ...theres 1000 miliseconds in a second, 60 seconds in a minute, 60 minutes in an hou,r 24 hours in a day, times how many days out... so the g multiplication would give you how many days untill start... and add the n for days till billing  so that the total will give you the date for the bill.  I just did the math wrong.  Hope this clears it up for you.  you could also turn g+n into a variable so that the add+ still ends in a single variable.
              • 4. Re: Another Date Calculation Question.
                ajmayjnr Level 1
                Thank you so much!  Not only did it clear it up but the explaination ensured I learnt how that calculation works - thank you mate, I truly appreciate your assistance.
                Ant
