4 Replies Latest reply on Oct 11, 2011 8:54 AM by ozDiGennaro
    Dispatching & listening for custom events from custom component [Flex 4.1]
    martinjconnolly Level 1
      I'm giving this a try for the first time and I'm not sure I have the recipe correct!
      I have a custom component - it contains a data grid where I want to double click a row and dispatch an event that a row has been chosen.
      I created a custom event
      package oss
          import flash.events.Event;
          public class PersonChosenEvent extends Event
              public function PersonChosenEvent(type:String, bubbles:Boolean=false, cancelable:Boolean=false)
                  super(type, bubbles, cancelable);
              // Define static constant.
              public static const PERSON_CHOSEN:String = "personChosen";
              // Define a public variable to hold the state of the enable property.
              public var isEnabled:Boolean;
              // Override the inherited clone() method.
              override public function clone():Event {
                  return new PersonChosenEvent(type);
      Then I try to dispatch the event within the component when the datagrid is doubleclicked:
      import oss.PersonChosenEvent
      dispatchEvent(new PersonChosenEvent(PersonChosenEvent.PERSON_CHOSEN, true, false));
      And in the parent application containing the component I do on creationComplete
      addEventListener(PersonChosenEvent.PERSON_CHOSEN,addPersonToList);
      The event does not seem to fire though. And if I try to evaluate the "new PersonChosenEvent(..." code it tells me "no such variable".
      What am I doing wrong?
      (It was so easy in VisualAge for Java, what have we done in the last 10 years?? )
      Martin
        • 1. Re: Dispatching & listening for custom events from custom component [Flex 4.1]
          Claudiu Ursica Level 4
          I think your clone does not passes the bubbling as true. So you kind of need to do that yourself ...
          C
          • 2. Re: Dispatching & listening for custom events from custom component [Flex 4.1]
            UbuntuPenguin Level 4
            ಠ_ಠ
            • 3. Re: Dispatching & listening for custom events from custom component [Flex 4.1]
              I meant creating and promoting events was easy in VA Java. The IDE took care of it. Perhaps Flash Builder should do something similar. All this hand-coding makes me cranky....
              • 4. Re: Dispatching & listening for custom events from custom component [Flex 4.1]
                ozDiGennaro Level 1
                I've done this kind of thing routinely, when I want to add information to the event.  I never code the "clone" method at all.
                Be sure that you are listening to the event on a parent of the dispatching component.
                You can also have the dispatching component listen for the event too, and use trace() to get a debug message.
                I doubt if it has anything to to with "bubbles" since the default is true.
                Sample code
                In a child (BorderContainer)
                dispatchEvent(new ActivationEvent(ActivationEvent.CREATION_COMPLETE,null,window));
                In the container parent (BorderContainer)
                activation.addEventListener(ActivationEvent.CREATION_COMPLETE,activationEvent);
                package components.events
                    import components.containers.SemanticWindow;
                    import components.triples.SemanticActivation;
                    public class ActivationEvent extends Event
                        public static const LOADED:String = "ActivationEvent: loaded";
                        public static const CREATION_COMPLETE:String = "ActivationEvent: creation complete";
                        public static const RELOADED:String = "ActivationEvent: reloaded";
                        public static const LEFT_SIDE:String = "ActivationEvent: left side";
                        public static const RIGHT_SIDE:String = "ActivationEvent: right side";
                        private var _activation:SemanticActivation;
                        private var _window:SemanticWindow;
                        public function ActivationEvent(type:String, activation:SemanticActivation, window:SemanticWindow)
                            super(type);
                            _activation = activation;
                            _window = window
                        public function get activation():SemanticActivation {
                            return _activation;
                        public function get window():SemanticWindow{
                            return _window;
