7 Replies Latest reply on Oct 21, 2011 2:37 PM by MatteoLegittimo
    Width Height Custom Component
    MatteoLegittimo Level 1
      Hi!
      Im building a mobile application, so im trying to scale and optimize the application for different mobile.
      My problem it's that i dont know how to resize a custom component that i made, when canging the orientation or the device.
      Im my view i have the component:
      <components:MyComponent/>
      In this component there is just an fxg from illustrator:
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark" title="MyComponent" xmlns:assets="assets.*">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
         <assets:MenKshirt/>
      </s:View>
      If i do like this:
      <assets:MenKshirt width="90%"/>
      It's correctly scaling in the component, but not im myView:
              xmlns:s="library://ns.adobe.com/flex/spark" title="MyView" xmlns:component="component.*">
          <fx:Declarations>
          </fx:Declarations>
         <component:MyComponent/>
      </s:View>
      How can i do it?
      Thanks a lot!
        • 1. Re: Width Height Custom Component
          Shongrunden Adobe Employee
          You'll probably want to set <assets:MenKshirt width="100%"/> then set <component:MyComponent width="90%"/>.
          • 2. Re: Width Height Custom Component
            yes you right, but i need to scale also the height!
            When im in portrait state im gonna set the width to 100% but the height??? I need to scale proportionally
            I need to find a way to fit my component proportionally inside an area!
            Thanks again!
            • 3. Re: Width Height Custom Component
              pramod.rao
              Try using scaleX and scaleY properties. I think that should help you.
              • 4. Re: Width Height Custom Component
                I would recommend setting the component size to width="100%" height="100%" and then inside that component you will want to calcuate what size to make the things inside of it based on the width/height it is given and the aspect ratio you want to preserve.  Here's a simple (buggy) example:
                               xmlns:local="*">
                    <fx:Declarations>
                        <fx:Component className="MyComponent">
                            <s:Group resize="group1_resizeHandler()">
                                <fx:Script>
                                    <![CDATA[
                                        private var targetAspectRatio:Number = 2;
                                        protected function group1_resizeHandler():void
                                            // get the size of the target's parent
                                            var parentWidth:Number = this.width;
                                            var parentHeight:Number = this.height;
                                            var parentAspectRatio:Number = parentWidth / parentHeight;
                                            // start with the adjusted target size being the same as the parent
                                            var adjustedTargetWidth:Number = parentWidth;
                                            var adjustedTargetHeight:Number = parentHeight;
                                            // then if the the parent and source aspect ratios don't match we
                                            // want either the width or height of the source to equal the parent
                                            // size, then adjust the other appropriately
                                            if (targetAspectRatio > parentAspectRatio)
                                                adjustedTargetHeight = parentWidth / targetAspectRatio;
                                            else
                                                adjustedTargetWidth = parentHeight * targetAspectRatio;
                                            target.width = adjustedTargetWidth;
                                            target.height = adjustedTargetHeight;
                                </fx:Script>
                                <s:Button id="target" label="maintain my aspect ratio" />
                            </s:Group>
                        </fx:Component>
                    </fx:Declarations>
                    <local:MyComponent width="100%" height="100%" />
                </s:Application>
                • 5. Re: Width Height Custom Component
                  Hi Shongrunden,
                  thanks for your replay!
                  I tried to use your code and i did a new flex mobile project in flash builder like this:
                  The first View:
                          xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView" xmlns:component="component.*">
                      <fx:Declarations>
                      </fx:Declarations>
                      <component:MyComponent width="100%" height="100%"/>
                  </s:View>
                  The Component:
                          creationComplete="creationCompleteHandler(event)"
                          resize="resizeHandler(event)">
                      <fx:Script>
                          <![CDATA[
                              import mx.events.FlexEvent;
                              import mx.events.ResizeEvent;
                              private var targetAspectRatio:Number = 1;
                              private var parentWidth:Number
                              private var parentHeight:Number
                              private var parentAspectRatio:Number
                              private var adjustedTargetWidth:Number
                              private var adjustedTargetHeight:Number
                              protected function creationCompleteHandler(event:FlexEvent):void {
                                  onResize()
                              protected function resizeHandler(event:ResizeEvent):void {
                                  onResize()
                                  if (targetAspectRatio > parentAspectRatio){
                                  } else {
                              private function onResize():void {
                                  parentWidth = width;
                                  parentHeight = height;
                                  parentAspectRatio = parentWidth / parentHeight;
                                  adjustedTargetWidth = parentWidth;
                                  adjustedTargetHeight = parentHeight;
                                  trace('targetAspectRatio: '+targetAspectRatio+'        parentAspectRatio: '+parentAspectRatio)
                      </fx:Script>
                      <fx:Declarations>
                      </fx:Declarations>
                      <s:Group>
                      </s:Group>
                  </s:View>
                  I didn't understood why in my creationCompleteHandler when i call the on resize event the width is not setting (it's 0, the default value)
                  And why did u set the targetAspectRatio to 2?
                  thanks a lot!
                  Matteo
                  • 6. Re: Width Height Custom Component
                    Does it work if you use viewActivate instead of creationComplete?
                    I just set targetAspectRatio to some random number, you will probably want to calculate the aspect ratio that you wish to maintain.
                    • 7. Re: Width Height Custom Component
                      like this it's working:
                              resize="resizeHandler(event)" xmlns:assets="assets.*" creationComplete="creationCompleteHandler(event)">
                          <fx:Script>
                              <![CDATA[
                                  private var targetWidth:Number
                                  protected function creationCompleteHandler(event:FlexEvent):void{
                                      targetWidth = target.width
                                      setSize()
                                      onResize()
                                      //getScale()
                                      trace(getScale())
                                  private function setSize():void {
                                      //trace('w: '+target.width+'    h:'+target.height)
                                          trace('adjustedTargetHeight    '+parentAspectRatio)
                                      } else {
                                          trace('adjustedTargetWidth    '+parentAspectRatio)
                                      //trace('targetAspectRatio: '+targetAspectRatio+'        parentAspectRatio: '+parentAspectRatio)
                                  public function getScale():Number {
                                      //targetWidth : 100 = adjustedTargetWidth : x
                                      return (adjustedTargetWidth*100)/targetWidth
                          </fx:Script>
                          <fx:Declarations>
                          </fx:Declarations>
                          <s:Group>
                              <!--<s:Button id="target" label="maintain my aspect ratio" />-->
                              <assets:ManKshirt id="target"/>
                          </s:Group>
                      </s:View>
                      thanks for help me!
