2 Replies Latest reply on Oct 9, 2011 2:16 AM by ccsnet
    XML In To Flex Mobile
    ccsnet
      I wonder if you can help me.... I'm new to Flex so I've been playing with a demo app from Lynda which with out mods loads simple xml as a demo and shows it as a list.
      I've tried to take that and use a more complex xml file with some info I source from else where and I seem to not be able to process it. TypeError: Error #1034: Type Coercion failed: cannot convert XMLList@xxxx to XML comes upo which I believe is about placing XML in to an array where as it should be an object ? I've looked at a number of code snippets but there seems to be a number of ways to do this and I'm going round and round.
      I'd appriciate any help you may be able to give me been a complete noob.
      Terran
      <s:ViewNavigatorApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:s="library://ns.adobe.com/flex/spark" applicationDPI="240"
        splashScreenImage="@Embed('images/tmsplashscreen.jpg') "
        persistNavigatorState="true"
        creationComplete="getUnplanned.send()">
                <fx:Script>
                          <![CDATA[
                                    import mx.collections.ArrayCollection;
                                    import mx.core.FlexGlobals;
                                    import mx.rpc.events.ResultEvent;
                                    import views.MainHomeView;
                                    [Bindable]
                                    //make this work with xml
                                    protected var myUnplanned:ArrayCollection;
                                    // May not need this line
                                    protected function getUnplanned_resultHandler(event:ResultEvent):void
                                              // TODO Auto-generated method stub
                                              myUnplanned = event.result.payloadPublication.situation
                                              navigator.pushView(views.MainHomeView, event.result.payloadPublication.situation);
                </fx:Script>
                <fx:Declarations>
                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                          <s:HTTPService url="http://www.letscommunicate.co.uk/xxxxxxxxxxxxx/xmldisunplannedevente.php"
                                                           id="getUnplanned"
                                                           resultFormat="e4x"
                                                           result="getUnplanned_resultHandler(event)"/>
                </fx:Declarations>
                <s:navigationContent>
                          <s:Button label="Back" click="navigator.popView()"/>
                          <s:Button label="Menu" click="mx.core.FlexGlobals.topLevelApplication.viewMenuOpen=true"/>
                </s:navigationContent>
      </s:ViewNavigatorApplication>
        • 1. Re: XML In To Flex Mobile
          Shongrunden Adobe Employee
          Here's a simple example that appears to work:
              <fx:Script>
                  <![CDATA[
                      import mx.collections.XMLListCollection;
                      [Bindable]
                      protected var myUnplanned:XMLListCollection;
                          var xml:XML = new XML(event.result);
                          myUnplanned = new XMLListCollection(new XMLList(xml.children()));
                          myList.dataProvider = myUnplanned;
                      private function myLabelFunction(item:Object):String {
                          return item.TITLE;
              </fx:Script>
              <fx:Declarations>
                  <s:HTTPService id="getUnplanned" url="http://www.w3schools.com/xml/cd_catalog.xml" resultFormat="e4x" result="getUnplanned_resultHandler(event)"/>
              </fx:Declarations>
              <s:List id="myList" labelFunction="myLabelFunction"/>
          </s:Application>
          • 2. Re: XML In To Flex Mobile
            ccsnet Level 1
            Thanks very much - Ill give this a go.
            Terran
