1 Reply Latest reply on Oct 9, 2011 11:36 AM by Filmzaddict
    Wird problem with property setter
    Filmzaddict
      I have a class, inside it a get/set property, called IsSomethingCool of type Boolean. The setter looks like this:
      private var _isSomethingCool:Boolean = false;
      public function set IsSomethingCool(value:Boolean)
           _isSomethingCool = value;
          if (_isSomethingCool)
              coolStatusColor = 0x008000;    //green
           else
              coolStatusColor = 0xff0000;      // red
           trace("this doesnt");
      Inside this class theres also a function Test():void which basically looks like this:
      public function Test():Boolean
        var result:Boolean = false;
        //do some tests to dtermine if the object is cool
        //set result
        trace("this is actually happening");
        IsSomethingCool = result;
      This function fires periodically every second or so, and the wird thing is the trace statement inside Test function fires everytime, the trace function inside the property setter doesnt fire at all. Lol i ve been doing flex/as3 for 2-3 years now and i just feel like a donkey atm how is this possible?
