4 Replies Latest reply on Oct 12, 2011 2:00 AM by Anthony_Clarke
    custom Dialog boxes
    Anthony_Clarke
      Hello Guys,
      What I would like to do is to have a box that pops up with an information text and when the user does an action (click on a button, use a radio button or a check box or anything else..) the content of a text field changes.
      I found in the api reference guide how to make a custom dialog box on page 111: http://www.adobe.com/content/dam/Adobe/en/devnet/acrobat/pdfs/js_api_reference.pdf
      The code at the end of my message is the sample code provided in this document. It produces a dialog box where the user can check a checkbox: ckbx  with the text pet owner to enable the 3 radio buttons to enter the number of pets the user has.
      This is the event triggered when the user changes the checkbox. It enables the radio buttons.
                     ckbx: function (dialog) {
                     // Process the checkbox, if the user has a pet, turn on radios                             Here I would need something like ckbx.name = "the new name"
                     this.hasPet = !this.hasPet;        or dialog.name ({"ckbx": "new name"} but I tried all tricks and no result
                     dialog.enable({
                     "rd01" : this.hasPet,
                     "rd02" : this.hasPet,
                     "rd03" : this.hasPet
      I tried everything I could think of to change the value of one of the text fields but it didn't work.
      Can we use the same kind of logic to change the text of a field in the dialog box?
      Thanks for your help guys,
      Source code below:
      var dialog2 =
      initialize: function(dialog) {
      // Set a default value for radio button field
      dialog.load({"rd01": true });
      this.hasPet = false;
      // Disable radio button field
      dialog.enable({
      commit: function(dialog) {
      // When the user presses "Ok", this handler will execute first
      console.println("commit");
      var results = dialog.store();
      // Do something with the data, for example,
      var hasPet = (this.hasPet) ? "have" : "don't have";
      console.println("You " + hasPet + " a pet.");
      if (this.hasPet)
      console.println("You have " + this.getNumPets(results)
      + " pet(s).");
      getNumPets: function (results) {
      for ( var i=1; i<=3; i++) {
      if ( results["rd0"+i] ) {
      switch {
      case 1:
      var nPets = "one";
      break;
      case 2:
      var nPets = "two";
      break;
      case 3:
      var nPets = "three or more";
      return nPets;
      ok: function(dialog) {
      // The handler for the Ok button will be handed after commit
      console.println("Ok!");
      dialog.enable({
      cancel: function(dialog) { // Handle the cancel button
      console.println("Cancel!");
      other: function(dialog){ // Handle the other button
      app.alert("Thanks for pressing me!");
      dialog.end("other"); // End the dialog box, return "other"!
      // The dialog box description
      description:
      name: "More Personal Information",
      elements:
      type: "view",
      align_children: "align_left",
      elements:
      type: "static_text",
      name: "Personal Information",
      bold: true,
      font: "dialog",
      char_width: 30,
      height: 20
      type: "check_box",
      item_id: "ckbx",
      type: "view",
      align_children: "align_row",
      elements:
      name: "Number of pets: "
      type: "radio",
      item_id: "rd01",
      group_id: "rado",
      type: "radio",
      item_id: "rd02",
      group_id: "rado",
      type: "radio",
      item_id: "rd03",
      group_id: "rado",
      name: "Three or more",
      type: "gap", //Add a small vertical gap between
      height: 10 //..radio fields and buttons
      type: "ok_cancel_other",
      ok_name: "Ok",
      cancel_name: "Cancel",
      other_name: "Press Me"
      var retn = app.execDialog(dialog2);
