1 Reply Latest reply on May 25, 2012 5:40 AM by areohbee
    folder:getPhotos
    areohbee Level 6
      My preliminary testing of the folder:getPhotos function indicated it was working as documented - attending to the "include-children" parameter as expected (and returning all photos in a folder, and subfolders if include-children parameter true. whether filtered or stacked...).
      Now, it seems to be ignoring the include-children parameter and returning just the portion of photos that are contributing to the filmstrip, regardless of what I pass for the include-children parameter - its excluding those that are not top of stack, or are being excluded by lib filter...
      This latter behavior is exactly what I want, but its really bugging me that I concluded it was working differently before. And of course I fear it will revert to the previous (documented) behavior if I turn my back on it...
      Am I losing my mind?
      This function is presently working perfectly!? (but it seems like it shouldn't!!!):
      UPDATE: *** THIS FUNCTION NO LONGER WORKING (SEE BELOW), OR SHOULD I SAY IS WORKING HOW I EXPECT WHICH IS TO NOT WORK!!!
      (my presently conclusion is that folder:getPhotos is flaky - behavior shifts between returning all photos in folder (subject to include-children parameter), and just those contributing to filmstrip, ignoring include-children parameter)
      --- Get list of photos in filmstrip.
      --  @usage this function *may* not be perfect, and may return photos even if excluded by lib filter or buried in stack.
      --      <br>    presently its working perfectly, but I don't trust it, and neither should you!?
      --      <br>    *** originally: function Catalog:getFilmstripPhotos( assumeSubfoldersToo, bottomFeedersToo )
      --  @return      array of photos - may be empty, but never nil (should not throw any errors).
      function Catalog:getFilmstripPhotos()
          --local subfolders
          --if assumeSubfoldersToo == nil then
          --    subfolders = false -- nil means true otherwise.
          --end
          local targetPhoto = catalog:getTargetPhoto()
          if targetPhoto == nil then
              return catalog:getTargetPhotos()
          end
          local sources = catalog:getActiveSources()
          if sources == nil or #sources == 0 then
              return {}
          end
          local photoDict = {} -- lookup
          local filmstrip = {} -- array
          local function addToDict( photos )
              for i, photo in ipairs( photos ) do
                  --if not bottomFeedersToo then
                  --    local isBuried = cat:isBuriedInStack( photo )
                  --    if isBuried then
                  --    else
                  --        photoDict[photo] = true
                  --    end
                  --else
                  --end
              end
          end
          local function getPhotosFromSource( source )
              if source.getPhotos then
                  -- local photos = source:getPhotos( subfolders ) -- reminder: nil parameter behaves as true, not false.
                  local photos = source:getPhotos() -- At the moment, this function is doing exactly what I want: returning the photos as they contribute to filmstrip,
                  -- and excluding bottom feeders - its ignoring the "include-children" parameter. I could have sworn it was previously attending to said parameter as documented.
                  -- Although I'm glad it is behaving as it is, I fear problems that go away by themselves will return by themselves. ###3 - good for now I guess...
                  addToDict( photos ) -- assure no duplication, in case overlapping sources.
                  return
              elseif source.getChildren then
                  local children = source:getChildren()
                  for i, child in ipairs( children ) do
                      getPhotosFromSource( child )
                  end
              elseif source.type then
                  app:logWarning( "Unrecognized source type: " .. source:type() )
              else
                  app:logWarning( "Unrecognized source: " .. str:to( source ) )
              end
          end
          --local sc = 0
          for i, source in ipairs( sources ) do
              --sc = sc + 1
          end
          for k, v in pairs( photoDict ) do
              filmstrip[#filmstrip + 1] = k
          end
          return filmstrip
      end
      Thanks for any light you can shed,
      Rob
