• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Damaged Installer for Mac OS X Lion
New Here ,
Oct 11, 2011 Oct 11, 2011
I have tried numerous times to install Adobe Flash Player (versions 10.3.183.5 & 11.0.1.152) on Mac OS X Lion.  Every time the installer proceeds to approximately 5% completion, then fails with the following message:
The installation failed.  Get support.
From searching other threads I found the recommendation to run the uninstaller package, then download and re-run the latest installer package.  The uninstaller package runs fine, but the installer fails again.  Another thread recommends to control-click the Install Adobe Flash Player Application, then Show Package Contents, then open the Contents/Resources folder to find the Adobe Flash Player package.  When I try to run this package I receive the follwoing error message:
The Installer is damaged.  The Installer can't open the package.  There may be a problem with file ownership or permissions.
I have tried downloading the installer different times from both the Adobe website and download.cnet.com with no success.  This is a factory install of Lion and I have installed several other applications on this Mac with no problems.  I have installed JRE and ensured that that the Flash Player plugins are not currently installed in my Internet Plugins folder of my Library and the core Library.  I have installed Google Chrome and flash runs fine with it's flash player plugin.
Thanks in advance for any advice.
Views
2.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
sounds like you have a bad download.  clear your browser cache and try downloading the installers from this FAQ: http://forums.adobe.com/message/3952360
Votes
Translate
Translate
Report
Report
New Here ,
I cleared my cache by using the Safari/Reset Safari menu item (which deletes a lot of stuff), cleaned out my downloads folder, then emptied the trash.  I used the direct link to the Mac installer listed in the linked article.  Same result for both methods of opening the installed package.  I checked the file information for the installer downloaded and it showed the most recent download time for the version 11 installer.
Also, just for grins, I downloaded the installer using Chrome.  No luck that route either.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 14, 2011 Oct 14, 2011
LATEST
are you using the uninstaller that is also linked in the FAQ?
Votes
Translate
Translate
Report
Report
