what is up with trying to instal the New Flash Player 11 when it goes to Hard drive? and the only thing i get is just the installer nothing else HELP Plus when i go to my hard Drive there is nothing there showing the Flash player 11.
i have windows 7 64bit i can you all the serous help
what happen to getting online tech support for issues like this?
which browser are you using and is it a 32-bit or 64-bit version? i'll supply a link to the installer that you'll need to complete the installation.
I use the 64 bit and I have windows 7
I have tried most of the day to install flash player 11.0 for the windows 7 64 bit but it will go so far and then tell me it as failed and I re try it and it does same thing
Can you give us the exact message you are getting?
Also, can you post the contents of file FlashInstall.log in C:\Windows\syswow64\Macromed\Flash ?
P.S. does the same thing happen if you use the installer from http://forums.adobe.com/thread/909550 ?
all the message saids is that it failed nothing more. No I haven't try the link you gave me .but I will try itnow.
I jst down loaded the link you gave me for the 64 bit and it saidsit is installed .But how do I know it really is in there ?????????
it saids it is there but I wonder if there away to check and see if it is??
Did you check in C:\Windows\syswow64\Macromed\Flash ?
Did you check in C:\Windows\system32\Macromed\Flash ?
Did you check if it works: http://www.adobe.com/software/flash/about/ ?
Sorry, I do not understand what your problem is. Where else would it install than on the hard drive?
I don’t know but its not showing up in the hard drive so you tell me where would it go cause I get message that the down load was done but when I go there its not in the hard drive.
