7 Replies Latest reply on Nov 8, 2006 11:36 AM by seth_hodgson
    Issues with messaging sample
    nivek83
      I am having trouble getting the built-in "dashboard" sample app to work with JMS. It works fine with Flex messaging, but for some reason, it seems like it can't stay subscribed to a topic when I use JMS.
      I am using WebSphere v6 with TibcoEMS v4.3 as the JMS provider.
      I know I have the destinations configured correctly, because when I send a message over the chat, I can see the number of pending messages in the topic increasing. I can publish to a topic, but cannot subscribe. After turning on the EMS trace, here's what it produces when I start up the dashboard application:
      [10/23/06 17:51:19:030 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: createSubscriber tsub=1871 tsess=214 topic=Topic[EMST.SS.FLEX_DASHBOARD_CHAT]
      [10/23/06 17:51:19:030 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: start conn=224
      [10/23/06 17:51:19:030 EDT] 00000064 SystemErr R 2006-10-23 17:51:19 [1867667001 Thread-74] [TIBCO EMS]: before receiveNoWait cons=1871 sess=214
      [10/23/06 17:51:19:030 EDT] 00000064 SystemErr R 2006-10-23 17:51:19 [1867667001 Thread-74] [TIBCO EMS]: after receiveNoWait cons=1871 sess=214 msg=null
      ...repeats last 2 lines 6 more times
      [10/23/06 17:51:19:733 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: createTopicConnection tconn=227 tconfac=TopicConnectionFactory[URL=tcp://adal54:10222;clientID=null] user=flex
      [10/23/06 17:51:19:733 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: setExceptionListener conn=227 lsnr=non-null
      [10/23/06 17:51:19:780 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: createTopicSession tsess=217 tconn=227 tran=false ackmode=1
      [10/23/06 17:51:19:795 EDT] 00000064 SystemErr R 2006-10-23 17:51:19 [1867667001 Thread-74] [TIBCO EMS]: before receiveNoWait cons=1871 sess=214
      [10/23/06 17:51:19:795 EDT] 00000064 SystemErr R 2006-10-23 17:51:19 [1867667001 Thread-74] [TIBCO EMS]: after receiveNoWait cons=1871 sess=214 msg=null
      [10/23/06 17:51:19:842 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: createSubscriber tsub=1873 tsess=217 topic=Topic[EMST.SS.FLEX_DASHBOARD_FEED]
      [10/23/06 17:51:19:842 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: start conn=227
      [10/23/06 17:51:19:842 EDT] 00000064 SystemErr R 2006-10-23 17:51:19 [1867667001 Thread-74] [TIBCO EMS]: before receiveNoWait cons=1873 sess=217
      [10/23/06 17:51:19:842 EDT] 00000064 SystemErr R 2006-10-23 17:51:19 [1867667001 Thread-74] [TIBCO EMS]: after receiveNoWait cons=1873 sess=217 msg=null
      [10/23/06 17:51:19:889 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: close cons=1871 sess=214
      [10/23/06 17:51:19:889 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: close cons=1873 sess=217
      [10/23/06 17:51:19:904 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: stop conn=227
      [10/23/06 17:51:19:967 EDT] 0000007d SystemErr R 2006-10-23 17:51:19 [564303409 WorkManager.DefaultWorkManager : 18] [TIBCO EMS]: stop conn=224
      It looks like it's starting up, creating the subscriber connection, and then once it doesn't find something to read, Flex is closing the connection so that it can't read any new messages. Has anyone run into anything similar in the past? Any suggestions on how to troubleshoot this further?
      Kevin
        • 1. Re: Issues with messaging sample
          aglosband
          What happens if you have a java client subscribed to the topic? When you send the message from Flex does the java client get the message? That might be something to try. In the meantime I'll ask if those errors look familiar to anyone here.
          • 2. Re: Issues with messaging sample
            nivek83 Level 1
            Thanks for the quick response.
            I confirmed that a simple Java client can receive a message sent from the Flex dashboard chat without a problem, so this is definitely looking like a Flex issue.
            Were you able to replicate this?
            Kevin
            • 3. Re: Issues with messaging sample
              aglosband Level 1
              Hi Kevin,
              I haven't tried to replicate this yet as we don't have a system with WebSphere 6 and Tibco configured currently. I'm going to go ahead and get one set up but in the meantime could you try two things for me?
              1. Can you try adding -Dtrace.rtmp and -Dtrace.message to the jvm arguments before starting the server. Hopefully if there is an exception that is causing the RTMP connection to close this will show it to us.
              2. Can you try changing the messaging destination to use the AMF polling channel instead of the RTMP channel (this may actually help you get around the problem for the time being). In the WEB-INF\flex\messaging-config.xml, just change the channels definition to the following and restart the server.
              <channels>
              <channel ref="my-polling-amf"/>
              </channels>
              We have had problems with the RTMP channel not working on some platforms so this will help us determine if it's an RTMP issue or not. Thanks.
              • 4. Re: Issues with messaging sample
                nivek83 Level 1
                I tried #1, and received the following error:
                javax.jms.IllegalStateException: Method setMessageListener not permitted
                I believe the explanation for this is in this article:
                http://www-1.ibm.com/support/docview.wss?uid=swg21114239
                Unfortunately, I don't have the full log trace for you because I deleted it in trying to troubleshoot issues with the second suggestion.
                I tried to test out the polling-amf solution, but since making that change, I have been unable to get anything to work, whether I use polling amf or go back to rtmp. The error I'm getting now is:
                [11/1/06 10:09:24:408 EST] 00000048 SystemOut O [Flex] [DEBUG] Error handling rtmp message: flex.messaging.MessageException: Context: MER2CONDA711373Node01Cell/nodes/MER2CONDA711373Node01/servers/server1, name:
                jms/TopicConnectionFactory
                : First component in name
                not found.
                This doesn't make any sense, as I'm able to connect to the TCF and the associated topics using the same plain JMS test program I used to troubleshoot this earlier. This program is running under the same server, and is actually part of the same WAR file, so I really don't understand how my test program can do the JNDI lookup, but Flex cannot. I am at a complete loss as to how to further troubleshoot this.
                I realize this is a completely different issue than what I first posted about, but it started happening when I was trying your two suggestions above. The *only* changes I made were to add the two JVM args that you suggested, and to change the channel Flex is trying to connect to. Even after reversing those two changes, I am still getting these JMS errors.
                Have you got any idea why this is happening?
                Kevin
                • 5. Re: Issues with messaging sample
                  CathyM Level 1
                  We've installed WebSphere with Tibco and are unfortnately, we see connections closing as well but haven't been able to pinpoint the issue.
                  This leaves two options for running the samples with JMS - either use the polling-amf channel (after resolving your issues) or using the default JMS provider that somes with WebSphere.
                  This isn't anything to worry about. This is something we would expect to see with the additional debug output. On WebSphere, when we encounter this exception we default to polling for JMS messages via receiveNoWait, which you've seen in your previous traces.
                  In your test programming, what properties did you pass into your initial context and how did you create the initial context? And, when you did the TopicConnectionFactory and the Topic jndi lookup, what did the code look like?
                  What does your destination configuration in samples/WEB-INF/flex/messaging-config.xml look like?
                  The shipping sample contains -
                  <connection-factory>jms/flex/TopicConnectionFactory</connection-factory>
                  <destination-jndi-name>jms/topic/flex/dashboard_chat</destination-jndi-name>
                  From the errors, it looks like you may be using jms/TopicConnectionFactory.
                  Also note that you'll need to use the name for the TopicConnectionFactory as exposed through JNDI, in some cases, this requires that resource-refs/resource-env-refs be resolved during web app deployment. In some cases, you may only access JMS resources if you've exposed the resources through the J2EE deployment files.
                  If you're exposed your JMS resources through the resource-env-refs then in many cases you'll access using -
                  java:comp/env/jms/flex/TopicConnectionFactory
                  java:comp/env/jms/flex/dashboard_chat
                  • 6. Re: Issues with messaging sample
                    nivek83 Level 1
                    I found the issue with the JNDI lookup. Apparently, when I made the change to messaging-config.xml to test the polling-amf solution, I did a Ctrl+Shift+F in Rational Application Developer, which formatted the xml file, and changed:
                    <connection-factory>jms/TopicConnectionFactory</connection-factory>
                    <destination-jndi-name>jms/topic/flex/DashboardFeed</destination-jndi-name>
                    to:
                    Seems there's a bug in the parser for the FDS config file that can't handle white space between the tag and the value.
                    Anyways, now that that's out of the way, I was able to test out the polling-amf solution, and I got the same results.
                    I don't know if this is actually helpful to you at all now that you have your own test setup, but here's the exception I'm getting now with the polling-amf solution. The first one is this, which you said not to worry about.
                    [11/1/06 17:59:18:322 EST] 0000002c JMSMessageCon 1 Method getMessageListener not permitted
                    javax.jms.IllegalStateException: Method getMessageListener not permitted
                    at com.ibm.ejs.jms.JMSCMUtils.methodNotPermittedException(JMSCMUtils.java:204)
                    at com.ibm.ejs.jms.JMSMessageConsumerHandle.getMessageListener(JMSMessageConsumerHandle.java :358)
                    at flex.messaging.services.messaging.adapters.JMSConsumer.receiverAdapter(JMSConsumer.java:1 61)
                    at flex.messaging.services.messaging.adapters.JMSConsumer.asyncReceive(JMSConsumer.java:86)
                    at flex.messaging.services.messaging.adapters.JMSAdapter.manage(JMSAdapter.java:368)
                    at flex.messaging.services.MessageService.manageSubscriptions(MessageService.java:571)
                    at flex.messaging.services.MessageService.serviceCommand(MessageService.java:152)
                    at flex.messaging.MessageBroker.routeCommandToService(MessageBroker.java:622)
                    at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:298)
                    at flex.messaging.endpoints.amf.MessageBrokerFilter.invoke(MessageBrokerFilter.java:93)
                    at flex.messaging.endpoints.amf.LegacyFilter.invoke(LegacyFilter.java:156)
                    at flex.messaging.endpoints.amf.SessionFilter.invoke(SessionFilter.java:46)
                    at flex.messaging.endpoints.amf.BatchProcessFilter.invoke(BatchProcessFilter.java:67)
                    at flex.messaging.endpoints.amf.SerializationFilter.invoke(SerializationFilter.java:130)
                    at flex.messaging.endpoints.AMFEndpoint.service(AMFEndpoint.java:164)
                    at flex.messaging.MessageBrokerServlet.service(MessageBrokerServlet.java:340)
                    at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
                    at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1212)
                    at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:629)
                    at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.jav a:80)
                    at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:1657)
                    at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:77)
                    at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink .java:421)
                    at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewInformation(HttpInboundLink .java:367)
                    at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.jav a:94)
                    at com.ibm.ws.tcp.channel.impl.WorkQueueManager.requestComplete(WorkQueueManager.java:548)
                    at com.ibm.ws.tcp.channel.impl.WorkQueueManager.attemptIO(WorkQueueManager.java:601)
                    at com.ibm.ws.tcp.channel.impl.WorkQueueManager.workerRun(WorkQueueManager.java:934)
                    at com.ibm.ws.tcp.channel.impl.WorkQueueManager$Worker.run(WorkQueueManager.java:1021)
                    at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1332)
                    Then, I receive thousands of these exceptions, presumably because they're being thrown every time Flex polls:
                    [11/1/06 17:59:18:541 EST] 0000003f JMSMessageCon 1 Caught JMSException in receiveNoWait
                    javax.jms.IllegalStateException: Consumer closed
                    at com.ibm.ejs.jms.JMSMessageConsumerHandle.checkOpen(JMSMessageConsumerHandle.java:747)
                    at com.ibm.ejs.jms.JMSTopicSubscriberHandle.getOpenTopicSubscriber(JMSTopicSubscriberHandle. java:543)
                    at com.ibm.ejs.jms.JMSTopicSubscriberHandle.getOpenMessageConsumer(JMSTopicSubscriberHandle. java:529)
                    at com.ibm.ejs.jms.JMSMessageConsumerHandle.receiveNoWait(JMSMessageConsumerHandle.java:566)
                    at flex.messaging.services.messaging.adapters.JMSConsumer.receiveNoWait(JMSConsumer.java:126 )
                    at flex.messaging.services.messaging.adapters.PollingMessageReceiver.run(PollingMessageRecei ver.java:68)
                    at java.util.TimerThread.mainLoop(Timer.java:447)
                    at java.util.TimerThread.run(Timer.java:397)
                    There's a lot more info in the trace file than that. If you give me an email address or an ftp location, I can send you the whole file.
                    So, right now, I am working under the assumption that Flex will not work with Websphere 6 and Tibco EMS. Is this something that we can expect to be fixed in the near future, or something that won't likely be fixed until the next major release, if it's fixed at all?
                    Kevin
                    • 7. Re: Issues with messaging sample
                      seth_hodgson Level 1
                      Hi Kevin,
                      Alex has reproduced this internally with Tibco EMS and we have a bug logged. Thanks for raising this issue. The root problem is that various vendors are more or less strict about which JMS APIs they allow to be invoked from within a web container. For the time being you'll need to try using a different JMS provider.
                      Sorry for the hassle,
                      Seth
