8 Replies Latest reply on Oct 12, 2011 1:44 PM by Tuffmann
    AE is fast while working, slow when Rendering...?
    Tuffmann Level 1
      Hi there,
      I have a strange Problem with AE CS5.5 I guess.
      While working, everything is blazing fast. RAM-Previews are very quick, anything is fine. But when I'm rendering, it gets brutally slow.
      For example, I just had a small Animation with some Blur, Glow and Exposure, nothing big; in AE, I needed about 30secs for a RAM-Preview (at "Full"), but when rendering, it needs 10-15 Minutes. That's really strange, isn't it?
      I have a Dual Xeon-System with 16cores and 24GB RAM; I'm using 12 cores for rendering, 0,75GB/each. Windows 7 x64 is my OS
      Does anyone know how to maybe tweak it right?
        • 1. Re: AE is fast while working, slow when Rendering...?
          TimeRemapper Level 4
          Some of the reasons for potential slowdowns while rendering may be:
          • Output Module settings (codecs/encoding/multiple output modules, multiple resolutions)
          • Drive Speed
          • Network BUS Speed
          • Memory and Multi-processing settings
          Can you provide more info about your queued render items? How about your system set up? That info may help yield better results on this end. If you're using multiprocessing, you may want to try to disable it for a test render and see what your results are. Also, you should check out this FAQ.
          • 2. Re: AE is fast while working, slow when Rendering...?
            Tuffmann Level 1
            ->Output-Module
            1080p to FotoJPEG (QT) or CineForm, doesn't matter :/
            ->Drive Speed
            I thought about that. But honestly, how is this possible? The full video is about 100mb, not a big thing.
            Also, I tested it with my SSD, no Difference there.
            ->Network BUS Speed
            How is this related?
            These are my Multi-Processoring settings:
            http://dl.dropbox.com/u/748408/hardware/ae_settings.PNG
            I only queue one Item at a time.
            What else you need to know about my setup?
            • 3. Re: AE is fast while working, slow when Rendering...?
              It looks like you're likely starving your cores of RAM, which is in turn slowing down ther render. Each core should have 2GB of RAM for background processing. You're allocating .75GB. Way too little. Either try disabling "Render Multiple Frames Simultaneously", or increase the allocated RAM/Core, or decrease the number of used cores, and adjust RAM allocation accordingly.
              The Network BUS might have mattered if your doing a lot of Read/Write over the wire of major frame sizes and significant compression/decompression. Same for Disk Speed, however, I don't think either of these is the culprit. I think it's your memory settings.
              • 4. Re: AE is fast while working, slow when Rendering...?
                Tuffmann Level 1
                I read several tests where giving the cores more RAM didn't brought any big effect. Also, before I formatted my PC lately, it worked fine that way
                Decreasing the Cores is kinda stupid I think, I don't have 16cores to not using them or do I get this wrong?
                I'll try that, just rendering somethin so I can have a comparsion!
                //edit
                something strange happend:
                I started the render (with the Settings from above) and all cores were working hard. Now after 8 minutes, only 12% CPU is used...?
                • 5. Re: AE is fast while working, slow when Rendering...?
                  canoli99 Level 1
                  it may not be so "stupid" to use less cores if it means  their access to RAM is inadequate. Adobe recommends 2G minimum for AFX. As TR pointed out you're basically starving them by allocating so little.
                  You say you didn't notice any difference with MP turned off? That is very surprising.
                  It'll take some tweaking but start with (at least) 2G per CPU and go from there. You have a lot of options with 24G available. Maybe increase AFX's total by lowering the amount you're saving for other apps?
                  I have 24G as well and I rarely save more than 6G for PS, PP etc. You kinda want AFX to have as much RAM as possible...
                  One nice is thing is you can do your tweaking on the fly. Good luck with it! Let us know how you're progressing...
                  • 6. Re: AE is fast while working, slow when Rendering...?
                    Read this page for recommended memory settings, and read this page for more info on when enabling multi-processing is beneficial.
                    • 7. Re: AE is fast while working, slow when Rendering...?
                      canoli99 Level 1
                      Thansk TR - the links are helpful to me too as I was wrong to make a blanket statement saying "Adobe recommends 2G per CPU."
                      To quote Adobe:
                      "For a typical standard-definition television project, at least 1 GB per background process is recommended. For a typical project with HDTV-sized compositions, at least 2 GB per background process is recommended for optimum performance."
                      • 8. Re: AE is fast while working, slow when Rendering...?
                        Tuffmann Level 1
                        Funny, I read some Tests where the Size of RAM for each Core didn't matter. You'll never learn enough
                        I didn't meant w/o MP it's the same speed, I meant that less RAM was same then large RAM/core. But I see now this is wrong.
                        For know, I made every core 1,5GB, so I can use 11 cores. When I'm using too much RAM, Windwos tells me the System wouldn't have enough Memory and then AE makes failures, even if 4-5 GB are always available. Till I now how to avoid this, I'll leave it 1,5GB/Core.
                        Thanks Guys!
