2 Replies Latest reply on Oct 10, 2011 8:05 AM by leo'ssite
    Having Voice Over problem with CS5
    leo'ssite
      Have Creative Sounblaster/front back inputs-drivers up to date
      Used head set with mic; Koss single mic and rode ntg-2 ; went to preference audio and hardware-set it up for creative-it doen't want the other input.
      The audio 1 line in--the best i can do is get a small green line of audio in audio 1 and master. I am in audio mixer mode. I have gone to control panel and identified the mic as well as seeing the audio move up/down. This does not translate, audio output/in in prem. pro. Alas i am stuck and need help.
      Note: Have 2T  (7200) on c and other drives. I7 and 12gb of ram.
      Leo
      PS. did front and back jacks-same results. Music/audio from other inputs OK.
        • 1. Re: Having Voice Over problem with CS5
          Andrey V Level 2
          Use Adobe Audition. Set it so that it will not stop recording when on the background, and start recording then switch to Premiere and watch your video clip recording your voice over and at the end just import recorded audio
          • 2. Re: Having Voice Over problem with CS5
            leo'ssite Level 1
            I don't have Adobe Audition but will look into it as well. Just an FYI, I did not realize that there was an extra step that I was unaware of. In preference/hardware, I needed to activate the asio section which opened another box. Once I indicated the mic I was using, no problem. The problem was solved by my nephew in 5 minutes. Oh well, learn something new everyday. Thanks for your input.
            Leo
