This content has been marked as final.
Show 2 replies
1. Re: Plugin Problem On Starting CS3
Inchindown Oct 8, 2011 8:33 AM (in response to Inchindown)Addition to my original post.
The new PC is a 64 bit machine, in case that might be a factor.
2. Re: Plugin Problem On Starting CS3
MTSTUNER Oct 8, 2011 8:39 AM (in response to Inchindown)When you say loaded i hope you mean you actually installed cs3 on windows 7 and not just copied the program files over to win 7.
Those are adobe plugins installed with the cs3 install, so there is no need to copy those, only your third party plugins and it's
usually a good idea to use the plugin installer rather than to copy the files over. Were those plugins from cs3 or some other version?
You should probably uninstall cs3 and clear out the cs3 program files folder and then reinstall cs3 and then update cs3 to 10.01.
Photoshop cs3 should run fine on win 7 x64.
MTSTUNER
