18 Replies Latest reply on Nov 16, 2011 4:45 PM by bltechnical
    Adobe Reader requires Internet Explorer 6 or higher
    bltechnical
      I have attempted several times to install Adobe Reader X and keep getting this error. The computer runs Windows 7 and has Adobe Acrobat Standard 8 also installed. Any recommendations would be appreciated.
        • 1. Re: Adobe Reader requires Internet Explorer 6 or higher
          LeoAdobeX Adobe Employee
          Can you check if you have Shdocvw.dll file in the %SystemFolder%  (C:\Windows\System32)
          The file version must be 6.00.2600.0000 or higher
          • 3. Re: Adobe Reader requires Internet Explorer 6 or higher
            Ankit_Jain Adobe Employee
            Please re-register the file using  the following process:
            1. Click on the Start button and type in cmd.
            2. You will see a "cmd.exe" displayed in top section of the Start Menu. Right click on the same and select Run as Administrator.
            3. In the Command Prompt window displayed type:
                regsvr32 shdocvw.dll /i /s (Hit Enter)
                regsvr32 shdocvw.dll /s    (Hit Enter)
            Close the command Prompt window and try installing Adobe Reader again.
            Hopefully this should solve the issue.
            Ankit
            • 4. Re: Adobe Reader requires Internet Explorer 6 or higher
              bltechnical Level 1
              No sorry, same thing. When I run run the commands without the /s switch, I get the following error:
              The module "shdocvw.dll" was loaded but the entry-point DLLRegissterServer was not found.
              Make sure that "shdocvw.dll" is a valid DLL or OCX file and then try again.
              • 5. Re: Adobe Reader requires Internet Explorer 6 or higher
                Are you using a 64 bit OS?
                Can you try the following command and see if the issue gets resolved:
                    sfc /scannow (Hit Enter)
                • 6. Re: Adobe Reader requires Internet Explorer 6 or higher
                  bltechnical Level 1
                  No, it's Windows 7, 32-bit. SFC didn't find any integrity violations.
                  • 7. Re: Adobe Reader requires Internet Explorer 6 or higher
                    Can you please describe in details how you are trying to install Adobe Reader?
                    Every single step will help.
                    Do you have the following text in the error message "Please visit www.microsoft.com to upgrade Internet Explorer." ?
                    Can you make sure that %SystemFolder% is indeed resolves into C:\Windows\System32 ?
                    The only other thing I would suggest is if you could enable full verbose logging for Windows Installer (Google for instructions),
                    try to install again and provide latest MSIxxx.log file from your Temp folder.
                    • 8. Re: Adobe Reader requires Internet Explorer 6 or higher
                      Robert Hand
                      My I come in here?? I would like to download adobe reader 8, I can only find the updates using the search engine. Can anybody help me please??
                      • 9. Re: Adobe Reader requires Internet Explorer 6 or higher
                        bltechnical Level 1
                        %systemfolder% doesn't appear to be a valid variable. %systemroot% resolves to C:\windows. I looked at the log file and found nothing useful, maybe you can see something from it:
                        [logfile removed]
                        • 10. Re: Adobe Reader requires Internet Explorer 6 or higher
                          It is all about MIN_SYSTEM property which is set properly in the UI sequence, but was not passed to the Execute sequence and LaunchConditions action has failed - you can follow this property in the log file.
                          Can you try to install from local drive instead of the \\sbs\redirected\techadmin\Desktop ?
                          Let me know if it helped. If not, I'll spend some more time on it.
                          • 11. Re: Adobe Reader requires Internet Explorer 6 or higher
                            bltechnical Level 1
                            I ran it from C:\Apps. Same result:
                            [logfile removed]
                            • 12. Re: Adobe Reader requires Internet Explorer 6 or higher
                              I still see references to the network source location  in this log
                              MSI (c) (70:48) [10:31:28:478]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is '\\sbs.REDACTED.local\Software Media\Adobe\'.
                              The thing is that Windows Installer Service always tries to use latest registered source if it is available.
                              You would think that installation package is used from one location, but it is not always true.
                              Can you please make \\sbc... location unavailable? If you have any Reader already installed, please uninstall\cleanup it from the system before attempting to install again from local disk location.
                              Also, please delete logs from this thread - I do not need them anymore.
                              • 13. Re: Adobe Reader requires Internet Explorer 6 or higher
                                bltechnical Level 1
                                I moved the file from the server to the local C drive this time and got the same result:
                                [log data removed]
                                • 14. Re: Adobe Reader requires Internet Explorer 6 or higher
                                  You can delete the log now - I made a copy..
                                  Very interesting and unique issue.
                                  Something related to how this installation is elevated prevents MSI (Windows Installer) from allowing properties set in the UI sequence to be passed to the Execute sequence.
                                  All of those "Ignoring disallowed property.." should not be in the log.
                                  I have never seen MSI_LUA property to be referenced in the way it is referenced in your log file:
                                  MSI (c) (5C:40) [14:12:05:008]: MSI_LUA: Source resolution and approval provided for source 'C:\Apps\'
                                  MSI (c) (5C:40) [14:12:05:008]: MSI_LUA: 'Try Harder' succeeded and source accepted
                                  MSI (s) (E4:D8) [14:12:12:738]: MSI_LUA: Credential prompt is not required at this point, product is managed and deployment compliant
                                  Also, in the normal log I do not see this:
                                  MSI (s) (E4:D8) [14:12:12:740]: Machine policy value 'EnableUserControl' is 0
                                  MSI (s) (E4:D8) [14:12:12:740]: PROPERTY CHANGE: Adding RestrictedUserControl property. Its value is '1'.
                                  Do you have UAC enabled and getting UAC prompt during installation?
                                  I think your system has a unique policy set that leads to this MSI behavior.
                                  If you are not the one who set those policies, please ask your system administrator.
                                  Good luck.
                                  • 15. Re: Adobe Reader requires Internet Explorer 6 or higher
                                    bltechnical Level 1
                                    I'll try removing the computer from the domain and see if it installs.
                                    • 16. Re: Adobe Reader requires Internet Explorer 6 or higher
                                      bltechnical Level 1
                                      I ran the installer on the computer after removing it from the domain, so domain policies cannot be the cause.
                                      === Verbose logging started: 11/11/2011  13:53:17  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
                                      MSI (c) (40:C4) [13:53:17:372]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
                                      MSI (c) (40:D0) [13:53:17:387]: Resetting cached policy values
                                      MSI (c) (40:D0) [13:53:17:387]: Machine policy value 'Debug' is 0
                                      MSI (c) (40:D0) [13:53:17:387]: ******* RunEngine:
                                                 ******* Product: C:\Apps\AdbeRdr1010_en_US.msi
                                                 ******* Action:
                                                 ******* CommandLine: **********
                                      MSI (c) (40:D0) [13:53:17:387]: Machine policy value 'DisableUserInstalls' is 0
                                      MSI (c) (40:D0) [13:53:17:403]: User policy value 'SearchOrder' is 'nmu'
                                      MSI (c) (40:D0) [13:53:17:403]: User policy value 'DisableMedia' is 0
                                      MSI (c) (40:D0) [13:53:17:403]: Machine policy value 'AllowLockdownMedia' is 1
                                      MSI (c) (40:D0) [13:53:17:403]: SOURCEMGMT: Looking for sourcelist for product {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (c) (40:D0) [13:53:17:403]: SOURCEMGMT: Adding {AC76BA86-7AD7-1033-7B44-AA1000000001}; to potential sourcelist list (pcode;disk;relpath).
                                      MSI (c) (40:D0) [13:53:17:403]: SOURCEMGMT: Now checking product {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (c) (40:D0) [13:53:17:403]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
                                      MSI (c) (40:D0) [13:53:17:403]: SOURCEMGMT: Trying source C:\Apps\.
                                      MSI (c) (40:D0) [13:53:17:434]: Cloaking enabled.
                                      MSI (c) (40:D0) [13:53:17:434]: Attempting to enable all disabled privileges before calling Install on Server
                                      MSI (c) (40:D0) [13:53:17:450]: Connected to service.
                                      MSI (c) (40:D0) [13:53:17:465]: SOURCEMGMT: Resolved source to: 'C:\Apps\'
                                      MSI (c) (40:D0) [13:53:17:481]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Apps\AdbeRdr1010_en_US.msi' against software restriction policy
                                      MSI (c) (40:D0) [13:53:17:481]: SOFTWARE RESTRICTION POLICY: C:\Apps\AdbeRdr1010_en_US.msi has a digital signature
                                      MSI (c) (40:D0) [13:53:17:652]: SOFTWARE RESTRICTION POLICY: C:\Apps\AdbeRdr1010_en_US.msi is permitted to run at the 'unrestricted' authorization level.
                                      MSI (c) (40:D0) [13:53:17:652]: Cloaking enabled.
                                      MSI (c) (40:D0) [13:53:17:652]: Attempting to enable all disabled privileges before calling Install on Server
                                      MSI (c) (40:D0) [13:53:17:652]: End dialog not enabled
                                      MSI (c) (40:D0) [13:53:17:652]: Original package ==> C:\Apps\AdbeRdr1010_en_US.msi
                                      MSI (c) (40:D0) [13:53:17:652]: Package we're running from ==> C:\Apps\AdbeRdr1010_en_US.msi
                                      MSI (c) (40:D0) [13:53:17:684]: APPCOMPAT: looking for appcompat database entry with ProductCode '{AC76BA86-7AD7-1033-7B44-AA1000000001}'.
                                      MSI (c) (40:D0) [13:53:17:684]: APPCOMPAT: no matching ProductCode found in database.
                                      MSI (c) (40:D0) [13:53:17:715]: MSCOREE not loaded loading copy from system32
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'DisablePatch' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'AllowLockdownPatch' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'DisableMsi' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'AlwaysInstallElevated' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: User policy value 'AlwaysInstallElevated' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is admin assigned: LocalSystem owns the publish key.
                                      MSI (c) (40:D0) [13:53:17:762]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is managed.
                                      MSI (c) (40:D0) [13:53:17:762]: Running product '{AC76BA86-7AD7-1033-7B44-AA1000000001}' with elevated privileges: Product is assigned.
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'DisableLUAPatching' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'DisableFlyWeightPatching' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                                      MSI (c) (40:D0) [13:53:17:762]: APPCOMPAT: looking for appcompat database entry with ProductCode '{AC76BA86-7AD7-1033-7B44-AA1000000001}'.
                                      MSI (c) (40:D0) [13:53:17:762]: APPCOMPAT: no matching ProductCode found in database.
                                      MSI (c) (40:D0) [13:53:17:762]: Transforms are not secure.
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\LOCALA~1\AppData\Local\Temp\MSI185e1.LOG'.
                                      MSI (c) (40:D0) [13:53:17:762]: Command Line: CURRENTDIRECTORY=C:\Apps CLIENTUILEVEL=0 CLIENTPROCESSID=2880
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{9587FED9-63E2-4D75-B4B2-1F9CDD57B3F5}'.
                                      MSI (c) (40:D0) [13:53:17:762]: Product Code passed to Engine.Initialize:           '{AC76BA86-7AD7-1033-7B44-AA1000000001}'
                                      MSI (c) (40:D0) [13:53:17:762]: Product Code from property table before transforms: '{AC76BA86-7AD7-1033-7B44-AA1000000001}'
                                      MSI (c) (40:D0) [13:53:17:762]: Product Code from property table after transforms:  '{AC76BA86-7AD7-1033-7B44-AA1000000001}'
                                      MSI (c) (40:D0) [13:53:17:762]: Product not registered: beginning first-time install
                                      MSI (c) (40:D0) [13:53:17:762]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding ProductState property. Its value is '1'.
                                      MSI (c) (40:D0) [13:53:17:762]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                      MSI (c) (40:D0) [13:53:17:762]: Specifed source is already in a list.
                                      MSI (c) (40:D0) [13:53:17:762]: User policy value 'SearchOrder' is 'nmu'
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'DisableBrowse' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'AllowLockdownBrowse' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: Adding new sources is not allowed.
                                      MSI (c) (40:D0) [13:53:17:762]: Package name retrieved from configuration data: 'AdbeRdr1010_en_US.msi'
                                      MSI (c) (40:D0) [13:53:17:762]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                                      MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'EnableUserControl' is 0
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding RestrictedUserControl property. Its value is '1'.
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Apps'.
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2880'.
                                      MSI (c) (40:D0) [13:53:17:762]: TRANSFORMS property is now:
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
                                      MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '300'.
                                      MSI (c) (40:D0) [13:53:17:762]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming
                                      MSI (c) (40:D0) [13:53:17:762]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Favorites
                                      MSI (c) (40:D0) [13:53:17:762]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                                      MSI (c) (40:D0) [13:53:17:762]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Documents
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Recent
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\SendTo
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Templates
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Local
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Pictures
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Desktop
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                                      MSI (c) (40:D0) [13:53:17:777]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                                      MSI (c) (40:D0) [13:53:17:777]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                                      MSI (c) (40:D0) [13:53:17:777]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
                                      MSI (c) (40:D0) [13:53:17:777]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                                      MSI (c) (40:D0) [13:53:17:777]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Admin'.
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Microsoft'.
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Apps\AdbeRdr1010_en_US.msi'.
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Apps\AdbeRdr1010_en_US.msi'.
                                      MSI (c) (40:D0) [13:53:17:777]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Apps\'.
                                      MSI (c) (40:D0) [13:53:17:777]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Apps\'.
                                      MSI (c) (40:C4) [13:53:17:808]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
                                      === Logging started: 11/11/2011  13:53:17 ===
                                      MSI (c) (40:D0) [13:53:17:824]: Note: 1: 2205 2:  3: PatchPackage
                                      MSI (c) (40:D0) [13:53:17:824]: Machine policy value 'DisableRollback' is 0
                                      MSI (c) (40:D0) [13:53:17:824]: User policy value 'DisableRollback' is 0
                                      MSI (c) (40:D0) [13:53:17:824]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
                                      MSI (c) (40:D0) [13:53:17:824]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                                      MSI (c) (40:D0) [13:53:17:824]: Doing action: INSTALL
                                      Action 13:53:17: INSTALL.
                                      Action start 13:53:17: INSTALL.
                                      MSI (c) (40:D0) [13:53:17:840]: UI Sequence table 'InstallUISequence' is present and populated.
                                      MSI (c) (40:D0) [13:53:17:840]: Running UISequence
                                      MSI (c) (40:D0) [13:53:17:840]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
                                      MSI (c) (40:D0) [13:53:17:840]: Doing action: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A
                                      Action 13:53:17: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A.
                                      Action start 13:53:17: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A.
                                      MSI (c) (40:D0) [13:53:17:840]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947 B287C203A'
                                      MSI (c) (40:D0) [13:53:17:840]: PROPERTY CHANGE: Adding WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A property. Its value is 'C:\Windows\'.
                                      Action ended 13:53:17: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:840]: Doing action: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54
                                      Action 13:53:17: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
                                      Action start 13:53:17: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
                                      MSI (c) (40:D0) [13:53:17:840]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54'
                                      MSI (c) (40:D0) [13:53:17:840]: PROPERTY CHANGE: Adding WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\'.
                                      Action ended 13:53:17: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:840]: Doing action: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54
                                      Action 13:53:17: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
                                      Action start 13:53:17: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
                                      MSI (c) (40:D0) [13:53:17:840]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54'
                                      MSI (c) (40:D0) [13:53:17:840]: PROPERTY CHANGE: Adding SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\system32\'.
                                      Action ended 13:53:17: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:840]: Doing action: ISSetupFilesExtract
                                      Action 13:53:17: ISSetupFilesExtract.
                                      Action start 13:53:17: ISSetupFilesExtract.
                                      MSI (c) (40:D0) [13:53:17:840]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'ISSetupFilesExtract'
                                      MSI (c) (40:D0) [13:53:17:840]: Creating MSIHANDLE (1) of type 790542 for thread 976
                                      MSI (c) (40:E8) [13:53:17:840]: Invoking remote custom action. DLL: C:\Users\LOCALA~1\AppData\Local\Temp\MSI87B5.tmp, Entrypoint: SFStartupEx
                                      MSI (c) (40:B4) [13:53:17:840]: Cloaking enabled.
                                      MSI (c) (40:B4) [13:53:17:840]: Attempting to enable all disabled privileges before calling Install on Server
                                      MSI (c) (40:B4) [13:53:17:840]: Connected to service for CA interface.
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (2) of type 790531 for thread 3312
                                      1: Starting to extract setup files
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (2) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (3) of type 790531 for thread 3312
                                      1: Getting SUPPORTDIR property :
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (3) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (4) of type 790531 for thread 3312
                                      1: Extracting SetupFiles to:  C:\Users\LOCALA~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (4) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (5) of type 790541 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (6) of type 790531 for thread 3312
                                      1: Getting ISSetupFile table view
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (6) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (7) of type 790540 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (8) of type 790531 for thread 3312
                                      1: Executing ISSetupFile table view
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (8) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (9) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (10) of type 790531 for thread 3312
                                      1: Extracting Setup File:
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (10) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:886]: Creating MSIHANDLE (11) of type 790531 for thread 3312
                                      1: C:\Users\LOCALA~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}\FixTransforms .exe
                                      MSI (c) (40!F0) [13:53:17:886]: Closing MSIHANDLE (11) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:933]: Closing MSIHANDLE (9) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:933]: Creating MSIHANDLE (12) of type 790531 for thread 3312
                                      1: Setting SUPPORTDIR property to:  C:\Users\LOCALA~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (c) (40!F0) [13:53:17:933]: Closing MSIHANDLE (12) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:933]: PROPERTY CHANGE: Adding SUPPORTDIR property. Its value is 'C:\Users\LOCALA~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}'.
                                      MSI (c) (40!F0) [13:53:17:933]: PROPERTY CHANGE: Adding ISSETUPFILESCOMPLETED property. Its value is 'Completed'.
                                      MSI (c) (40!F0) [13:53:17:933]: Creating MSIHANDLE (13) of type 790531 for thread 3312
                                      1: Setting ISSETUPFILESCOMPLETED property
                                      MSI (c) (40!F0) [13:53:17:933]: Closing MSIHANDLE (13) of type 790531 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:933]: Closing MSIHANDLE (7) of type 790540 for thread 3312
                                      MSI (c) (40!F0) [13:53:17:933]: Closing MSIHANDLE (5) of type 790541 for thread 3312
                                      MSI (c) (40:E8) [13:53:17:933]: Closing MSIHANDLE (1) of type 790542 for thread 976
                                      Action ended 13:53:17: ISSetupFilesExtract. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:933]: Doing action: ProcessAbcpy
                                      Action 13:53:17: ProcessAbcpy. Processing the Abcpy.ini file.
                                      Action start 13:53:17: ProcessAbcpy.
                                      MSI (c) (40:D0) [13:53:17:933]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'ProcessAbcpy'
                                      MSI (c) (40:D0) [13:53:17:933]: Creating MSIHANDLE (14) of type 790542 for thread 976
                                      MSI (c) (40:54) [13:53:17:933]: Invoking remote custom action. DLL: C:\Users\LOCALA~1\AppData\Local\Temp\MSI8814.tmp, Entrypoint: GetOemSettings
                                      CustomAction ProcessAbcpy returned actual error code 1603 but will be translated to success due to continue marking
                                      MSI (c) (40:54) [13:53:17:933]: Closing MSIHANDLE (14) of type 790542 for thread 976
                                      Action ended 13:53:17: ProcessAbcpy. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:933]: Doing action: AppSearch
                                      Action 13:53:17: AppSearch. Searching for installed applications
                                      Action start 13:53:17: AppSearch.
                                      AppSearch: Property: ACROBAT_APP_PATH, Signature: _acrobat_sig
                                      MSI (c) (40:D0) [13:53:17:933]: PROPERTY CHANGE: Adding ACROBAT_APP_PATH property. Its value is 'C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe'.
                                      AppSearch: Property: MIN_SYSTEM, Signature: _Shdocvw_dll
                                      MSI (c) (40:D0) [13:53:17:949]: PROPERTY CHANGE: Adding MIN_SYSTEM property. Its value is 'C:\Windows\system32\Shdocvw.dll'.
                                      AppSearch: Property: AS_INSTALLDIR, Signature: _AsInstallDir
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\10.0\Installer 3: 2
                                      AppSearch: Property: READER_6X_INSTALLED, Signature: _Reader_6x_Installed
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\6.0\InstallPath 3: 2
                                      AppSearch: Property: AS_OPTIMIZE_ENABLED, Signature: _AsOptimizeEnabled
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Adobe\Acrobat Reader\10.0\Installer\Optimization 3: 2
                                      AppSearch: Property: AS_REPAIR_VERSION_LIST, Signature: _RepairVersionList
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Adobe\Repair\Acrobat Reader 3: 2
                                      AppSearch: Property: AS_OPTIMIZE_STATUS, Signature: _AsOptimizeStatus
                                      AppSearch: Property: READER_APP_PATH, Signature: _ReaderAppPath
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AcroRd32.exe 3: 2
                                      AppSearch: Property: READER_7X_INSTALLED, Signature: _Reader_7x_Installed
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\7.0\InstallPath 3: 2
                                      AppSearch: Property: ACROBAT_10_INSTALLED, Signature: _Acro_10_Installed
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Adobe Acrobat\10.0\InstallPath 3: 2
                                      AppSearch: Property: READER8_SU1_INSTALLED, Signature: _Rdr8_SU1_Installed
                                      MSI (c) (40:D0) [13:53:17:949]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\8.0\Installer 3: 2
                                      AppSearch: Property: IE_VERSION, Signature: _IeVersion
                                      MSI (c) (40:D0) [13:53:17:949]: PROPERTY CHANGE: Adding IE_VERSION property. Its value is '8.0.7601.17514'.
                                      AppSearch: Property: READER_PATH, Signature: _ReaderPath
                                      Action ended 13:53:17: AppSearch. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:949]: Doing action: LaunchConditions
                                      Action 13:53:17: LaunchConditions. Evaluating launch conditions
                                      Action start 13:53:17: LaunchConditions.
                                      Action ended 13:53:17: LaunchConditions. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:949]: Doing action: FindRelatedProducts
                                      Action 13:53:17: FindRelatedProducts. Searching for related applications
                                      Action start 13:53:17: FindRelatedProducts.
                                      FindRelatedProducts: Found application: {AC76BA86-1033-0000-BA7E-000000000003}
                                      MSI (c) (40:D0) [13:53:17:949]: PROPERTY CHANGE: Adding UT_AS2 property. Its value is '{AC76BA86-1033-0000-BA7E-000000000003}'.
                                      Action ended 13:53:17: FindRelatedProducts. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:949]: Skipping action: OlderOverNewerAbort (condition is false)
                                      MSI (c) (40:D0) [13:53:17:949]: Skipping action: CCPSearch (condition is false)
                                      MSI (c) (40:D0) [13:53:17:949]: Skipping action: RMCCPSearch (condition is false)
                                      MSI (c) (40:D0) [13:53:17:949]: Doing action: ValidateProductID
                                      Action 13:53:17: ValidateProductID.
                                      Action start 13:53:17: ValidateProductID.
                                      Action ended 13:53:17: ValidateProductID. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:949]: Doing action: CostInitialize
                                      Action 13:53:17: CostInitialize. Computing space requirements
                                      Action start 13:53:17: CostInitialize.
                                      MSI (c) (40:D0) [13:53:17:949]: Machine policy value 'MaxPatchCacheSize' is 10
                                      MSI (c) (40:D0) [13:53:17:949]: Baseline: Sorting baselines for {AC76BA86-7AD7-1033-7B44-AA1000000001}.
                                      MSI (c) (40:D0) [13:53:17:949]: Baseline: New baseline 10.1.0 from transaction.
                                      MSI (c) (40:D0) [13:53:17:980]: Baseline: Sorted order Native: Order 0.
                                      MSI (c) (40:D0) [13:53:17:980]: Baseline Data Table:
                                      MSI (c) (40:D0) [13:53:17:980]: ProductCode: {AC76BA86-7AD7-1033-7B44-AA1000000001} Version: 10.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
                                      MSI (c) (40:D0) [13:53:17:980]: Baseline File Table:
                                      MSI (c) (40:D0) [13:53:17:980]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:17:980]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
                                      Action ended 13:53:17: CostInitialize. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:980]: Doing action: SetupPluginsProperties
                                      Action 13:53:17: SetupPluginsProperties.
                                      Action start 13:53:17: SetupPluginsProperties.
                                      MSI (c) (40:D0) [13:53:17:980]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetupPluginsProperties'
                                      MSI (c) (40:D0) [13:53:17:980]: Creating MSIHANDLE (15) of type 790542 for thread 976
                                      MSI (c) (40:28) [13:53:17:980]: Invoking remote custom action. DLL: C:\Users\LOCALA~1\AppData\Local\Temp\MSI8843.tmp, Entrypoint: InitializePluginProperties
                                      MSI (c) (40:28) [13:53:17:996]: Closing MSIHANDLE (15) of type 790542 for thread 976
                                      Action ended 13:53:17: SetupPluginsProperties. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:996]: Doing action: FileTypesOwnerInit
                                      Action 13:53:17: FileTypesOwnerInit.
                                      Action start 13:53:17: FileTypesOwnerInit.
                                      MSI (c) (40:D0) [13:53:17:996]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'FileTypesOwnerInit'
                                      MSI (c) (40:D0) [13:53:17:996]: Creating MSIHANDLE (16) of type 790542 for thread 976
                                      MSI (c) (40:24) [13:53:17:996]: Invoking remote custom action. DLL: C:\Users\LOCALA~1\AppData\Local\Temp\MSI8854.tmp, Entrypoint: FileTypesOwnerInit
                                      MSI (c) (40!E0) [13:53:17:996]: Creating MSIHANDLE (17) of type 790531 for thread 2784
                                      ADelRCP logging: : PDF ownership: InitCurrentPDFOwner()
                                      MSI (c) (40!E0) [13:53:17:996]: Closing MSIHANDLE (17) of type 790531 for thread 2784
                                      MSI (c) (40!E0) [13:53:17:996]: Creating MSIHANDLE (18) of type 790531 for thread 2784
                                      ADelRCP logging: :    Current owner: C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe
                                      MSI (c) (40!E0) [13:53:17:996]: Closing MSIHANDLE (18) of type 790531 for thread 2784
                                      MSI (c) (40!E0) [13:53:17:996]: Creating MSIHANDLE (19) of type 790531 for thread 2784
                                      ADelRCP logging: :       The installing/uninstall app path: "\AcroRd32.exe";  version: 10
                                      MSI (c) (40!E0) [13:53:17:996]: Closing MSIHANDLE (19) of type 790531 for thread 2784
                                      MSI (c) (40!E0) [13:53:17:996]: Creating MSIHANDLE (20) of type 790531 for thread 2784
                                      ADelRCP logging: :    The installing/uninstalling product is not the current PDF owner
                                      MSI (c) (40!E0) [13:53:17:996]: Closing MSIHANDLE (20) of type 790531 for thread 2784
                                      MSI (c) (40!E0) [13:53:17:996]: PROPERTY CHANGE: Modifying DEFAULT_VERB property. Its current value is 'Read'. Its new value: 'Open'.
                                      MSI (c) (40!E0) [13:53:17:996]: PROPERTY CHANGE: Adding DISPLAYPDFOWNERSHIPDLG property. Its value is '1'.
                                      MSI (c) (40!E0) [13:53:17:996]: Creating MSIHANDLE (21) of type 790531 for thread 2784
                                      ADelRCP logging: :    Set the flag to display SetupFileTypes dialog, to decide if taking over ownership
                                      MSI (c) (40!E0) [13:53:17:996]: Closing MSIHANDLE (21) of type 790531 for thread 2784
                                      MSI (c) (40:24) [13:53:17:996]: Closing MSIHANDLE (16) of type 790542 for thread 976
                                      Action ended 13:53:17: FileTypesOwnerInit. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:996]: Doing action: FileCost
                                      Action 13:53:17: FileCost. Computing space requirements
                                      Action start 13:53:17: FileCost.
                                      MSI (c) (40:D0) [13:53:17:996]: Note: 1: 2262 2: Class 3: -2147287038
                                      Action ended 13:53:17: FileCost. Return value 1.
                                      MSI (c) (40:D0) [13:53:17:996]: Doing action: IsolateComponents
                                      Action 13:53:17: IsolateComponents.
                                      Action start 13:53:17: IsolateComponents.
                                      Action ended 13:53:17: IsolateComponents. Return value 0.
                                      MSI (c) (40:D0) [13:53:17:996]: Doing action: ResolveSource
                                      Action 13:53:17: ResolveSource.
                                      Action start 13:53:17: ResolveSource.
                                      MSI (c) (40:D0) [13:53:17:996]: Resolving source.
                                      MSI (c) (40:D0) [13:53:17:996]: Resolving source to launched-from source.
                                      MSI (c) (40:D0) [13:53:17:996]: Setting launched-from source as last-used.
                                      MSI (c) (40:D0) [13:53:17:996]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{AC76BA86-7AD7-1033-7B44-AA1000000001}'.
                                      MSI (c) (40:D0) [13:53:17:996]: SOURCEDIR ==> C:\Apps\
                                      MSI (c) (40:D0) [13:53:17:996]: SOURCEDIR product ==> {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (c) (40:D0) [13:53:17:996]: Determining source type
                                      MSI (c) (40:D0) [13:53:18:011]: Source type from package 'AdbeRdr1010_en_US.msi': 2
                                      MSI (c) (40:D0) [13:53:18:011]: Source path resolution complete. Dumping Directory table...
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TARGETDIR , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SourceDirCustom , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ACROFORM , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: EXERLOGS , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: AcrobatAppData , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CACHE , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COLLAB , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MESSAGES , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PREFERENCES , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PRINTME_STARTMENU_INTERNETPRINTING , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: UPDATERAPPDATA , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AdobeAppData , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAdobeAcrobat , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAcrobatVersion , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAcrobatVersionCache , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAcrobatVersionForms , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: AdobeAppData , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAcrobatVersionPrefs , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAcrobatVersionUpdater , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAdobe , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_LocalAppDataAdobe , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_LocalAppDataAdobeAcrobat , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_LocalAppDataAdobeAcrobatVer , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_LocalAppDataAdobeAcrobatVerCache , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_LocalAppDataAdobeAcrobatVerCacheSearch , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: U_AppDataAcrobatVersionCollaboration , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: printme_startmenu_internetprinting , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: AcrobatAppData_8 , Object: C:\Apps\ , LongSubPath:  , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A , Object: C:\Apps\ , LongSubPath: Windows\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WinSxsDirectory.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_94 7B287C203A , Object: C:\Apps\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WinSxsPolicies.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947 B287C203A , Object: C:\Apps\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: policydir.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287C 203A , Object: C:\Apps\ , LongSubPath: Windows\winsxs\Policies\dlpCRTx86\ , ShortSubPath: Windows\winsxs\Policies\mi3i-_yb\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: payload_ul.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287 C203A , Object: C:\Apps\ , LongSubPath: Windows\winsxs\ulpCRTx86\ , ShortSubPath: Windows\winsxs\c94ecusr\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WinSxsDirectory.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: policydir_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\ , ShortSubPath: Windows\winsxs\w5ctxsiq\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WinSxsPolicies.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: policydir.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\ , ShortSubPath: Windows\winsxs\Policies\izxws5kd\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WinSxsManifests.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\byzbj3nm\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: payload.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\dlCRTx86\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: payload_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\winsxs\ulCRTx86\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Apps\ , LongSubPath: Windows\system32\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WindowsVolume , Object: C:\Apps\ , LongSubPath: WinRoot\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: WindowsFolder , Object: C:\Apps\ , LongSubPath: Windows\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: USERPROFILE , Object: C:\Apps\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TemplateFolder , Object: C:\Apps\ , LongSubPath: ShellNew\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TempFolder , Object: C:\Apps\ , LongSubPath: Temp\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SystemFolder , Object: C:\Apps\ , LongSubPath: System32\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: System64Folder , Object: C:\Apps\ , LongSubPath: System64\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: System16Folder , Object: C:\Apps\ , LongSubPath: System\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: StartupFolder , Object: C:\Apps\ , LongSubPath: StartUp\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: StartMenuFolder , Object: C:\Apps\ , LongSubPath: Start Menu\ , ShortSubPath: STARTM~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SendToFolder , Object: C:\Apps\ , LongSubPath: SendTo\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ProgramMenuFolder , Object: C:\Apps\ , LongSubPath: Programs\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ProgramFiles64Folder , Object: C:\Apps\ , LongSubPath: Program Files 64\ , ShortSubPath: Prog64~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PrimaryVolumePath , Object: C:\Apps\ , LongSubPath: PrimaryVolumePath\ , ShortSubPath: Primar~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PersonalFolder , Object: C:\Apps\ , LongSubPath: Personal\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MyPicturesFolder , Object: C:\Apps\ , LongSubPath: MyPictures\ , ShortSubPath: MyPict~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LocalAppDataFolder , Object: C:\Apps\ , LongSubPath: LocalAppData\ , ShortSubPath: LocalA~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: GlobalAssemblyCache , Object: C:\Apps\ , LongSubPath: GlobalAssemblyCache\ , ShortSubPath: Global~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: FontsFolder , Object: C:\Apps\ , LongSubPath: Fonts\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: FavoritesFolder , Object: C:\Apps\ , LongSubPath: Favorites\ , ShortSubPath: FAVORI~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DesktopFolder , Object: C:\Apps\ , LongSubPath: Desktop\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CommonFiles64Folder , Object: C:\Apps\ , LongSubPath: Common64\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: AppDataFolder , Object: C:\Apps\ , LongSubPath: Application Data\ , ShortSubPath: APPLIC~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: AdminToolsFolder , Object: C:\Apps\ , LongSubPath: AdminTools\ , ShortSubPath: Admint~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CommonAppDataFolder , Object: C:\Apps\ , LongSubPath: CommonAppData\ , ShortSubPath: Common~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ALLUSERS_APPDATA_ADOBE , Object: C:\Apps\ , LongSubPath: CommonAppData\Adobe\ , ShortSubPath: Common~1\Adobe\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT , Object: C:\Apps\ , LongSubPath: CommonAppData\Adobe\Acrobat\ , ShortSubPath: Common~1\Adobe\Acrobat\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT_9 , Object: C:\Apps\ , LongSubPath: CommonAppData\Adobe\Acrobat\10.0\ , ShortSubPath: Common~1\Adobe\Acrobat\10.0\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE , Object: C:\Apps\ , LongSubPath: CommonAppData\Adobe\Acrobat\10.0\Replicate\ , ShortSubPath: Common~1\Adobe\Acrobat\10.0\REPLIC~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY , Object: C:\Apps\ , LongSubPath: CommonAppData\Adobe\Acrobat\10.0\Replicate\Security\ , ShortSubPath: Common~1\Adobe\Acrobat\10.0\REPLIC~1\SECURI~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Apps\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ProgramFilesFolder , Object: C:\Apps\ , LongSubPath: program files\ , ShortSubPath: PROGRA~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ADOBE , Object: C:\Apps\ , LongSubPath: program files\Adobe\ , ShortSubPath: PROGRA~1\Adobe\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: READER_9.0 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\ , ShortSubPath: PROGRA~1\Adobe\READER~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: INSTALLDIR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\ , ShortSubPath: PROGRA~1\Adobe\READER~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ESL_DIR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Esl\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Esl\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: RESOURCE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT_UNICODE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\Unicode\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT_UNICODE_MAPPINGS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\Unicode\Mappings\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT_UNICODE_MAPPINGS_WIN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\win\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\Unicode\Mappings\win\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT_UNICODE_MAPPINGS_MAC , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Mac\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\Unicode\Mappings\Mac\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT_UNICODE_MAPPINGS_ADOBE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Adobe\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\Unicode\Mappings\Adobe\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TYPESPT_UNICODE_ICU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\ICU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\TYPESU~1\Unicode\ICU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SASIPREP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\SaslPrep\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\SaslPrep\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: FONT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Font\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\Font\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PFM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Font\PFM\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\Font\PFM\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_LINGUISTIC , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Linguistics\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\LINGUI~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_LINGUISTIC_LANGUAGENAMES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Linguistics\LanguageNames2\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\LINGUI~1\Langua~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_PROVIDERS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Linguistics\Providers\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\LINGUI~1\PROVID~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_PROVIDERS_PROXIMITY , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\LINGUI~1\PROVID~1\PROXIM~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_PROVIDERS_PROXIMITY_1100 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\LINGUI~1\PROVID~1\PROXIM~1\11.00\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_PROVIDERS_PROXIMITY_1100_NCL3S4PNTX , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\NC-L3S4PNTX\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\LINGUI~1\PROVID~1\PROXIM~1\11.00\NC-L3S~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CMAP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\CMap\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\CMap\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CIDFONT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Resource\CIDFont\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Resource\CIDFont\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CACHE_SETUP_FILES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Setup Files\ , ShortSubPath: PROGRA~1\Adobe\READER~1\SETUPF~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CACHE_DIR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\ , ShortSubPath: PROGRA~1\Adobe\READER~1\SETUPF~1\PAC76B~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: READER , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: TRACKER , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Tracker\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Tracker\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SPPLUGINS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\SPPlugins\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\SPPLUG~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PLUGINS_3D , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins3d\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_i~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PLUGINS_3D_PRC , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins3d\prc\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_i~1\prc\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: NETSCAPE_4 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: NETSCAPE_3 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_8 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_7 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_6 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_5 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_4 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_3 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_2 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MOZILLA_1 , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_ZH_TW , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\zh_TW\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\zh_TW\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_ZH_TW , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\zh_TW\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\zh_TW\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_ZH_CN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\zh_CN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\zh_CN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_ZH_CN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\zh_CN\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\zh_CN\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_UK_UA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\uk_UA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\uk_UA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_UK_UA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\uk_UA\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\uk_UA\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_TR_TR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\tr_TR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\tr_TR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_TR_TR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\tr_TR\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\tr_TR\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_SV_SE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\sv_SE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\sv_SE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_SV_SE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\sv_SE\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\sv_SE\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_SL_SI , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\sl_SI\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\sl_SI\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_SL_SI , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\sl_SI\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\sl_SI\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_SK_SK , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\sk_SK\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\sk_SK\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_SK_SK , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\sk_SK\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\sk_SK\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_RU_RU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ru_RU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ru_RU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_RU_RU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ru_RU\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ru_RU\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_RO_RO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ro_RO\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ro_RO\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_RO_RO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ro_RO\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ro_RO\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_PT_BR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\pt_BR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\pt_BR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_PT_BR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\pt_BR\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\pt_BR\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_PL_PL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\pl_PL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\pl_PL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_PL_PL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\pl_PL\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\pl_PL\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_NL_NL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\nl_NL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\nl_NL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_NL_NL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\nl_NL\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\nl_NL\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_NB_NO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\nb_NO\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\nb_NO\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_NB_NO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\nb_NO\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\nb_NO\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_KO_KR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ko_KR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ko_KR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_KO_KR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ko_KR\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ko_KR\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_JA_JP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ja_JP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ja_JP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_JA_JP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ja_JP\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ja_JP\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_IT_IT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\it_IT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\it_IT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_IT_IT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\it_IT\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\it_IT\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_HU_HU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\hu_HU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\hu_HU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_HU_HU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\hu_HU\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\hu_HU\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_HR_HR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\hr_HR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\hr_HR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_HR_HR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\hr_HR\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\hr_HR\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_FR_FR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\fr_FR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\fr_FR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_FR_FR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\fr_FR\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\fr_FR\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_FI_FI , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\fi_FI\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\fi_FI\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_FI_FI , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\fi_FI\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\fi_FI\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_EU_ES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\eu_ES\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\eu_ES\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_EU_ES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\eu_ES\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\eu_ES\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_ES_ES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\es_ES\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\es_ES\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_ES_ES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\es_ES\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\es_ES\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_DE_DE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\de_DE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\de_DE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_DE_DE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\de_DE\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\de_DE\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_DA_DK , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\da_DK\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\da_DK\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_DA_DK , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\da_DK\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\da_DK\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_CS_CZ , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\cs_CZ\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_CS_CZ , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\cs_CZ\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LOCALE_CA_ES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ca_ES\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ca_ES\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: SERVICES_CA_ES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Locale\ca_ES\Services\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Locale\ca_ES\Services\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_UKR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\UKR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\UKR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_TUR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\TUR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\TUR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_SVE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\SVE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\SVE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_SUO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\SUO\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\SUO\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_SLV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\SLV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\SLV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_SKY , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\SKY\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\SKY\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_RUS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\RUS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\RUS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_RUM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\RUM\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\RUM\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_PTB , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\PTB\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\PTB\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_POL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\POL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\POL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_NOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\NOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\NOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_NLD , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\NLD\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\NLD\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_KOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\KOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\KOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_JPN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\JPN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\JPN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_ITA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\ITA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\ITA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_HUN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\HUN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\HUN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_HRV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\HRV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\HRV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_FRA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\FRA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\FRA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_EUQ , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\EUQ\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\EUQ\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_ESP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\ESP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\ESP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_ENU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\ENU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\ENU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_DEU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\DEU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\DEU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_DAN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\DAN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\DAN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_CZE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\CZE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\CZE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_CHT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\CHT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\CHT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_CHS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\CHS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\CHS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: LEGAL_CAT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Legal\CAT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Legal\CAT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: JAVASCRIPTS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Javascripts\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\JAVASC~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_UKR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\UKR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\UKR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_TUR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\TUR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\TUR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_SVE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\SVE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\SVE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_SUO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\SUO\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\SUO\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_SLV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\SLV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\SLV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_SKY , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\SKY\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\SKY\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_RUS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\RUS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\RUS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_RUM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\RUM\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\RUM\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_PTB , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\PTB\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\PTB\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_POL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\POL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\POL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_NOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\NOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\NOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_NLD , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\NLD\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\NLD\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_KOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\KOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\KOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_JPN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\JPN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\JPN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_ITA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\ITA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\ITA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_HUN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\HUN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\HUN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_HRV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\HRV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\HRV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_FRA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\FRA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\FRA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_EUQ , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\EUQ\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\EUQ\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_ESP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\ESP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\ESP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_ENU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\ENU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\ENU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_DEU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\DEU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\DEU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_DAN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\DAN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\DAN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_CZE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\CZE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\CZE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_CHT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\CHT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\CHT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_CHS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\CHS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\CHS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: IDTEMPLATES_CAT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\IDTemplates\CAT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\IDTEMP~1\CAT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_UKR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\UKR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\UKR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_TUR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\TUR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\TUR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_SVE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SVE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\SVE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_SUO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SUO\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\SUO\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_SLV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SLV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\SLV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_SKY , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SKY\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\SKY\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_RUS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\RUS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_RUM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUM\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\RUM\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_PTB , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\PTB\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\PTB\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_POL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\POL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\POL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_NOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\NOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_NLD , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NLD\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\NLD\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_KOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\KOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\KOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_JPN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\JPN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\JPN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_ITA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ITA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\ITA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_HUN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HUN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\HUN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_HRV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HRV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\HRV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_FRA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\FRA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\FRA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_ESP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ESP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\ESP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_ENU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ENU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\ENU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_DEU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DEU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\DEU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_DAN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DAN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\DAN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_CZE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CZE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\CZE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_CHT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\CHT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: DOCSETTINGS_PORTFOLIO_CHS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\DOCSET~1\PORTFO~1\CHS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: BROWSER_IE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: BROWSER , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\Browser\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PLUG_INS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_SVE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\SVE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\SVE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_NLD , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\NLD\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\NLD\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_ITA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ITA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\ITA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_FRA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\FRA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\FRA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_ESP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ESP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\ESP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_ENU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ENU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\ENU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: VDKHOME_DEU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\DEU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\VDKHome\DEU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PLUG_INS_ACROFORM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\AcroForm\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: PLUG_INS_ACROFORM_PMP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\PMP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\AcroForm\PMP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_SVE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_SUO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_PTB , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_NOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_NLD , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_KOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_JAPN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_ITA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_FRA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_EUQ , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_ESP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_DEU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_DAN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_CHT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_CHS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MULTIMEDIA_MPP_CAT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_UKR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_UKR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_UKR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_TUR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_TUR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_TUR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_SLV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SLV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_SLV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_SKY , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SKY\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_SKY\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_RUS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_RUS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_RUM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUM\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_RUM\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_POL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_POL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_POL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_HUN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HUN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_HUN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_HRV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HRV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_HRV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP_CZE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_CZE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP_CZE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: MPP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\MULTIM~1\MPP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ANNOTATIONS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_UKR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\UKR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\UKR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_TUR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\TUR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\TUR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_SVE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SVE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\SVE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_SUO , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SUO\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\SUO\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_SLV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SLV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\SLV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_SKY , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SKY\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\SKY\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_RUS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\RUS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_RUM , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUM\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\RUM\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_PTB , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\PTB\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\PTB\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_POL , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\POL\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\POL\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_NOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\NOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_NLD , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NLD\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\NLD\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_KOR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\KOR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\KOR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_JPN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\JPN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\JPN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_ITA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ITA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\ITA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_HUN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HUN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\HUN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_HRV , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HRV\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\HRV\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_FRA , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\FRA\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\FRA\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_EUQ , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\EUQ\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\EUQ\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_ESP , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ESP\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\ESP\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_ENU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ENU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\ENU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_DEU , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DEU\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\DEU\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_DAN , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DAN\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\DAN\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_CZE , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CZE\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\CZE\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_CHT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\CHT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_CHS , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHS\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\CHS\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: STAMP_CAT , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CAT\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\plug_ins\ANNOTA~1\Stamps\CAT\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: AIR , Object: C:\Apps\ , LongSubPath: program files\Adobe\Reader 10.0\Reader\AIR\ , ShortSubPath: PROGRA~1\Adobe\READER~1\Reader\AIR\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: CommonFilesFolder , Object: C:\Apps\ , LongSubPath: Common\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ADOBE_COMMON , Object: C:\Apps\ , LongSubPath: Common\Adobe\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_TW , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_tw\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_TW_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_tw\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_TW_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_tw\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_TW_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_tw\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_CN , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_cn\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_CN_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_cn\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_CN_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_cn\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ZH_CN_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\zh_cn\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_UK_UA , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\uk_ua\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_UK_UA_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\uk_ua\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_UK_UA_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\uk_ua\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_UK_UA_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\uk_ua\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_TR_TR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\tr_tr\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_TR_TR_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\tr_tr\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_TR_TR_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\tr_tr\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_TR_TR_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\tr_tr\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SV_SE , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sv_se\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SV_SE_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sv_se\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SV_SE_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sv_se\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SV_SE_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sv_se\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SL_SI , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sl_si\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SL_SI_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sl_si\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SL_SI_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sl_si\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SL_SI_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sl_si\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SK_SK , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sk_sk\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SK_SK_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sk_sk\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SK_SK_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sk_sk\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_SK_SK_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\sk_sk\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RU_RU , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ru_ru\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RU_RU_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ru_ru\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RU_RU_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ru_ru\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RU_RU_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ru_ru\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RO_RO , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ro_ro\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RO_RO_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ro_ro\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RO_RO_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ro_ro\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_RO_RO_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ro_ro\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PT_BR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pt_br\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PT_BR_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pt_br\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PT_BR_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pt_br\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PT_BR_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pt_br\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PL_PL , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pl_pl\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PL_PL_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pl_pl\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PL_PL_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pl_pl\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_PL_PL_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\pl_pl\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NL_NL , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nl_nl\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NL_NL_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nl_nl\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NL_NL_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nl_nl\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NL_NL_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nl_nl\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NB_NO , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nb_no\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NB_NO_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nb_no\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NB_NO_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nb_no\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_NB_NO_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\nb_no\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_KO_KR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ko_kr\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_KO_KR_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ko_kr\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_KO_KR_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ko_kr\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_KO_KR_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ko_kr\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_JA_JP , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ja_jp\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_JA_JP_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ja_jp\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_JA_JP_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ja_jp\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_JA_JP_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ja_jp\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_IT_IT , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\it_it\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_IT_IT_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\it_it\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_IT_IT_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\it_it\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_IT_IT_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\it_it\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HU_HU , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hu_hu\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HU_HU_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hu_hu\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HU_HU_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hu_hu\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HU_HU_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hu_hu\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HR_HR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hr_hr\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HR_HR_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hr_hr\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HR_HR_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hr_hr\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_HR_HR_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\hr_hr\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FR_FR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fr_fr\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FR_FR_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fr_fr\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FR_FR_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fr_fr\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FR_FR_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fr_fr\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FI_FI , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fi_fi\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FI_FI_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fi_fi\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FI_FI_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fi_fi\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_FI_FI_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\fi_fi\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EU_ES , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\eu_ES\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EU_ES_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\eu_ES\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EU_ES_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\eu_ES\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EU_ES_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\eu_ES\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ES_ES , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\es_es\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ES_ES_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\es_es\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ES_ES_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\es_es\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_ES_ES_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\es_es\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EN_US , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\en_us\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EN_US_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\en_us\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EN_US_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\en_us\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_EN_US_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\en_us\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DE_DE , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\de_de\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DE_DE_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\de_de\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DE_DE_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\de_de\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DE_DE_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\de_de\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DA_DK , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\da_dk\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DA_DK_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\da_dk\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DA_DK_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\da_dk\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_DA_DK_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\da_dk\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CS_CZ , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\cs_cz\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CS_CZ_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\cs_cz\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CS_CZ_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\cs_cz\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CS_CZ_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\cs_cz\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CA_ES , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ca_es\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CA_ES_RDR , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ca_es\reader\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CA_ES_RDRX , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ca_es\reader\X\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ONLINE_HELP_CA_ES_RDRX_USING , Object: C:\Apps\ , LongSubPath: Common\Adobe\Help\ca_es\reader\X\using\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_UKR , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\uk_UA\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_TUR , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\tr_TR\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_SVE , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\sv_SE\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_SUO , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\fi_FI\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_SLV , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\sl_SI\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_SKY , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\sk_SK\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_RUS , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\ru_RU\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_RUM , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\ro_RO\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_PTB , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\pt_BR\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_POL , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\pl_PL\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_NOR , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\nb_NO\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_NLD , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\nl_NL\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_KOR , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\ko_KR\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_JPN , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\ja_JP\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_ITA , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\it_IT\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_HUN , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\hu_HU\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_HRV , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\hr_HR\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_FRA , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\fr_FR\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_EUQ , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\eu_ES\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_ESP , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\es_ES\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_ENU , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\en_US\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_DEU , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\de_DE\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_DAN , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\da_DK\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_CZE , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\cs_CZ\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_CHT , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\zh_TW\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_CHS , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\zh_CN\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: COMMON_ADOBE_HELP_CAT , Object: C:\Apps\ , LongSubPath: Common\Adobe\HelpCfg\ca_ES\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ARM , Object: C:\Apps\ , LongSubPath: Common\Adobe\ARM\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ARM_1.0 , Object: C:\Apps\ , LongSubPath: Common\Adobe\ARM\1.0\ , ShortSubPath:
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ADOBE_COMMON_ACROBAT , Object: C:\Apps\ , LongSubPath: Common\Adobe\Acrobat\ , ShortSubPath: Common\Adobe\ACROBA~1\
                                      MSI (c) (40:D0) [13:53:18:011]: Dir (source): Key: ACTIVE_X , Object: C:\Apps\ , LongSubPath: Common\Adobe\Acrobat\ActiveX\ , ShortSubPath: Common\Adobe\ACROBA~1\ActiveX\
                                      Action ended 13:53:18: ResolveSource. Return value 1.
                                      MSI (c) (40:D0) [13:53:18:011]: Doing action: CostFinalize
                                      Action 13:53:18: CostFinalize. Computing space requirements
                                      Action start 13:53:18: CostFinalize.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
                                      MSI (c) (40:D0) [13:53:18:011]: Note: 1: 2205 2:  3: Patch
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding WinSxsDirectory.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_94 7B287C203A property. Its value is 'C:\Windows\winsxs\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding WinSxsPolicies.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947 B287C203A property. Its value is 'C:\Windows\winsxs\Policies\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding policydir.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287C 203A property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353 f75\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding payload_ul.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287 C203A property. Its value is 'C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_60 a5df56e60dc5df\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding WinSxsDirectory.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding policydir_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding WinSxsPolicies.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\Policies\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding policydir.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding WinSxsManifests.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\Manifests\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding payload.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding payload_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_bcb86ed6ac711 f91\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding System64Folder property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ProgramFiles64Folder property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PrimaryVolumePath property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding GlobalAssemblyCache property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding CommonFiles64Folder property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ALLUSERS_APPDATA_ADOBE property. Its value is 'C:\ProgramData\Adobe\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ALLUSERS_APPDATA_ADOBE_ACROBAT property. Its value is 'C:\ProgramData\Adobe\Acrobat\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ALLUSERS_APPDATA_ADOBE_ACROBAT_9 property. Its value is 'C:\ProgramData\Adobe\Acrobat\10.0\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE property. Its value is 'C:\ProgramData\Adobe\Acrobat\10.0\Replicate\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY property. Its value is 'C:\ProgramData\Adobe\Acrobat\10.0\Replicate\Security\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ADOBE property. Its value is 'C:\Program Files\Adobe\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding READER_9.0 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding ESL_DIR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Esl\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding RESOURCE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT_UNICODE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT_UNICODE_MAPPINGS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT_UNICODE_MAPPINGS_WIN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\win\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT_UNICODE_MAPPINGS_MAC property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Mac\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT_UNICODE_MAPPINGS_ADOBE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Adobe\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TYPESPT_UNICODE_ICU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\ICU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SASIPREP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\SaslPrep\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding FONT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Font\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PFM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Font\PFM\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding COMMON_LINGUISTIC property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding COMMON_LINGUISTIC_LANGUAGENAMES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\LanguageNames2\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding COMMON_ADOBE_PROVIDERS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding COMMON_ADOBE_PROVIDERS_PROXIMITY property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding COMMON_ADOBE_PROVIDERS_PROXIMITY_1100 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding COMMON_ADOBE_PROVIDERS_PROXIMITY_1100_NCL3S4PNTX property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\NC-L3S4PNTX\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding CMAP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\CMap\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding CIDFONT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Resource\CIDFont\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding CACHE_SETUP_FILES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Setup Files\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding CACHE_DIR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding READER property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding TRACKER property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Tracker\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SPPLUGINS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\SPPlugins\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PLUGINS_3D property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PLUGINS_3D_PRC property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\prc\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding NETSCAPE_4 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding NETSCAPE_3 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_8 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_7 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_6 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_5 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_4 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_3 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_2 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding MOZILLA_1 property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_ZH_TW property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_ZH_TW property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_ZH_CN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_ZH_CN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_UK_UA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_UK_UA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_TR_TR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_TR_TR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_SV_SE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_SV_SE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_SL_SI property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_SL_SI property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_SK_SK property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_SK_SK property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_RU_RU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_RU_RU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_RO_RO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_RO_RO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_PT_BR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_PT_BR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_PL_PL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_PL_PL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_NL_NL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_NL_NL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_NB_NO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_NB_NO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_KO_KR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_KO_KR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_JA_JP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_JA_JP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_IT_IT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_IT_IT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_HU_HU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_HU_HU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_HR_HR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_HR_HR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_FR_FR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_FR_FR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_FI_FI property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_FI_FI property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_EU_ES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_EU_ES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_ES_ES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_ES_ES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_DE_DE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_DE_DE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_DA_DK property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_DA_DK property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_CS_CZ property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_CS_CZ property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LOCALE_CA_ES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding SERVICES_CA_ES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\Services\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_UKR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\UKR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_TUR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\TUR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_SVE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SVE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_SUO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SUO\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_SLV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SLV\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_SKY property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SKY\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_RUS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUS\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_RUM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUM\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_PTB property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\PTB\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_POL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\POL\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_NOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NOR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_NLD property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NLD\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_KOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\KOR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_JPN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\JPN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_ITA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ITA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_HUN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HUN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_HRV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HRV\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_FRA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\FRA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_EUQ property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\EUQ\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_ESP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ESP\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_ENU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ENU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_DEU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DEU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_DAN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DAN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_CZE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CZE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_CHT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHT\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_CHS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHS\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding LEGAL_CAT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CAT\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding JAVASCRIPTS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Javascripts\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_UKR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\UKR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_TUR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\TUR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_SVE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SVE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_SUO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SUO\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_SLV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SLV\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_SKY property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SKY\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_RUS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUS\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_RUM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUM\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_PTB property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\PTB\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_POL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\POL\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_NOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NOR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_NLD property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NLD\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_KOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\KOR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_JPN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\JPN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_ITA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ITA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_HUN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HUN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_HRV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HRV\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_FRA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\FRA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_EUQ property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\EUQ\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_ESP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ESP\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_ENU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ENU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_DEU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DEU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_DAN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DAN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_CZE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CZE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_CHT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHT\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_CHS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHS\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding IDTEMPLATES_CAT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CAT\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_UKR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\UKR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_TUR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\TUR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_SVE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SVE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_SUO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SUO\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_SLV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SLV\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_SKY property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SKY\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_RUS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUS\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_RUM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUM\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_PTB property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\PTB\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_POL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\POL\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_NOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NOR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_NLD property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NLD\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_KOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\KOR\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_JPN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\JPN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_ITA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ITA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_HUN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HUN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_HRV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HRV\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_FRA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\FRA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_ESP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ESP\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_ENU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ENU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_DEU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DEU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_DAN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DAN\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_CZE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CZE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_CHT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHT\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding DOCSETTINGS_PORTFOLIO_CHS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHS\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding BROWSER_IE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding BROWSER property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\Browser\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding PLUG_INS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_SVE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\SVE\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_NLD property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\NLD\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_ITA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ITA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_FRA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\FRA\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_ESP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ESP\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_ENU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ENU\'.
                                      MSI (c) (40:D0) [13:53:18:011]: PROPERTY CHANGE: Adding VDKHOME_DEU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\DEU\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding PLUG_INS_ACROFORM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding PLUG_INS_ACROFORM_PMP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\PMP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_SVE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_SUO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_PTB property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_NOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_NLD property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_KOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_JAPN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_ITA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_FRA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_EUQ property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_ESP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_DEU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_DAN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_CHT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_CHS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MULTIMEDIA_MPP_CAT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_UKR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_UKR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_TUR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_TUR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_SLV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SLV\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_SKY property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SKY\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_RUS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUS\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_RUM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUM\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_POL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_POL\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_HUN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HUN\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_HRV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HRV\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP_CZE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_CZE\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding MPP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ANNOTATIONS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_UKR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\UKR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_TUR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\TUR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_SVE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SVE\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_SUO property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SUO\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_SLV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SLV\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_SKY property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SKY\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_RUS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUS\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_RUM property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUM\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_PTB property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\PTB\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_POL property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\POL\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_NOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NOR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_NLD property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NLD\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_KOR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\KOR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_JPN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\JPN\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_ITA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ITA\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_HUN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HUN\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_HRV property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HRV\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_FRA property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\FRA\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_EUQ property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\EUQ\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_ESP property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ESP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_ENU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ENU\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_DEU property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DEU\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_DAN property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DAN\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_CZE property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CZE\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_CHT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHT\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_CHS property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHS\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding STAMP_CAT property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CAT\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding AIR property. Its value is 'C:\Program Files\Adobe\Reader 10.0\Reader\AIR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ADOBE_COMMON property. Its value is 'C:\Program Files\Common Files\Adobe\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP property. Its value is 'C:\Program Files\Common Files\Adobe\Help\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_TW property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_tw\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_TW_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_TW_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_TW_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_CN property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_cn\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_CN_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_CN_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ZH_CN_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_UK_UA property. Its value is 'C:\Program Files\Common Files\Adobe\Help\uk_ua\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_UK_UA_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_UK_UA_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_UK_UA_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_TR_TR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\tr_tr\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_TR_TR_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_TR_TR_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_TR_TR_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SV_SE property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sv_se\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SV_SE_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sv_se\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SV_SE_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SV_SE_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SL_SI property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sl_si\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SL_SI_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sl_si\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SL_SI_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SL_SI_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SK_SK property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sk_sk\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SK_SK_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SK_SK_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_SK_SK_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RU_RU property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ru_ru\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RU_RU_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RU_RU_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RU_RU_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RO_RO property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ro_ro\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RO_RO_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RO_RO_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_RO_RO_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PT_BR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pt_br\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PT_BR_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pt_br\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PT_BR_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PT_BR_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PL_PL property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pl_pl\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PL_PL_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PL_PL_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_PL_PL_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NL_NL property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nl_nl\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NL_NL_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NL_NL_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NL_NL_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NB_NO property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nb_no\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NB_NO_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nb_no\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NB_NO_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_NB_NO_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_KO_KR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ko_kr\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_KO_KR_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_KO_KR_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_KO_KR_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_JA_JP property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ja_jp\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_JA_JP_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_JA_JP_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_JA_JP_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_IT_IT property. Its value is 'C:\Program Files\Common Files\Adobe\Help\it_it\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_IT_IT_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\it_it\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_IT_IT_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_IT_IT_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HU_HU property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hu_hu\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HU_HU_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HU_HU_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HU_HU_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HR_HR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hr_hr\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HR_HR_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HR_HR_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_HR_HR_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FR_FR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fr_fr\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FR_FR_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FR_FR_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FR_FR_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FI_FI property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fi_fi\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FI_FI_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FI_FI_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_FI_FI_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EU_ES property. Its value is 'C:\Program Files\Common Files\Adobe\Help\eu_ES\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EU_ES_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EU_ES_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EU_ES_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ES_ES property. Its value is 'C:\Program Files\Common Files\Adobe\Help\es_es\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ES_ES_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\es_es\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ES_ES_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_ES_ES_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EN_US property. Its value is 'C:\Program Files\Common Files\Adobe\Help\en_us\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EN_US_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\en_us\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EN_US_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_EN_US_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DE_DE property. Its value is 'C:\Program Files\Common Files\Adobe\Help\de_de\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DE_DE_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\de_de\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DE_DE_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DE_DE_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DA_DK property. Its value is 'C:\Program Files\Common Files\Adobe\Help\da_dk\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DA_DK_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\da_dk\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DA_DK_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_DA_DK_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CS_CZ property. Its value is 'C:\Program Files\Common Files\Adobe\Help\cs_cz\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CS_CZ_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CS_CZ_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CS_CZ_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CA_ES property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ca_es\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CA_ES_RDR property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ca_es\reader\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CA_ES_RDRX property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ONLINE_HELP_CA_ES_RDRX_USING property. Its value is 'C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\using\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_UKR property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\uk_UA\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_TUR property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\tr_TR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_SVE property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\sv_SE\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_SUO property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\fi_FI\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_SLV property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\sl_SI\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_SKY property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\sk_SK\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_RUS property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\ru_RU\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_RUM property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\ro_RO\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_PTB property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\pt_BR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_POL property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\pl_PL\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_NOR property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\nb_NO\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_NLD property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\nl_NL\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_KOR property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\ko_KR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_JPN property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\ja_JP\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_ITA property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\it_IT\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_HUN property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\hu_HU\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_HRV property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\hr_HR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_FRA property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\fr_FR\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_EUQ property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\eu_ES\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_ESP property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\es_ES\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_ENU property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\en_US\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_DEU property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\de_DE\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_DAN property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\da_DK\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_CZE property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\cs_CZ\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_CHT property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\zh_TW\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_CHS property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\zh_CN\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding COMMON_ADOBE_HELP_CAT property. Its value is 'C:\Program Files\Common Files\Adobe\HelpCfg\ca_ES\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ARM property. Its value is 'C:\Program Files\Common Files\Adobe\ARM\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ARM_1.0 property. Its value is 'C:\Program Files\Common Files\Adobe\ARM\1.0\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ADOBE_COMMON_ACROBAT property. Its value is 'C:\Program Files\Common Files\Adobe\Acrobat\'.
                                      MSI (c) (40:D0) [13:53:18:027]: PROPERTY CHANGE: Adding ACTIVE_X property. Its value is 'C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\'.
                                      MSI (c) (40:D0) [13:53:18:027]: Target path resolution complete. Dumping Directory table...
                                      MSI (c) (40:D0) [13:53:18:027]: Note: target paths subject to change (via custom actions or browsing)
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TARGETDIR , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SourceDirCustom , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ACROFORM , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: EXERLOGS , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: AcrobatAppData , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CACHE , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COLLAB , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MESSAGES , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PREFERENCES , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PRINTME_STARTMENU_INTERNETPRINTING , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: UPDATERAPPDATA , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AdobeAppData , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAdobeAcrobat , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAcrobatVersion , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAcrobatVersionCache , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAcrobatVersionForms , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: AdobeAppData , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAcrobatVersionPrefs , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAcrobatVersionUpdater , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAdobe , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_LocalAppDataAdobe , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_LocalAppDataAdobeAcrobat , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_LocalAppDataAdobeAcrobatVer , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_LocalAppDataAdobeAcrobatVerCache , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_LocalAppDataAdobeAcrobatVerCacheSearch , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: U_AppDataAcrobatVersionCollaboration , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: printme_startmenu_internetprinting , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: AcrobatAppData_8 , Object: NULL
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A , Object: C:\Windows\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WinSxsDirectory.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_94 7B287C203A , Object: C:\Windows\winsxs\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WinSxsPolicies.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947 B287C203A , Object: C:\Windows\winsxs\Policies\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: policydir.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287C 203A , Object: C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f 75\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: payload_ul.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287 C203A , Object: C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_60a 5df56e60dc5df\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WinSxsDirectory.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: policydir_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WinSxsPolicies.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\Policies\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: policydir.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WinSxsManifests.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\Manifests\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: payload.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: payload_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_bcb86ed6ac711f 91\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 , Object: C:\Windows\system32\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WindowsVolume , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: USERPROFILE , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TemplateFolder , Object: C:\ProgramData\Microsoft\Windows\Templates\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TempFolder , Object: C:\Users\LOCALA~1\AppData\Local\Temp\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SystemFolder , Object: C:\Windows\system32\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: System64Folder , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: System16Folder , Object: C:\Windows\system\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: StartupFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: StartMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SendToFolder , Object: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\SendTo\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ProgramMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ProgramFiles64Folder , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PrimaryVolumePath , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PersonalFolder , Object: C:\Users\LocalAdmin\Documents\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MyPicturesFolder , Object: C:\Users\LocalAdmin\Pictures\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LocalAppDataFolder , Object: C:\Users\LocalAdmin\AppData\Local\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: GlobalAssemblyCache , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: FontsFolder , Object: C:\Windows\Fonts\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: FavoritesFolder , Object: C:\Users\LocalAdmin\Favorites\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DesktopFolder , Object: C:\Users\Public\Desktop\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CommonFiles64Folder , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: AppDataFolder , Object: C:\Users\LocalAdmin\AppData\Roaming\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: AdminToolsFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CommonAppDataFolder , Object: C:\ProgramData\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ALLUSERS_APPDATA_ADOBE , Object: C:\ProgramData\Adobe\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT , Object: C:\ProgramData\Adobe\Acrobat\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT_9 , Object: C:\ProgramData\Adobe\Acrobat\10.0\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE , Object: C:\ProgramData\Adobe\Acrobat\10.0\Replicate\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY , Object: C:\ProgramData\Adobe\Acrobat\10.0\Replicate\Security\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ADOBE , Object: C:\Program Files\Adobe\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: READER_9.0 , Object: C:\Program Files\Adobe\Reader 10.0\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: INSTALLDIR , Object: C:\Program Files\Adobe\Reader 10.0\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ESL_DIR , Object: C:\Program Files\Adobe\Reader 10.0\Esl\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: RESOURCE , Object: C:\Program Files\Adobe\Reader 10.0\Resource\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT_UNICODE , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT_UNICODE_MAPPINGS , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT_UNICODE_MAPPINGS_WIN , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\win\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT_UNICODE_MAPPINGS_MAC , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Mac\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT_UNICODE_MAPPINGS_ADOBE , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Adobe\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TYPESPT_UNICODE_ICU , Object: C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\ICU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SASIPREP , Object: C:\Program Files\Adobe\Reader 10.0\Resource\SaslPrep\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: FONT , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Font\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PFM , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Font\PFM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_LINGUISTIC , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_LINGUISTIC_LANGUAGENAMES , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\LanguageNames2\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_PROVIDERS , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_PROVIDERS_PROXIMITY , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_PROVIDERS_PROXIMITY_1100 , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_PROVIDERS_PROXIMITY_1100_NCL3S4PNTX , Object: C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\NC-L3S4PNTX\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CMAP , Object: C:\Program Files\Adobe\Reader 10.0\Resource\CMap\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CIDFONT , Object: C:\Program Files\Adobe\Reader 10.0\Resource\CIDFont\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CACHE_SETUP_FILES , Object: C:\Program Files\Adobe\Reader 10.0\Setup Files\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CACHE_DIR , Object: C:\Program Files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: READER , Object: C:\Program Files\Adobe\Reader 10.0\Reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: TRACKER , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Tracker\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SPPLUGINS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\SPPlugins\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PLUGINS_3D , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PLUGINS_3D_PRC , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\prc\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: NETSCAPE_4 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: NETSCAPE_3 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_8 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_7 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_6 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_5 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_4 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_3 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_2 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MOZILLA_1 , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_ZH_TW , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_ZH_TW , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_ZH_CN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_ZH_CN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_UK_UA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_UK_UA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_TR_TR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_TR_TR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_SV_SE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_SV_SE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_SL_SI , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_SL_SI , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_SK_SK , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_SK_SK , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_RU_RU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_RU_RU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_RO_RO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_RO_RO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_PT_BR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_PT_BR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_PL_PL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_PL_PL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_NL_NL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_NL_NL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_NB_NO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_NB_NO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_KO_KR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_KO_KR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_JA_JP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_JA_JP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_IT_IT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_IT_IT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_HU_HU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_HU_HU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_HR_HR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_HR_HR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_FR_FR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_FR_FR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_FI_FI , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_FI_FI , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_EU_ES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_EU_ES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_ES_ES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_ES_ES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_DE_DE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_DE_DE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_DA_DK , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_DA_DK , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_CS_CZ , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_CS_CZ , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LOCALE_CA_ES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: SERVICES_CA_ES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\Services\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_UKR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\UKR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_TUR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\TUR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_SVE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SVE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_SUO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SUO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_SLV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SLV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_SKY , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SKY\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_RUS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_RUM , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_PTB , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\PTB\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_POL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\POL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_NOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_NLD , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NLD\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_KOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\KOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_JPN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\JPN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_ITA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ITA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_HUN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HUN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_HRV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HRV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_FRA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\FRA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_EUQ , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\EUQ\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_ESP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ESP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_ENU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ENU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_DEU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DEU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_DAN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DAN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_CZE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CZE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_CHT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_CHS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: LEGAL_CAT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CAT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: JAVASCRIPTS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Javascripts\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_UKR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\UKR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_TUR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\TUR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_SVE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SVE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_SUO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SUO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_SLV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SLV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_SKY , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SKY\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_RUS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_RUM , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_PTB , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\PTB\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_POL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\POL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_NOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_NLD , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NLD\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_KOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\KOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_JPN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\JPN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_ITA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ITA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_HUN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HUN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_HRV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HRV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_FRA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\FRA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_EUQ , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\EUQ\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_ESP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ESP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_ENU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ENU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_DEU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DEU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_DAN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DAN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_CZE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CZE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_CHT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_CHS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: IDTEMPLATES_CAT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CAT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_UKR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\UKR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_TUR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\TUR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_SVE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SVE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_SUO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SUO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_SLV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SLV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_SKY , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SKY\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_RUS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_RUM , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_PTB , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\PTB\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_POL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\POL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_NOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_NLD , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NLD\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_KOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\KOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_JPN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\JPN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_ITA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ITA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_HUN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HUN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_HRV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HRV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_FRA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\FRA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_ESP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ESP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_ENU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ENU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_DEU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DEU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_DAN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DAN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_CZE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CZE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_CHT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: DOCSETTINGS_PORTFOLIO_CHS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: BROWSER_IE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: BROWSER , Object: C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PLUG_INS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_SVE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\SVE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_NLD , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\NLD\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_ITA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ITA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_FRA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\FRA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_ESP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ESP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_ENU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ENU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: VDKHOME_DEU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\DEU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PLUG_INS_ACROFORM , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: PLUG_INS_ACROFORM_PMP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\PMP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_SVE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_SUO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_PTB , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_NOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_NLD , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_KOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_JAPN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_ITA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_FRA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_EUQ , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_ESP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_DEU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_DAN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_CHT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_CHS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MULTIMEDIA_MPP_CAT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_UKR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_UKR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_TUR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_TUR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_SLV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SLV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_SKY , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SKY\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_RUS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_RUM , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_POL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_POL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_HUN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HUN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_HRV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HRV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP_CZE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_CZE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: MPP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ANNOTATIONS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_UKR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\UKR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_TUR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\TUR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_SVE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SVE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_SUO , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SUO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_SLV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SLV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_SKY , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SKY\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_RUS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_RUM , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_PTB , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\PTB\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_POL , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\POL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_NOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_NLD , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NLD\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_KOR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\KOR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_JPN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\JPN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_ITA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ITA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_HUN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HUN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_HRV , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HRV\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_FRA , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\FRA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_EUQ , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\EUQ\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_ESP , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ESP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_ENU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ENU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_DEU , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DEU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_DAN , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DAN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_CZE , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CZE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_CHT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_CHS , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHS\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: STAMP_CAT , Object: C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CAT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: AIR , Object: C:\Program Files\Adobe\Reader 10.0\Reader\AIR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files\Common Files\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ADOBE_COMMON , Object: C:\Program Files\Common Files\Adobe\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP , Object: C:\Program Files\Common Files\Adobe\Help\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_TW , Object: C:\Program Files\Common Files\Adobe\Help\zh_tw\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_TW_RDR , Object: C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_TW_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_TW_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_CN , Object: C:\Program Files\Common Files\Adobe\Help\zh_cn\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_CN_RDR , Object: C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_CN_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ZH_CN_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_UK_UA , Object: C:\Program Files\Common Files\Adobe\Help\uk_ua\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_UK_UA_RDR , Object: C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_UK_UA_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_UK_UA_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_TR_TR , Object: C:\Program Files\Common Files\Adobe\Help\tr_tr\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_TR_TR_RDR , Object: C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_TR_TR_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_TR_TR_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SV_SE , Object: C:\Program Files\Common Files\Adobe\Help\sv_se\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SV_SE_RDR , Object: C:\Program Files\Common Files\Adobe\Help\sv_se\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SV_SE_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SV_SE_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SL_SI , Object: C:\Program Files\Common Files\Adobe\Help\sl_si\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SL_SI_RDR , Object: C:\Program Files\Common Files\Adobe\Help\sl_si\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SL_SI_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SL_SI_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SK_SK , Object: C:\Program Files\Common Files\Adobe\Help\sk_sk\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SK_SK_RDR , Object: C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SK_SK_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_SK_SK_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RU_RU , Object: C:\Program Files\Common Files\Adobe\Help\ru_ru\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RU_RU_RDR , Object: C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RU_RU_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RU_RU_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RO_RO , Object: C:\Program Files\Common Files\Adobe\Help\ro_ro\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RO_RO_RDR , Object: C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RO_RO_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_RO_RO_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PT_BR , Object: C:\Program Files\Common Files\Adobe\Help\pt_br\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PT_BR_RDR , Object: C:\Program Files\Common Files\Adobe\Help\pt_br\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PT_BR_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PT_BR_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PL_PL , Object: C:\Program Files\Common Files\Adobe\Help\pl_pl\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PL_PL_RDR , Object: C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PL_PL_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_PL_PL_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NL_NL , Object: C:\Program Files\Common Files\Adobe\Help\nl_nl\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NL_NL_RDR , Object: C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NL_NL_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NL_NL_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NB_NO , Object: C:\Program Files\Common Files\Adobe\Help\nb_no\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NB_NO_RDR , Object: C:\Program Files\Common Files\Adobe\Help\nb_no\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NB_NO_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_NB_NO_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_KO_KR , Object: C:\Program Files\Common Files\Adobe\Help\ko_kr\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_KO_KR_RDR , Object: C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_KO_KR_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_KO_KR_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_JA_JP , Object: C:\Program Files\Common Files\Adobe\Help\ja_jp\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_JA_JP_RDR , Object: C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_JA_JP_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_JA_JP_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_IT_IT , Object: C:\Program Files\Common Files\Adobe\Help\it_it\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_IT_IT_RDR , Object: C:\Program Files\Common Files\Adobe\Help\it_it\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_IT_IT_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_IT_IT_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HU_HU , Object: C:\Program Files\Common Files\Adobe\Help\hu_hu\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HU_HU_RDR , Object: C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HU_HU_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HU_HU_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HR_HR , Object: C:\Program Files\Common Files\Adobe\Help\hr_hr\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HR_HR_RDR , Object: C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HR_HR_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_HR_HR_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FR_FR , Object: C:\Program Files\Common Files\Adobe\Help\fr_fr\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FR_FR_RDR , Object: C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FR_FR_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FR_FR_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FI_FI , Object: C:\Program Files\Common Files\Adobe\Help\fi_fi\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FI_FI_RDR , Object: C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FI_FI_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_FI_FI_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EU_ES , Object: C:\Program Files\Common Files\Adobe\Help\eu_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EU_ES_RDR , Object: C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EU_ES_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EU_ES_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ES_ES , Object: C:\Program Files\Common Files\Adobe\Help\es_es\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ES_ES_RDR , Object: C:\Program Files\Common Files\Adobe\Help\es_es\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ES_ES_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_ES_ES_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EN_US , Object: C:\Program Files\Common Files\Adobe\Help\en_us\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EN_US_RDR , Object: C:\Program Files\Common Files\Adobe\Help\en_us\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EN_US_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_EN_US_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DE_DE , Object: C:\Program Files\Common Files\Adobe\Help\de_de\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DE_DE_RDR , Object: C:\Program Files\Common Files\Adobe\Help\de_de\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DE_DE_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DE_DE_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DA_DK , Object: C:\Program Files\Common Files\Adobe\Help\da_dk\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DA_DK_RDR , Object: C:\Program Files\Common Files\Adobe\Help\da_dk\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DA_DK_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_DA_DK_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CS_CZ , Object: C:\Program Files\Common Files\Adobe\Help\cs_cz\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CS_CZ_RDR , Object: C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CS_CZ_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CS_CZ_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CA_ES , Object: C:\Program Files\Common Files\Adobe\Help\ca_es\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CA_ES_RDR , Object: C:\Program Files\Common Files\Adobe\Help\ca_es\reader\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CA_ES_RDRX , Object: C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ONLINE_HELP_CA_ES_RDRX_USING , Object: C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\using\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP , Object: C:\Program Files\Common Files\Adobe\HelpCfg\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_UKR , Object: C:\Program Files\Common Files\Adobe\HelpCfg\uk_UA\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_TUR , Object: C:\Program Files\Common Files\Adobe\HelpCfg\tr_TR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_SVE , Object: C:\Program Files\Common Files\Adobe\HelpCfg\sv_SE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_SUO , Object: C:\Program Files\Common Files\Adobe\HelpCfg\fi_FI\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_SLV , Object: C:\Program Files\Common Files\Adobe\HelpCfg\sl_SI\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_SKY , Object: C:\Program Files\Common Files\Adobe\HelpCfg\sk_SK\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_RUS , Object: C:\Program Files\Common Files\Adobe\HelpCfg\ru_RU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_RUM , Object: C:\Program Files\Common Files\Adobe\HelpCfg\ro_RO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_PTB , Object: C:\Program Files\Common Files\Adobe\HelpCfg\pt_BR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_POL , Object: C:\Program Files\Common Files\Adobe\HelpCfg\pl_PL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_NOR , Object: C:\Program Files\Common Files\Adobe\HelpCfg\nb_NO\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_NLD , Object: C:\Program Files\Common Files\Adobe\HelpCfg\nl_NL\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_KOR , Object: C:\Program Files\Common Files\Adobe\HelpCfg\ko_KR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_JPN , Object: C:\Program Files\Common Files\Adobe\HelpCfg\ja_JP\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_ITA , Object: C:\Program Files\Common Files\Adobe\HelpCfg\it_IT\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_HUN , Object: C:\Program Files\Common Files\Adobe\HelpCfg\hu_HU\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_HRV , Object: C:\Program Files\Common Files\Adobe\HelpCfg\hr_HR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_FRA , Object: C:\Program Files\Common Files\Adobe\HelpCfg\fr_FR\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_EUQ , Object: C:\Program Files\Common Files\Adobe\HelpCfg\eu_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_ESP , Object: C:\Program Files\Common Files\Adobe\HelpCfg\es_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_ENU , Object: C:\Program Files\Common Files\Adobe\HelpCfg\en_US\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_DEU , Object: C:\Program Files\Common Files\Adobe\HelpCfg\de_DE\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_DAN , Object: C:\Program Files\Common Files\Adobe\HelpCfg\da_DK\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_CZE , Object: C:\Program Files\Common Files\Adobe\HelpCfg\cs_CZ\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_CHT , Object: C:\Program Files\Common Files\Adobe\HelpCfg\zh_TW\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_CHS , Object: C:\Program Files\Common Files\Adobe\HelpCfg\zh_CN\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: COMMON_ADOBE_HELP_CAT , Object: C:\Program Files\Common Files\Adobe\HelpCfg\ca_ES\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ARM , Object: C:\Program Files\Common Files\Adobe\ARM\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ARM_1.0 , Object: C:\Program Files\Common Files\Adobe\ARM\1.0\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ADOBE_COMMON_ACROBAT , Object: C:\Program Files\Common Files\Adobe\Acrobat\
                                      MSI (c) (40:D0) [13:53:18:027]: Dir (target): Key: ACTIVE_X , Object: C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\
                                      MSI (c) (40:D0) [13:53:18:058]: skipping installation of assembly component: {14F2B62D-DF5F-335F-A517-0991F44CB087} since the assembly already exists
                                      MSI (c) (40:D0) [13:53:18:058]: skipping installation of assembly component: {B708EB72-AA82-3EB7-8BB0-D845BA35C93D} since the assembly already exists
                                      MSI (c) (40:D0) [13:53:18:105]: Disallowing installation of component: {011F7ED1-AAFA-4C09-8990-CB4CC522CC7B} since the same component with higher versioned keyfile exists
                                      MSI (c) (40:D0) [13:53:18:120]: Disallowing installation of component: {E4B0AE7E-2D75-44DD-96E1-1F77E51721A8} since the same component with higher versioned keyfile exists
                                      Action ended 13:53:18: CostFinalize. Return value 1.
                                      MSI (c) (40:D0) [13:53:18:167]: Doing action: SetARPReadme
                                      Action 13:53:18: SetARPReadme.
                                      Action start 13:53:18: SetARPReadme.
                                      MSI (c) (40:D0) [13:53:18:167]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetARPReadme'
                                      Action ended 13:53:18: SetARPReadme. Return value 1.
                                      MSI (c) (40:D0) [13:53:18:167]: Doing action: SetARPReadmeEx
                                      Action 13:53:18: SetARPReadmeEx.
                                      Action start 13:53:18: SetARPReadmeEx.
                                      MSI (c) (40:D0) [13:53:18:167]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetARPReadmeEx'
                                      MSI (c) (40:D0) [13:53:18:167]: PROPERTY CHANGE: Modifying ARPREADME property. Its current value is 'Readme.htm'. Its new value: 'C:\Program Files\Adobe\Reader 10.0\Readme.htm'.
                                      Action ended 13:53:18: SetARPReadmeEx. Return value 1.
                                      MSI (c) (40:D0) [13:53:18:167]: Doing action: MigrateFeatureStates
                                      Action 13:53:18: MigrateFeatureStates. Migrating feature states from related applications
                                      Action start 13:53:18: MigrateFeatureStates.
                                      Action ended 13:53:18: MigrateFeatureStates. Return value 0.
                                      MSI (c) (40:D0) [13:53:18:167]: Skipping action: PatchWelcome (condition is false)
                                      MSI (c) (40:D0) [13:53:18:167]: Skipping action: OutOfSpace (condition is false)
                                      MSI (c) (40:D0) [13:53:18:167]: Doing action: DestinationFolder
                                      Action 13:53:18: DestinationFolder.
                                      Action start 13:53:18: DestinationFolder.
                                      MSI (c) (40:D0) [13:53:18:167]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'DestinationFolder'
                                      Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                      Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                      Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                      Info 2826.Control Bitmap1 on dialog DestinationFolder extends beyond the boundaries of the dialog to the right by 8 pixels.
                                      Action 13:53:18: DestinationFolder. Dialog created
                                      MSI (c) (40:5C) [13:53:18:183]: Note: 1: 2205 2:  3: _RemoveFilePath
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: AcrobatAppData_8
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: printme_startmenu_internetprinting
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAcrobatVersionCollaboration
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_LocalAppDataAdobeAcrobatVerCacheSearch
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAdobe
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAcrobatVersionUpdater
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAcrobatVersionPrefs
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: AdobeAppData
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAcrobatVersionForms
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAcrobatVersionCache
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AppDataAdobeAcrobat
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: U_AdobeAppData
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: UPDATERAPPDATA
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: PRINTME_STARTMENU_INTERNETPRINTING
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: PREFERENCES
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: MESSAGES
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: COLLAB
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: CACHE
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: EXERLOGS
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: ACROFORM
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2756 2: SourceDirCustom
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2262 2: Class 3: -2147287038
                                      MSI (c) (40:5C) [13:53:18:245]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2205 2:  3: BindImage
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2205 2:  3: PublishComponent
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2205 2:  3: Font
                                      MSI (c) (40:5C) [13:53:18:245]: Note: 1: 2727 2:
                                      MSI (c) (40:C4) [13:53:18:698]: Note: 1: 2727 2:
                                      MSI (c) (40:C4) [13:53:19:212]: Note: 1: 2727 2:
                                      MSI (c) (40:C4) [13:53:19:727]: Note: 1: 2727 2:
                                      MSI (c) (40:C4) [13:53:20:242]: Note: 1: 2727 2:
                                      MSI (c) (40:C4) [13:53:20:304]: PROPERTY CHANGE: Modifying DEFAULT_VERB property. Its current value is 'Open'. Its new value: 'Read'.
                                      MSI (c) (40:C4) [13:53:20:304]: Doing action: Set_AS_HKCR_EXE
                                      Action 13:53:20: Set_AS_HKCR_EXE.
                                      Action start 13:53:20: Set_AS_HKCR_EXE.
                                      MSI (c) (40:C4) [13:53:20:304]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Set_AS_HKCR_EXE'
                                      Info 2726.Action not found: Set_AS_HKCR_EXE.
                                      Action ended 13:53:20: Set_AS_HKCR_EXE. Return value 0.
                                      Action ended 13:53:20: DestinationFolder. Return value 1.
                                      MSI (c) (40:D0) [13:53:20:304]: Skipping action: MaintenanceType (condition is false)
                                      MSI (c) (40:D0) [13:53:20:304]: Doing action: SetupProgress
                                      Action 13:53:20: SetupProgress.
                                      Action start 13:53:20: SetupProgress.
                                      MSI (c) (40:D0) [13:53:20:304]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetupProgress'
                                      Info 2826.Control Bitmap1 on dialog SetupProgress extends beyond the boundaries of the dialog to the right by 8 pixels.
                                      Action 13:53:20: SetupProgress. Dialog created
                                      Action ended 13:53:20: SetupProgress. Return value 1.
                                      MSI (c) (40:D0) [13:53:20:351]: Doing action: PrepareFilesInUse
                                      Action 13:53:20: PrepareFilesInUse.
                                      Action start 13:53:20: PrepareFilesInUse.
                                      MSI (c) (40:D0) [13:53:20:351]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'PrepareFilesInUse'
                                      MSI (c) (40:D0) [13:53:20:351]: Creating MSIHANDLE (22) of type 790542 for thread 976
                                      MSI (c) (40:0C) [13:53:20:351]: Invoking remote custom action. DLL: C:\Users\LOCALA~1\AppData\Local\Temp\MSI9189.tmp, Entrypoint: PrepareFilesInUseDialog
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (23) of type 790531 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (24) of type 790531 for thread 4076
                                      ADelRCP logging: : Process privilege adjusted.
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (24) of type 790531 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (25) of type 790541 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (26) of type 790540 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (27) of type 790531 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (28) of type 790531 for thread 4076
                                      ADelRCP logging: : Condition not met for AppsInUseEx module entry : AcroRd32dll
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (28) of type 790531 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (27) of type 790531 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (25) of type 790541 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (26) of type 790540 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (29) of type 790541 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Note: 1: 2262 2: AppsInUse 3: -2147287038
                                      MSI (c) (40!EC) [13:53:20:351]: Creating MSIHANDLE (30) of type 790540 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (29) of type 790541 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (30) of type 790540 for thread 4076
                                      MSI (c) (40!EC) [13:53:20:351]: Closing MSIHANDLE (23) of type 790531 for thread 4076
                                      MSI (c) (40:0C) [13:53:20:351]: Closing MSIHANDLE (22) of type 790542 for thread 976
                                      Action ended 13:53:20: PrepareFilesInUse. Return value 1.
                                      MSI (c) (40:D0) [13:53:20:351]: Doing action: ExecuteAction
                                      Action 13:53:20: ExecuteAction.
                                      Action start 13:53:20: ExecuteAction.
                                      MSI (c) (40:D0) [13:53:20:351]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
                                      MSI (c) (40:D0) [13:53:20:351]: Grabbed execution mutex.
                                      MSI (c) (40:D0) [13:53:20:351]: Incrementing counter to disable shutdown. Counter after increment: 0
                                      MSI (c) (40:D0) [13:53:20:382]: Switching to server: ROOTDRIVE="C:\" ACROBAT_APP_PATH="C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe" ADOBE_COMMON_ACROBAT="C:\Program Files\Common Files\Adobe\Acrobat\" ACTIVE_X="C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\" ADOBE="C:\Program Files\Adobe\" ADOBE_COMMON="C:\Program Files\Common Files\Adobe\" AIR="C:\Program Files\Adobe\Reader 10.0\Reader\AIR\" READER="C:\Program Files\Adobe\Reader 10.0\Reader\" TARGETDIR="C:\" ALLUSERSPROFILE="C:\" ALLUSERS_APPDATA_ADOBE="C:\ProgramData\Adobe\" ALLUSERS_APPDATA_ADOBE_ACROBAT="C:\ProgramData\Adobe\Acrobat\" ALLUSERS_APPDATA_ADOBE_ACROBAT_9="C:\ProgramData\Adobe\Acrobat\10.0\" ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE="C:\ProgramData\Adobe\Acrobat\10.0\Replicate\" ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY="C:\ProgramData\Adobe\Acrobat\10.0\Re plicate\Security\" PLUG_INS="C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\" ANNOTATIONS="C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\" ARM="C:\Program Files\Common Files\Adobe\ARM\" ARM_1.0="C:\Program Files\Commo
                                      MSI (s) (80:D8) [13:53:20:382]: Running installation inside multi-package transaction C:\Apps\AdbeRdr1010_en_US.msi
                                      MSI (s) (80:D8) [13:53:20:382]: Grabbed execution mutex.
                                      MSI (s) (80:8C) [13:53:20:382]: Resetting cached policy values
                                      MSI (s) (80:8C) [13:53:20:382]: Machine policy value 'Debug' is 0
                                      MSI (s) (80:8C) [13:53:20:382]: ******* RunEngine:
                                                 ******* Product: C:\Apps\AdbeRdr1010_en_US.msi
                                                 ******* Action: INSTALL
                                                 ******* CommandLine: **********
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'DisableUserInstalls' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 000021599B0090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 000021599B0090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 000041091A0090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 000041091A0090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109510090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109510090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109511090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109511090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109610090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109610090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109711090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109711090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109810090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109810090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109910090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109910090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109A10090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109A10090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109B10090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109B10090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109C20090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109C20090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109D30000000000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109D30000000000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109E60090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109E60090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109F10090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109F10090400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109F100A0C00000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109F100A0C00000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 00004109F100C0400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 00004109F100C0400000000000F01FEC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 032440EF5AC97F34B985A55C2AA8F133
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 032440EF5AC97F34B985A55C2AA8F133
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 076CFAAAB965F2A4284B2449E5D03EFE
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 076CFAAAB965F2A4284B2449E5D03EFE
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 08A6F3A53197E574B86974A759C2AF34
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 08A6F3A53197E574B86974A759C2AF34
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 099A4A9134357FF43B5BF640C690E1FD
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 099A4A9134357FF43B5BF640C690E1FD
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 0F8D0630A62678E4A86139B80DEBCB5C
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 0F8D0630A62678E4A86139B80DEBCB5C
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 11645F391072e45449BA26F354D8E9B6
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 11645F391072e45449BA26F354D8E9B6
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 14704D8AC0940914282F2609891914B4
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 14704D8AC0940914282F2609891914B4
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 154A5AC82690C1B409875A7968F737BE
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 154A5AC82690C1B409875A7968F737BE
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 19416C9AF2FE8DE4E801BF333E6C5BA5
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 19416C9AF2FE8DE4E801BF333E6C5BA5
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 1C79E9FA1347D6248A5DBA4E90590C1B
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 1C79E9FA1347D6248A5DBA4E90590C1B
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 1F20050C8F6051A46B8F4ECD56C582AA
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 1F20050C8F6051A46B8F4ECD56C582AA
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 21BBD9173A783014FBB523FB27750086
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 21BBD9173A783014FBB523FB27750086
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 23A92F3530D753648A3B38D929F1F669
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 23A92F3530D753648A3B38D929F1F669
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 24E9EA15D04641C49A6B346FA44A3E2E
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 24E9EA15D04641C49A6B346FA44A3E2E
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 26CEF00243C306D4C98ECE73E2100CF8
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 26CEF00243C306D4C98ECE73E2100CF8
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 2878E7224F2B79E40BEE94EDC91C0C0C
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 2878E7224F2B79E40BEE94EDC91C0C0C
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 293A837E096FD9A408E8B7FA080E3B89
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 293A837E096FD9A408E8B7FA080E3B89
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 295FE304B3594974CBFECEBA38C50259
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 295FE304B3594974CBFECEBA38C50259
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 29F618052561C7A49BCB846F2847C2B4
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 29F618052561C7A49BCB846F2847C2B4
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 2B51DA16BD0568647A9341EF81D04492
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 2B51DA16BD0568647A9341EF81D04492
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 2D491171AD575944F92004EE64AD40DA
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 2D491171AD575944F92004EE64AD40DA
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 3512A0B06A8544244B8552DE5FCF8D90
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 3512A0B06A8544244B8552DE5FCF8D90
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 389F20921C4BAB448BD5C5D6252E4C14
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 389F20921C4BAB448BD5C5D6252E4C14
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 39581A3AEB261EA4FAF33E1597FC40E2
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 39581A3AEB261EA4FAF33E1597FC40E2
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 3D04254D3B6B9FF42B3445CE3E1E0066
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 3D04254D3B6B9FF42B3445CE3E1E0066
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 3D8CE063E2AA4B24CA25FF9A1A1C1C9E
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 3D8CE063E2AA4B24CA25FF9A1A1C1C9E
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 3e43b73803c7c394f8a6b2f0402e19c2
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 3e43b73803c7c394f8a6b2f0402e19c2
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4314AE291D01A814191EA5403531A183
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4314AE291D01A814191EA5403531A183
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 453E600442D3AB943AF6E77BD5055D57
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 453E600442D3AB943AF6E77BD5055D57
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4A4869755DDD3AC4E98AB77E9D95D34B
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4A4869755DDD3AC4E98AB77E9D95D34B
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4A9D4F432C248434EB4F5E358C54947E
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4A9D4F432C248434EB4F5E358C54947E
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4AF8082622DCB2A4DA0505353E9C6F8F
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4AF8082622DCB2A4DA0505353E9C6F8F
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4B83AF924EA0D0D4A8151656BB99B00B
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4B83AF924EA0D0D4A8151656BB99B00B
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4C00AAA76E620CE4089659B5A0D90690
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4C00AAA76E620CE4089659B5A0D90690
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4DE4057180BD8A04182C728D0C5118AD
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4DE4057180BD8A04182C728D0C5118AD
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4E42866C3BBC1584BBF38EFC6D539032
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4E42866C3BBC1584BBF38EFC6D539032
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120632FF
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120632FF
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 4F9EB6A38CF5BB44EBB7232A6970EF6F
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 4F9EB6A38CF5BB44EBB7232A6970EF6F
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 5438F294D590F76429C67288079DE3FC
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 5438F294D590F76429C67288079DE3FC
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 55565908215A0914C9DA0B003CD6B6B6
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 55565908215A0914C9DA0B003CD6B6B6
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 57BE88642E821374B9BC556E427FDC54
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 57BE88642E821374B9BC556E427FDC54
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 5BE1CA8D0B8E0A441B3198497081A8F2
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 5BE1CA8D0B8E0A441B3198497081A8F2
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 5C1093C35543A0E32A41B090A305076A
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 5C1093C35543A0E32A41B090A305076A
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 5E1EFAEEB670A034699D5B7697A2AF88
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 5E1EFAEEB670A034699D5B7697A2AF88
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 6030E61781384634B8F8C04C9E73B6CA
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 6030E61781384634B8F8C04C9E73B6CA
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 6043B4640D4A419419F0C74A83D0CC31
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 6043B4640D4A419419F0C74A83D0CC31
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 60EA627A3AAA1D34783E075F0113F440
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 60EA627A3AAA1D34783E075F0113F440
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 6116D6C8427B0184F8D20D746E7B6DE8
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 6116D6C8427B0184F8D20D746E7B6DE8
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 63EF65ACE19041947AA0393E0CD90339
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 63EF65ACE19041947AA0393E0CD90339
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 65EF6217F775DC24E91B3D4EFBEDAFA9
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 65EF6217F775DC24E91B3D4EFBEDAFA9
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 68AB67CA33010000ABE7000000000030
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 68AB67CA33010000ABE7000000000030
                                      MSI (s) (80:8C) [13:53:20:398]: Setting cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
                                      MSI (s) (80:8C) [13:53:20:398]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
                                      MSI (s) (80:8C) [13:53:20:398]: User policy value 'SearchOrder' is 'nmu'
                                      MSI (s) (80:8C) [13:53:20:398]: User policy value 'DisableMedia' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'AllowLockdownMedia' is 1
                                      MSI (s) (80:8C) [13:53:20:398]: SOURCEMGMT: Looking for sourcelist for product {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (s) (80:8C) [13:53:20:398]: SOURCEMGMT: Adding {AC76BA86-7AD7-1033-7B44-AA1000000001}; to potential sourcelist list (pcode;disk;relpath).
                                      MSI (s) (80:8C) [13:53:20:398]: SOURCEMGMT: Now checking product {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      MSI (s) (80:8C) [13:53:20:398]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
                                      MSI (s) (80:8C) [13:53:20:398]: SOURCEMGMT: Trying source C:\Apps\.
                                      MSI (s) (80:8C) [13:53:20:398]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                      MSI (s) (80:8C) [13:53:20:398]: Specifed source is already in a list.
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'DisableBrowse' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'AllowLockdownBrowse' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'DisableMsi' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'AlwaysInstallElevated' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: User policy value 'AlwaysInstallElevated' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is admin assigned: LocalSystem owns the publish key.
                                      MSI (s) (80:8C) [13:53:20:398]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is managed.
                                      MSI (s) (80:8C) [13:53:20:398]: Running product '{AC76BA86-7AD7-1033-7B44-AA1000000001}' with elevated privileges: Product is assigned.
                                      MSI (s) (80:8C) [13:53:20:398]: Adding new sources is not allowed.
                                      MSI (s) (80:8C) [13:53:20:398]: Set LastUsedSource to: C:\Apps\.
                                      MSI (s) (80:8C) [13:53:20:398]: Set LastUsedType to: n.
                                      MSI (s) (80:8C) [13:53:20:398]: Set LastUsedIndex to: 2.
                                      MSI (s) (80:8C) [13:53:20:398]: SOURCEMGMT: Resolved source to: 'C:\Apps\'
                                      MSI (s) (80:8C) [13:53:20:398]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
                                      MSI (s) (80:8C) [13:53:20:398]: Note: 1: 1715 2: Adobe Reader X (10.1.0)
                                      MSI (s) (80:8C) [13:53:20:414]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Reader X (10.1.0).".
                                      MSI (s) (80:8C) [13:53:44:110]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 92.
                                      MSI (s) (80:8C) [13:53:44:141]: File will have security applied from OpCode.
                                      MSI (s) (80:8C) [13:53:44:204]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Apps\AdbeRdr1010_en_US.msi' against software restriction policy
                                      MSI (s) (80:8C) [13:53:44:204]: SOFTWARE RESTRICTION POLICY: C:\Apps\AdbeRdr1010_en_US.msi has a digital signature
                                      MSI (s) (80:8C) [13:53:44:391]: SOFTWARE RESTRICTION POLICY: C:\Apps\AdbeRdr1010_en_US.msi is permitted to run at the 'unrestricted' authorization level.
                                      MSI (s) (80:8C) [13:53:44:391]: End dialog not enabled
                                      MSI (s) (80:8C) [13:53:44:391]: Original package ==> C:\Apps\AdbeRdr1010_en_US.msi
                                      MSI (s) (80:8C) [13:53:44:391]: Package we're running from ==> C:\Windows\Installer\1ee54.msi
                                      MSI (s) (80:8C) [13:53:44:391]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
                                      MSI (s) (80:8C) [13:53:44:391]: APPCOMPAT: looking for appcompat database entry with ProductCode '{AC76BA86-7AD7-1033-7B44-AA1000000001}'.
                                      MSI (s) (80:8C) [13:53:44:391]: APPCOMPAT: no matching ProductCode found in database.
                                      MSI (s) (80:8C) [13:53:44:391]: MSCOREE not loaded loading copy from system32
                                      MSI (s) (80:8C) [13:53:44:391]: Machine policy value 'DisablePatch' is 0
                                      MSI (s) (80:8C) [13:53:44:391]: Machine policy value 'AllowLockdownPatch' is 0
                                      MSI (s) (80:8C) [13:53:44:391]: Machine policy value 'AlwaysInstallElevated' is 0
                                      MSI (s) (80:8C) [13:53:44:391]: User policy value 'AlwaysInstallElevated' is 0
                                      MSI (s) (80:8C) [13:53:44:391]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is admin assigned: LocalSystem owns the publish key.
                                      MSI (s) (80:8C) [13:53:44:391]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is managed.
                                      MSI (s) (80:8C) [13:53:44:391]: Running product '{AC76BA86-7AD7-1033-7B44-AA1000000001}' with elevated privileges: Product is assigned.
                                      MSI (s) (80:8C) [13:53:44:391]: Machine policy value 'DisableLUAPatching' is 0
                                      MSI (s) (80:8C) [13:53:44:391]: Machine policy value 'DisableFlyWeightPatching' is 0
                                      MSI (s) (80:8C) [13:53:44:391]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                                      MSI (s) (80:8C) [13:53:44:422]: APPCOMPAT: looking for appcompat database entry with ProductCode '{AC76BA86-7AD7-1033-7B44-AA1000000001}'.
                                      MSI (s) (80:8C) [13:53:44:422]: APPCOMPAT: no matching ProductCode found in database.
                                      MSI (s) (80:8C) [13:53:44:422]: Transforms are not secure.
                                      MSI (s) (80:8C) [13:53:44:422]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\LOCALA~1\AppData\Local\Temp\MSI185e1.LOG'.
                                      MSI (s) (80:8C) [13:53:44:422]: Command Line: ROOTDRIVE=C:\ ACROBAT_APP_PATH=C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe ADOBE_COMMON_ACROBAT=C:\Program Files\Common Files\Adobe\Acrobat\ ACTIVE_X=C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\ ADOBE=C:\Program Files\Adobe\ ADOBE_COMMON=C:\Program Files\Common Files\Adobe\ AIR=C:\Program Files\Adobe\Reader 10.0\Reader\AIR\ READER=C:\Program Files\Adobe\Reader 10.0\Reader\ TARGETDIR=C:\ ALLUSERSPROFILE=C:\ ALLUSERS_APPDATA_ADOBE=C:\ProgramData\Adobe\ ALLUSERS_APPDATA_ADOBE_ACROBAT=C:\ProgramData\Adobe\Acrobat\ ALLUSERS_APPDATA_ADOBE_ACROBAT_9=C:\ProgramData\Adobe\Acrobat\10.0\ ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE=C:\ProgramData\Adobe\Acrobat\10.0\Replicate\ ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY=C:\ProgramData\Adobe\Acrobat\10.0\Rep licate\Security\ PLUG_INS=C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\ ANNOTATIONS=C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\ ARM=C:\Program Files\Common Files\Adobe\ARM\ ARM_1.0=C:\Program Files\Common Files\Adobe\ARM\1.0\ BROWSER=C:\Program Fi
                                      MSI (s) (80:8C) [13:53:44:422]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{9587FED9-63E2-4D75-B4B2-1F9CDD57B3F5}'.
                                      MSI (s) (80:8C) [13:53:44:422]: Product Code passed to Engine.Initialize:           '{AC76BA86-7AD7-1033-7B44-AA1000000001}'
                                      MSI (s) (80:8C) [13:53:44:422]: Product Code from property table before transforms: '{AC76BA86-7AD7-1033-7B44-AA1000000001}'
                                      MSI (s) (80:8C) [13:53:44:422]: Product Code from property table after transforms:  '{AC76BA86-7AD7-1033-7B44-AA1000000001}'
                                      MSI (s) (80:8C) [13:53:44:422]: Product not registered: beginning first-time install
                                      MSI (s) (80:8C) [13:53:44:422]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
                                      MSI (s) (80:8C) [13:53:44:422]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
                                      MSI (s) (80:8C) [13:53:44:422]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is admin assigned: LocalSystem owns the publish key.
                                      MSI (s) (80:8C) [13:53:44:422]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is managed.
                                      MSI (s) (80:8C) [13:53:44:469]: Machine policy value 'AlwaysInstallElevated' is 0
                                      MSI (s) (80:8C) [13:53:44:469]: User policy value 'AlwaysInstallElevated' is 0
                                      MSI (s) (80:8C) [13:53:44:469]: MSI_LUA: Credential prompt is not required at this point, product is managed and deployment compliant
                                      MSI (s) (80:8C) [13:53:44:469]: Note: 1: 2205 2:  3: MsiPackageCertificate
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding ProductState property. Its value is '1'.
                                      MSI (s) (80:8C) [13:53:44:469]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
                                      MSI (s) (80:8C) [13:53:44:469]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                      MSI (s) (80:8C) [13:53:44:469]: Specifed source is already in a list.
                                      MSI (s) (80:8C) [13:53:44:469]: User policy value 'SearchOrder' is 'nmu'
                                      MSI (s) (80:8C) [13:53:44:469]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is admin assigned: LocalSystem owns the publish key.
                                      MSI (s) (80:8C) [13:53:44:469]: Product {AC76BA86-7AD7-1033-7B44-AA1000000001} is managed.
                                      MSI (s) (80:8C) [13:53:44:469]: Running product '{AC76BA86-7AD7-1033-7B44-AA1000000001}' with elevated privileges: Product is assigned.
                                      MSI (s) (80:8C) [13:53:44:469]: Adding new sources is not allowed.
                                      MSI (s) (80:8C) [13:53:44:469]: Package name retrieved from configuration data: 'AdbeRdr1010_en_US.msi'
                                      MSI (s) (80:8C) [13:53:44:469]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                                      MSI (s) (80:8C) [13:53:44:469]: Machine policy value 'EnableUserControl' is 0
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding RestrictedUserControl property. Its value is '1'.
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ROOTDRIVE
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding ACROBAT_APP_PATH property. Its value is 'C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe'.
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ADOBE_COMMON_ACROBAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ACTIVE_X
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property AIR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property READER
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TARGETDIR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ALLUSERSPROFILE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ALLUSERS_APPDATA_ADOBE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ALLUSERS_APPDATA_ADOBE_ACROBAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ALLUSERS_APPDATA_ADOBE_ACROBAT_9
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property PLUG_INS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ANNOTATIONS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ARM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ARM_1.0
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property BROWSER
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property BROWSER_IE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property CACHE_SETUP_FILES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property CACHE_DIR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property INSTALLDIR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property RESOURCE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property CIDFONT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property CMAP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_CAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_CHS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_CHT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_CZE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_DAN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_ENU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_EUQ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_HRV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_HUN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_JPN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_KOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_NOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_POL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_PTB
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_RUM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_RUS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_SKY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_SLV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_SUO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_TUR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_HELP_UKR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_LINGUISTIC
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_PROVIDERS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_PROVIDERS_PROXIMITY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_PROVIDERS_PROXIMITY_1100
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_ADOBE_PROVIDERS_PROXIMITY_1100_NCL3S4PNTX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMMON_LINGUISTIC_LANGUAGENAMES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_CHS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_CHT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_CZE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_DAN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_ENU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_HRV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_HUN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_JPN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_KOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_NOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_POL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_PTB
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_RUM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_RUS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_SKY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_SLV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_SUO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_TUR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DOCSETTINGS_PORTFOLIO_UKR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ESL_DIR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property FONT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_CAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_CHS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_CHT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_CZE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_DAN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_ENU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_EUQ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_HRV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_HUN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_JPN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_KOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_NOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_POL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_PTB
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_RUM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_RUS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_SKY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_SLV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_SUO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_TUR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IDTEMPLATES_UKR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property READER_9.0
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property JAVASCRIPTS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_CAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_CHS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_CHT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_CZE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_DAN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_ENU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_EUQ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_HRV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_HUN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_JPN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_KOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_NOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_POL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_PTB
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_RUM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_RUS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_SKY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_SLV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_SUO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_TUR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LEGAL_UKR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_CA_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_CS_CZ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_DA_DK
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_DE_DE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_ES_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_EU_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_FI_FI
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_FR_FR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_HR_HR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_HU_HU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_IT_IT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_JA_JP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_KO_KR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_NB_NO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_NL_NL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_PL_PL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_PT_BR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_RO_RO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_RU_RU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_SK_SK
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_SL_SI
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_SV_SE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_TR_TR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_UK_UA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_ZH_CN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property LOCALE_ZH_TW
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_1
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_2
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_3
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_4
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_5
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_6
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_7
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MOZILLA_8
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_CZE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_HRV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_HUN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_POL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_RUM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_RUS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_SKY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_SLV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_TUR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MPP_UKR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_CAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_CHS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_CHT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_DAN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_EUQ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_JAPN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_KOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_NOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_PTB
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_SUO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MULTIMEDIA_MPP_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property NETSCAPE_3
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property NETSCAPE_4
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CA_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CA_ES_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CA_ES_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CA_ES_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CS_CZ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CS_CZ_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CS_CZ_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_CS_CZ_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DA_DK
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DA_DK_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DA_DK_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DA_DK_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DE_DE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DE_DE_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DE_DE_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_DE_DE_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EN_US
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EN_US_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EN_US_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EN_US_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ES_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ES_ES_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ES_ES_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ES_ES_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EU_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EU_ES_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EU_ES_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_EU_ES_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FI_FI
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FI_FI_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FI_FI_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FI_FI_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FR_FR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FR_FR_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FR_FR_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_FR_FR_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HR_HR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HR_HR_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HR_HR_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HR_HR_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HU_HU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HU_HU_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HU_HU_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_HU_HU_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_IT_IT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_IT_IT_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_IT_IT_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_IT_IT_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_JA_JP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_JA_JP_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_JA_JP_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_JA_JP_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_KO_KR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_KO_KR_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_KO_KR_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_KO_KR_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NB_NO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NB_NO_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NB_NO_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NB_NO_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NL_NL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NL_NL_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NL_NL_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_NL_NL_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PL_PL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PL_PL_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PL_PL_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PL_PL_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PT_BR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PT_BR_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PT_BR_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_PT_BR_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RO_RO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RO_RO_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RO_RO_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RO_RO_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RU_RU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RU_RU_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RU_RU_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_RU_RU_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SK_SK
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SK_SK_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SK_SK_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SK_SK_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SL_SI
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SL_SI_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SL_SI_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SL_SI_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SV_SE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SV_SE_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SV_SE_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_SV_SE_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_TR_TR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_TR_TR_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_TR_TR_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_TR_TR_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_UK_UA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_UK_UA_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_UK_UA_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_UK_UA_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_CN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_CN_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_CN_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_CN_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_TW
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_TW_RDR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_TW_RDRX
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ONLINE_HELP_ZH_TW_RDRX_USING
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property PFM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property PLUGINS_3D
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property PLUGINS_3D_PRC
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property PLUG_INS_ACROFORM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property PLUG_INS_ACROFORM_PMP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SASIPREP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_CA_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_CS_CZ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_DA_DK
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_DE_DE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_ES_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_EU_ES
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_FI_FI
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_FR_FR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_HR_HR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_HU_HU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_IT_IT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_JA_JP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_KO_KR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_NB_NO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_NL_NL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_PL_PL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_PT_BR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_RO_RO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_RU_RU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_SK_SK
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_SL_SI
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_SV_SE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_TR_TR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_UK_UA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_ZH_CN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SERVICES_ZH_TW
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SPPLUGINS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_CAT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_CHS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_CHT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_CZE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_DAN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_ENU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_EUQ
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_HRV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_HUN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_JPN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_KOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_NOR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_POL
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_PTB
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_RUM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_RUS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_SKY
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_SLV
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_SUO
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_TUR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property STAMP_UKR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TRACKER
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT_UNICODE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT_UNICODE_ICU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT_UNICODE_MAPPINGS
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT_UNICODE_MAPPINGS_ADOBE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT_UNICODE_MAPPINGS_MAC
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property TYPESPT_UNICODE_MAPPINGS_WIN
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property USERPROFILE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_DEU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_ENU
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_ESP
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_FRA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_ITA
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_NLD
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property VDKHOME_SVE
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ISSETUPFILESCOMPLETED
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SUPPORTDIR
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property SOURCEDIR
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property COMPANYNAME
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property USERNAME
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property MIN_SYSTEM
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property IE_VERSION
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property ARPREADME
                                      MSI (s) (80:8C) [13:53:44:469]: Ignoring disallowed property DISPLAYPDFOWNERSHIPDLG
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding UT_AS2 property. Its value is '{AC76BA86-1033-0000-BA7E-000000000003}'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2880'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Apps'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'Help,ARM,Reader_Big_Features,SearchAndIndex,MultimediaPlugin,ReaderProgramFiles,ReaderBr owserIntegration,ReaderPDFIntegration,Accessibility_Plugins,Atmosphere_3D,AdobeCommonLingu istics_Big,Enterprise,Updater,Plugins,AdobeCommonTypSpt,DTShortcut'.
                                      MSI (s) (80:8C) [13:53:44:469]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
                                      MSI (s) (80:8C) [13:53:44:469]: RESTART MANAGER: Disabled by MSIRESTARTMANAGERCONTROL property; Windows Installer will use the built-in FilesInUse functionality.
                                      MSI (s) (80:8C) [13:53:44:469]: Engine has iefSecondSequence set to true.
                                      MSI (s) (80:8C) [13:53:44:469]: TRANSFORMS property is now:
                                      MSI (s) (80:8C) [13:53:44:469]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '300'.
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Favorites
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Documents
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Recent
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\SendTo
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Templates
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Local
                                      MSI (s) (80:8C) [13:53:44:469]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Pictures
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\Users\LocalAdmin\Desktop
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                                      MSI (s) (80:8C) [13:53:44:485]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                                      MSI (s) (80:8C) [13:53:44:485]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                                      MSI (s) (80:8C) [13:53:44:485]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                                      MSI (s) (80:8C) [13:53:44:485]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B744AA0100000010
                                      MSI (s) (80:8C) [13:53:44:485]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Admin'.
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Microsoft'.
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1ee54.msi'.
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Apps\AdbeRdr1010_en_US.msi'.
                                      MSI (s) (80:8C) [13:53:44:485]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                                      MSI (s) (80:8C) [13:53:44:485]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
                                      MSI (s) (80:8C) [13:53:44:485]: Note: 1: 2205 2:  3: PatchPackage
                                      MSI (s) (80:8C) [13:53:44:485]: Machine policy value 'DisableRollback' is 0
                                      MSI (s) (80:8C) [13:53:44:485]: User policy value 'DisableRollback' is 0
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
                                      MSI (s) (80:8C) [13:53:44:485]: Doing action: INSTALL
                                      Action 13:53:44: INSTALL.
                                      Action start 13:53:44: INSTALL.
                                      MSI (s) (80:8C) [13:53:44:485]: Running ExecuteSequence
                                      MSI (s) (80:8C) [13:53:44:485]: Doing action: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54
                                      Action 13:53:44: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
                                      Action start 13:53:44: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
                                      MSI (s) (80:8C) [13:53:44:485]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54'
                                      MSI (s) (80:8C) [13:53:44:485]: PROPERTY CHANGE: Adding SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 property. Its value is 'C:\Windows\system32\'.
                                      Action ended 13:53:44: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54. Return value 1.
                                      MSI (s) (80:8C) [13:53:44:485]: Doing action: ISSetupFilesExtract
                                      Action 13:53:44: ISSetupFilesExtract.
                                      Action start 13:53:44: ISSetupFilesExtract.
                                      MSI (s) (80:8C) [13:53:44:500]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'ISSetupFilesExtract'
                                      MSI (s) (80:8C) [13:53:44:500]: Skipping action due to msidbCustomActionTypeFirstSequence option.
                                      Action ended 13:53:44: ISSetupFilesExtract. Return value 0.
                                      MSI (s) (80:8C) [13:53:44:500]: Doing action: AppSearch
                                      Action 13:53:44: AppSearch. Searching for installed applications
                                      Action start 13:53:44: AppSearch.
                                      MSI (s) (80:8C) [13:53:44:500]: Skipping AppSearch action: already done on client side
                                      Action ended 13:53:44: AppSearch. Return value 0.
                                      MSI (s) (80:8C) [13:53:44:500]: Doing action: LaunchConditions
                                      Action 13:53:44: LaunchConditions. Evaluating launch conditions
                                      Action start 13:53:44: LaunchConditions.
                                      Adobe Reader X (10.1.0) requires Internet Explorer 6.0 or greater.  Please visit www.microsoft.com to upgrade Internet Explorer.
                                      MSI (s) (80:8C) [13:54:01:100]: Product: Adobe Reader X (10.1.0) -- Adobe Reader X (10.1.0) requires Internet Explorer 6.0 or greater.  Please visit www.microsoft.com to upgrade Internet Explorer.
                                      Action ended 13:54:01: LaunchConditions. Return value 3.
                                      Action ended 13:54:01: INSTALL. Return value 3.
                                      Property(S): Text = 0
                                      Property(S): DiskPrompt = [1]
                                      Property(S): Registration = No
                                      Property(S): UpgradeCode = {A6EADE66-0000-0000-484E-7E8A45000000}
                                      Property(S): VersionNT = 601
                                      Property(S): ACROBAT_APP_PATH = C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe
                                      Property(S): ProgramFilesFolder = C:\Program Files\
                                      Property(S): CommonFilesFolder = C:\Program Files\Common Files\
                                      Property(S): CommonAppDataFolder = C:\ProgramData\
                                      Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                                      Property(S): AppDataFolder = C:\Users\LocalAdmin\AppData\Roaming\
                                      Property(S): DesktopFolder = C:\Users\Public\Desktop\
                                      Property(S): FavoritesFolder = C:\Users\LocalAdmin\Favorites\
                                      Property(S): FontsFolder = C:\Windows\Fonts\
                                      Property(S): LocalAppDataFolder = C:\Users\LocalAdmin\AppData\Local\
                                      Property(S): MyPicturesFolder = C:\Users\LocalAdmin\Pictures\
                                      Property(S): PersonalFolder = C:\Users\LocalAdmin\Documents\
                                      Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                                      Property(S): SendToFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\SendTo\
                                      Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                                      Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                                      Property(S): System16Folder = C:\Windows\system\
                                      Property(S): SystemFolder = C:\Windows\system32\
                                      Property(S): TempFolder = C:\Users\LOCALA~1\AppData\Local\Temp\
                                      Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                                      Property(S): WindowsFolder = C:\Windows\
                                      Property(S): WindowsVolume = C:\
                                      Property(S): Preselected = 1
                                      Property(S): UILevel = 5
                                      Property(S): OriginalDatabase = C:\Apps\AdbeRdr1010_en_US.msi
                                      Property(S): DATABASE = C:\Windows\Installer\1ee54.msi
                                      Property(S): SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\system32\
                                      Property(S): COMPANYNAME = Microsoft
                                      Property(S): ALLUSERS = 1
                                      Property(S): Dummy_Microsoft_VC90_CRT_x86.0138F525_6C8A_333F_A105_14AE030B9A54 = 1
                                      Property(S): Dummy_policy_9_0_Microsoft_VC90_CRT_x86.52105B6B_A3EF_3A90_882A_947B287C203A = 1
                                      Property(S): USERNAME = Admin
                                      Property(S): MsiRunningElevated = 1
                                      Property(S): RedirectedDllSupport = 2
                                      Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
                                      Property(S): MsiNetAssemblySupport = 4.0.30319.1
                                      Property(S): Date = 11/11/2011
                                      Property(S): Time = 13:54:01
                                      Property(S): TTCSupport = 1
                                      Property(S): ColorBits = 32
                                      Property(S): TextInternalLeading = 3
                                      Property(S): TextHeight = 16
                                      Property(S): BorderSide = 1
                                      Property(S): BorderTop = 1
                                      Property(S): CaptionHeight = 22
                                      Property(S): AS_REPAIR_VERSION_LIST = A
                                      Property(S): ScreenY = 768
                                      Property(S): ProductCode = {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      Property(S): ApplicationUsers = AllUsers
                                      Property(S): AgreeToLicense = No
                                      Property(S): _IsMaintenance = Reinstall
                                      Property(S): SetupType = Typical
                                      Property(S): _IsSetupTypeMin = Typical
                                      Property(S): ARPCONTACT = Customer Support
                                      Property(S): ARPHELPLINK = http://www.adobe.com/support/main.html
                                      Property(S): ARPREADME = Readme.htm
                                      Property(S): ARPURLINFOABOUT = http://www.adobe.com
                                      Property(S): ARPURLUPDATEINFO = http://www.adobe.com/products/acrobat/readstep.html
                                      Property(S): DefaultUIFont = Tahoma8
                                      Property(S): ErrorDialog = SetupError
                                      Property(S): INSTALLLEVEL = 100
                                      Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
                                      Property(S): Manufacturer = Adobe Systems Incorporated
                                      Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                                      Property(S): ProductID = none
                                      Property(S): ProductLanguage = 1033
                                      Property(S): ProductName = Adobe Reader X (10.1.0)
                                      Property(S): ProductVersion = 10.1.0
                                      Property(S): ProgressType0 = install
                                      Property(S): ProgressType1 = Installing
                                      Property(S): ProgressType2 = installed
                                      Property(S): ProgressType3 = installs
                                      Property(S): RebootYesNo = Yes
                                      Property(S): ReinstallModeText = omus
                                      Property(S): TRACKINGKEY = Software\Adobe\Acrobat Reader\7.0
                                      Property(S): ARPPRODUCTICON = SC_Reader.ico
                                      Property(S): Cancel = 0
                                      Property(S): RadioGroup = 0
                                      Property(S): TypicalText = 0
                                      Property(S): ARPCOMMENTS =
                                      Property(S): ERROR_MIN_OVER_BIG = Setup has detected that you already have a more functional product installed.  Setup will now terminate.
                                      Property(S): SecureCustomProperties = DEFAULT_VERB;ACTIONPROPERTY;ELEMENTS;RDRMIN;RDRBIG;RDRBIG_8X;RDRBIG_9X;RDRBIG_10X;UT_FRB; UT_FRS;UT_AT;UT_AP1;UT_AP2;UT_AS1;UT_AS2;UT_A3D;UT_6X;UT_7X;UT_MM61;UT_MM62;UT_MM63;UT_EB6 1;UT_EB62;UT_EB63;AS_OPTIMIZE_ENABLED;ACROBAT_APP_PATH;AS_HKCR_EXE;PDFSHELL_LOCALSERVER_CO MMAND;PDF_DEFAULTICON;PDF_PREVIEW_HANDERLER_DLL;PDF_PREVIEW_HANDERLER_HELPDIR;DISABLE_PDFO WNERSHIP_RESTORE;PDF_INPROCSERVER_VIEWERPS;READER_PATH
                                      Property(S): BrandName = Adobe Reader X (10.1.0)
                                      Property(S): ISVROOT_PORT_NO = 0
                                      Property(S): ScreenX = 1024
                                      Property(S): IsMinIE_Message = requires Internet Explorer 6.0 or greater.  Please visit www.microsoft.com to upgrade Internet Explorer.
                                      Property(S): ISLANGFLAG = ENU
                                      Property(S): FilesLabel = 0
                                      Property(S): DisallowRunFromSource = 1
                                      Property(S): AppsInUseSilentAbort = A process is running that cannot be shut down by Setup.  Please either close all applications and run Setup again, or restart your computer and run Setup again.
                                      Property(S): ENABLE_CACHE_FILES = YES
                                      Property(S): OLE_VERB_OPEN = &Open,0,2
                                      Property(S): REINSTALLMODE = omus
                                      Property(S): Elevated = 1
                                      Property(S): ENABLE_OPTIMIZATION = YES
                                      Property(S): ERROR_DEFRAG_MSG = Optimizing performance ...
                                      Property(S): ERROR_DEFRAG_ADTEMPLATE = Completed [1]% of process
                                      Property(S): ERROR_CANNOT_OPTIMIZE_DISK = NOTE: Installation was successful. However, because your hard drive is fragmented, this application may not be able to launch as quickly as possible. To optimize performance, please defragment your hard drive and then repair this application under Add or Remove Programs in the Control Panel.
                                      Property(S): EULA_ACCEPT = NO
                                      Property(S): DISABLE_BROWSER_INTEGRATION = NO
                                      Property(S): AcroIEHelper_Description = Adobe PDF Reader Link Helper
                                      Property(S): DEFAULT_VERB = Read
                                      Property(S): ADMIN_INSTALL = NO
                                      Property(S): AdminProperties = ADMIN_INSTALL
                                      Property(S): REMOVE_PREVIOUS = YES
                                      Property(S): SYNCHRONIZER = YES
                                      Property(S): SystemLanguageID = 1033
                                      Property(S): OpenWith = Open with Adobe Reader X
                                      Property(S): SetupCacheExport =
                                      Property(S): LC_UNSUPPORTED_OS = This application cannot be installed on this operating system. Setup will now terminate. Please refer to the minimum system requirements at http://www.adobe.com/go/reader_system_reqs.
                                      Property(S): ApplicationList = 0
                                      Property(S): DEFAULT_ATTACHMENT_WHITELIST = version:1|.ade:3|.adp:3|.app:3|.arc:3|.arj:3|.asp:3|.bas:3|.bat:3|.bz:3|.bz2:3|.cab:3|.ch m:3|.class:3|.cmd:3|.com:3|.command:3|.cpl:3|.crt:3|.csh:3|.desktop:3|.dll:3|.exe:3|.fxp:3 |.gz:3|.hex:3|.hlp:3|.hqx:3|.hta:3|.inf:3|.ini:3|.ins:3|.isp:3|.its:3|.job:3|.js:3|.jse:3| .ksh:3|.lnk:3|.lzh:3|.mad:3|.maf:3|.mag:3|.mam:3|.maq:3|.mar:3|.mas:3|.mat:3|.mau:3|.mav:3 |.maw:3|.mda:3|.mdb:3|.mde:3|.mdt:3|.mdw:3|.mdz:3|.msc:3|.msi:3|.msp:3|.mst:3|.ocx:3|.ops: 3|.pcd:3|.pi:3|.pif:3|.prf:3|.prg:3|.pst:3|.rar:3|.reg:3|.scf:3|.scr:3|.sct:3|.sea:3|.shb: 3|.shs:3|.sit:3|.tar:3|.taz:3|.tgz:3|.tmp:3|.url:3|.vb:3|.vbe:3|.vbs:3|.vsmacros:3|.vss:3| .vst:3|.vsw:3|.webloc:3|.ws:3|.wsc:3|.wsf:3|.wsh:3|.z:3|.zip:3|.zlo:3|.zoo:3|.pdf:2|.fdf:2 |.jar:3|.pkg:3|.tool:3|.term:3
                                      Property(S): EXEC_MENU_WHITELIST = Close|GeneralInfo|Quit|FirstPage|PrevPage|NextPage|LastPage|ActualSize|FitPage|FitWidth|F itHeight|SinglePage|OneColumn|TwoPages|TwoColumns|ZoomViewIn|ZoomViewOut|ShowHideBookmarks |ShowHideThumbnails|Print|GoToPage|ZoomTo|GeneralPrefs|SaveAs|FullScreenMode|OpenOrganizer |Scan|Web2PDF:OpnURL|AcroSendMail:SendMail|Spelling:Check Spelling|PageSetup|Find|FindSearch|GoBack|GoForward|FitVisible|ShowHideArticles|ShowHideF ileAttachment|ShowHideAnnotManager|ShowHideFields|ShowHideOptCont|ShowHideModelTree|ShowHi deSignatures|InsertPages|ExtractPages|ReplacePages|DeletePages|CropPages|RotatePages|AddFi leAttachment|FindCurrentBookmark|BookmarkShowLocation|GoBackDoc|GoForwardDoc|DocHelpUserGu ide|HelpReader|rolReadPage|HandMenuItem|ZoomDragMenuItem|CollectionPreview|CollectionHome| CollectionDetails|CollectionShowRoot|&Pages|Co&ntent|&Forms|Action &Wizard|Recognize &Text|P&rotection|&Sign && Certify|Doc&ument Processing|Print Pro&duction|Ja&vaScript|&Accessibility|Analy&ze|&Annotations|D&rawing Markups|Revie&w
                                      Property(S): PDF_Integration = 1
                                      Property(S): Browser_Integration = 2
                                      Property(S): ARPNOREPAIR = 1
                                      Property(S): ActionTextLabel = 0
                                      Property(S): CurrentPdfOwner = 0
                                      Property(S): ReadmeHtml = Readme.htm
                                      Property(S): OprimizeError2 = 0
                                      Property(S): ReaderProcessPopup = 0
                                      Property(S): BrandNameMajorVer = Adobe Reader X
                                      Property(S): DefragResetProgress = No
                                      Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                                      Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                                      Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                                      Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                                      Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                                      Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                                      Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                                      Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                                      Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                                      Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                                      Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                                      Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                                      Property(S): IS_SQLSERVER_USERNAME = sa
                                      Property(S): _5789b66a5ab8e = {AC76BA80-0010-7AD7-0000-000000000000}
                                      Property(S): AttentionCloseReader = 0
                                      Property(S): RunTimeProperties = CACHE_DIR;ProductName;OriginalDatabase;REMOVE;WindowsFolder;SetupCacheExport;ALLUSERS;REI NSTALLMODE;PLUG_INS;DefragResetProgress;ALLUSERS_APPDATA_ADOBE;DEFAULT_VERB;IS_CURRENT_PDF OWNER;ACTIVE_X;Installed;READER;ProductCode
                                      Property(S): DV = 10.0
                                      Property(S): MSIRESTARTMANAGERCONTROL = Disable
                                      Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                                      Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                                      Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                                      Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                                      Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                                      Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                                      Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                                      Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                                      Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                                      Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                                      Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                                      Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                                      Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                                      Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                                      Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                                      Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                                      Property(S): RestartManagerOption = CloseRestart
                                      Property(S): AppsInUseUnknownAcrobatApps = Applications that are using Adobe Reader or Adobe Acrobat
                                      Property(S): EmbdUI = 1
                                      Property(S): ADOBE_LINK = http://www.adobe.com
                                      Property(S): _WebLinkChecked = 0
                                      Property(S): CurrentProduct = 0
                                      Property(S): DWUSLINK = CEFB870FBECC80BF79AC97C8298C978FD9DCB78FCEDC5098CE8B974F99DBF0F8CEEC50A809AC
                                      Property(S): PROCESSPATHWITHID = %s with process ID: %d
                                      Property(S): LANG_LIST = ENU,FRA,DEU,JPN,ITA,ESP,NLD,PTB,SVE,DAN,SUO,NOR,CHS,CHT,KOR,BGR,CZE,ETI,HRV,HUN,LTH,LVI,P OL,RUM,RUS,SKY,SLV,TUR,UKR,EUQ,CAT
                                      Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                                      Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                                      Property(S): UNKNOWNPROCESSWITHID = Unknown process with process ID: %d
                                      Property(S): Square = 1
                                      Property(S): ISReleaseFlags = ENU,READERBIG
                                      Property(S): ADDLOCAL = Help,ARM,Reader_Big_Features,SearchAndIndex,MultimediaPlugin,ReaderProgramFiles,ReaderBro wserIntegration,ReaderPDFIntegration,Accessibility_Plugins,Atmosphere_3D,AdobeCommonLingui stics_Big,Enterprise,Updater,Plugins,AdobeCommonTypSpt,DTShortcut
                                      Property(S): ComputerName = CC-DESK-11
                                      Property(S): UserLanguageID = 1033
                                      Property(S): UserSID = S-1-5-21-187901175-1198847298-2277931997-1006
                                      Property(S): LogonUser = LocalAdmin
                                      Property(S): Privileged = 1
                                      Property(S): VirtualMemory = 6054
                                      Property(S): PhysicalMemory = 3548
                                      Property(S): Intel = 6
                                      Property(S): ShellAdvtSupport = 1
                                      Property(S): OLEAdvtSupport = 1
                                      Property(S): GPTSupport = 1
                                      Property(S): RecentFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Recent\
                                      Property(S): PrintHoodFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                                      Property(S): NetHoodFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                                      Property(S): RemoteAdminTS = 1
                                      Property(S): MsiNTProductType = 1
                                      Property(S): ServicePackLevelMinor = 0
                                      Property(S): ServicePackLevel = 1
                                      Property(S): WindowsBuild = 7601
                                      Property(S): VersionMsi = 5.00
                                      Property(S): VersionDatabase = 300
                                      Property(S): SECONDSEQUENCE = 1
                                      Property(S): UT_AS2 = {AC76BA86-1033-0000-BA7E-000000000003}
                                      Property(S): CURRENTDIRECTORY = C:\Apps
                                      Property(S): CLIENTUILEVEL = 0
                                      Property(S): CLIENTPROCESSID = 2880
                                      Property(S): PRODUCTLANGUAGE = 1033
                                      Property(S): ACTION = INSTALL
                                      Property(S): EXECUTEACTION = INSTALL
                                      Property(S): RestrictedUserControl = 1
                                      Property(S): ProductState = 1
                                      Property(S): PackageCode = {9587FED9-63E2-4D75-B4B2-1F9CDD57B3F5}
                                      Property(S): MsiLogFileLocation = C:\Users\LOCALA~1\AppData\Local\Temp\MSI185e1.LOG
                                      MSI (s) (80:8C) [13:54:01:131]: MainEngineThread is returning 1603
                                      MSI (s) (80:D8) [13:54:01:131]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 92, szDescription: "".
                                      MSI (s) (80:D8) [13:54:01:131]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
                                      MSI (s) (80:D8) [13:54:01:131]: User policy value 'DisableRollback' is 0
                                      MSI (s) (80:D8) [13:54:01:131]: Machine policy value 'DisableRollback' is 0
                                      MSI (s) (80:D8) [13:54:01:131]: Incrementing counter to disable shutdown. Counter after increment: 0
                                      MSI (s) (80:D8) [13:54:01:131]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                                      MSI (s) (80:D8) [13:54:01:131]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
                                      MSI (s) (80:D8) [13:54:01:131]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
                                      MSI (s) (80:D8) [13:54:01:131]: Restoring environment variables
                                      MSI (c) (40:D0) [13:54:01:131]: Back from server. Return value: 1603
                                      MSI (c) (40:D0) [13:54:01:131]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
                                      MSI (c) (40:D0) [13:54:01:146]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
                                      Action ended 13:54:01: ExecuteAction. Return value 3.
                                      MSI (c) (40:D0) [13:54:01:146]: Doing action: SetupCompleteError
                                      Action 13:54:01: SetupCompleteError.
                                      Action start 13:54:01: SetupCompleteError.
                                      MSI (c) (40:D0) [13:54:01:146]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetupCompleteError'
                                      Info 2826.Control Bitmap1 on dialog SetupCompleteError extends beyond the boundaries of the dialog to the right by 8 pixels.
                                      Action 13:54:01: SetupCompleteError. Dialog created
                                      MSI (c) (40:C4) [13:54:02:925]: Doing action: ISSetupFilesCleanup
                                      Action 13:54:02: ISSetupFilesCleanup.
                                      Action start 13:54:02: ISSetupFilesCleanup.
                                      MSI (c) (40:C4) [13:54:02:925]: Note: 1: 2235 2:  3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'ISSetupFilesCleanup'
                                      MSI (c) (40:C4) [13:54:02:925]: Creating MSIHANDLE (31) of type 790542 for thread 2244
                                      MSI (c) (40:5C) [13:54:02:925]: Invoking remote custom action. DLL: C:\Users\LOCALA~1\AppData\Local\Temp\MSI37D6.tmp, Entrypoint: SFCleanupEx
                                      MSI (c) (40!60) [13:54:02:940]: Creating MSIHANDLE (32) of type 790531 for thread 5216
                                      MSI (c) (40!60) [13:54:02:940]: Closing MSIHANDLE (32) of type 790531 for thread 5216
                                      MSI (c) (40:5C) [13:54:02:940]: Closing MSIHANDLE (31) of type 790542 for thread 2244
                                      Action ended 13:54:02: ISSetupFilesCleanup. Return value 1.
                                      Action ended 13:54:02: SetupCompleteError. Return value 2.
                                      Action ended 13:54:02: INSTALL. Return value 3.
                                      MSI (c) (40:D0) [13:54:02:956]: Destroying RemoteAPI object.
                                      MSI (c) (40:B4) [13:54:02:972]: Custom Action Manager thread ending.
                                      Property(C): Text = 0
                                      Property(C): DiskPrompt = [1]
                                      Property(C): Registration = No
                                      Property(C): UpgradeCode = {A6EADE66-0000-0000-484E-7E8A45000000}
                                      Property(C): ROOTDRIVE = C:\
                                      Property(C): VersionNT = 601
                                      Property(C): ACROBAT_APP_PATH = C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrobat.exe
                                      Property(C): ADOBE_COMMON_ACROBAT = C:\Program Files\Common Files\Adobe\Acrobat\
                                      Property(C): ACTIVE_X = C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\
                                      Property(C): ProgramFilesFolder = C:\Program Files\
                                      Property(C): ADOBE = C:\Program Files\Adobe\
                                      Property(C): CommonFilesFolder = C:\Program Files\Common Files\
                                      Property(C): ADOBE_COMMON = C:\Program Files\Common Files\Adobe\
                                      Property(C): AIR = C:\Program Files\Adobe\Reader 10.0\Reader\AIR\
                                      Property(C): READER = C:\Program Files\Adobe\Reader 10.0\Reader\
                                      Property(C): TARGETDIR = C:\
                                      Property(C): ALLUSERSPROFILE = C:\
                                      Property(C): CommonAppDataFolder = C:\ProgramData\
                                      Property(C): ALLUSERS_APPDATA_ADOBE = C:\ProgramData\Adobe\
                                      Property(C): ALLUSERS_APPDATA_ADOBE_ACROBAT = C:\ProgramData\Adobe\Acrobat\
                                      Property(C): ALLUSERS_APPDATA_ADOBE_ACROBAT_9 = C:\ProgramData\Adobe\Acrobat\10.0\
                                      Property(C): ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE = C:\ProgramData\Adobe\Acrobat\10.0\Replicate\
                                      Property(C): ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY = C:\ProgramData\Adobe\Acrobat\10.0\Replicate\Security\
                                      Property(C): PLUG_INS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\
                                      Property(C): ANNOTATIONS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\
                                      Property(C): ARM = C:\Program Files\Common Files\Adobe\ARM\
                                      Property(C): ARM_1.0 = C:\Program Files\Common Files\Adobe\ARM\1.0\
                                      Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                                      Property(C): AppDataFolder = C:\Users\LocalAdmin\AppData\Roaming\
                                      Property(C): BROWSER = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): BROWSER_IE = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): CACHE_SETUP_FILES = C:\Program Files\Adobe\Reader 10.0\Setup Files\
                                      Property(C): CACHE_DIR = C:\Program Files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\
                                      Property(C): INSTALLDIR = C:\Program Files\Adobe\Reader 10.0\
                                      Property(C): RESOURCE = C:\Program Files\Adobe\Reader 10.0\Resource\
                                      Property(C): CIDFONT = C:\Program Files\Adobe\Reader 10.0\Resource\CIDFont\
                                      Property(C): CMAP = C:\Program Files\Adobe\Reader 10.0\Resource\CMap\
                                      Property(C): COMMON_ADOBE_HELP = C:\Program Files\Common Files\Adobe\HelpCfg\
                                      Property(C): COMMON_ADOBE_HELP_CAT = C:\Program Files\Common Files\Adobe\HelpCfg\ca_ES\
                                      Property(C): COMMON_ADOBE_HELP_CHS = C:\Program Files\Common Files\Adobe\HelpCfg\zh_CN\
                                      Property(C): COMMON_ADOBE_HELP_CHT = C:\Program Files\Common Files\Adobe\HelpCfg\zh_TW\
                                      Property(C): COMMON_ADOBE_HELP_CZE = C:\Program Files\Common Files\Adobe\HelpCfg\cs_CZ\
                                      Property(C): COMMON_ADOBE_HELP_DAN = C:\Program Files\Common Files\Adobe\HelpCfg\da_DK\
                                      Property(C): COMMON_ADOBE_HELP_DEU = C:\Program Files\Common Files\Adobe\HelpCfg\de_DE\
                                      Property(C): COMMON_ADOBE_HELP_ENU = C:\Program Files\Common Files\Adobe\HelpCfg\en_US\
                                      Property(C): COMMON_ADOBE_HELP_ESP = C:\Program Files\Common Files\Adobe\HelpCfg\es_ES\
                                      Property(C): COMMON_ADOBE_HELP_EUQ = C:\Program Files\Common Files\Adobe\HelpCfg\eu_ES\
                                      Property(C): COMMON_ADOBE_HELP_FRA = C:\Program Files\Common Files\Adobe\HelpCfg\fr_FR\
                                      Property(C): COMMON_ADOBE_HELP_HRV = C:\Program Files\Common Files\Adobe\HelpCfg\hr_HR\
                                      Property(C): COMMON_ADOBE_HELP_HUN = C:\Program Files\Common Files\Adobe\HelpCfg\hu_HU\
                                      Property(C): COMMON_ADOBE_HELP_ITA = C:\Program Files\Common Files\Adobe\HelpCfg\it_IT\
                                      Property(C): COMMON_ADOBE_HELP_JPN = C:\Program Files\Common Files\Adobe\HelpCfg\ja_JP\
                                      Property(C): COMMON_ADOBE_HELP_KOR = C:\Program Files\Common Files\Adobe\HelpCfg\ko_KR\
                                      Property(C): COMMON_ADOBE_HELP_NLD = C:\Program Files\Common Files\Adobe\HelpCfg\nl_NL\
                                      Property(C): COMMON_ADOBE_HELP_NOR = C:\Program Files\Common Files\Adobe\HelpCfg\nb_NO\
                                      Property(C): COMMON_ADOBE_HELP_POL = C:\Program Files\Common Files\Adobe\HelpCfg\pl_PL\
                                      Property(C): COMMON_ADOBE_HELP_PTB = C:\Program Files\Common Files\Adobe\HelpCfg\pt_BR\
                                      Property(C): COMMON_ADOBE_HELP_RUM = C:\Program Files\Common Files\Adobe\HelpCfg\ro_RO\
                                      Property(C): COMMON_ADOBE_HELP_RUS = C:\Program Files\Common Files\Adobe\HelpCfg\ru_RU\
                                      Property(C): COMMON_ADOBE_HELP_SKY = C:\Program Files\Common Files\Adobe\HelpCfg\sk_SK\
                                      Property(C): COMMON_ADOBE_HELP_SLV = C:\Program Files\Common Files\Adobe\HelpCfg\sl_SI\
                                      Property(C): COMMON_ADOBE_HELP_SUO = C:\Program Files\Common Files\Adobe\HelpCfg\fi_FI\
                                      Property(C): COMMON_ADOBE_HELP_SVE = C:\Program Files\Common Files\Adobe\HelpCfg\sv_SE\
                                      Property(C): COMMON_ADOBE_HELP_TUR = C:\Program Files\Common Files\Adobe\HelpCfg\tr_TR\
                                      Property(C): COMMON_ADOBE_HELP_UKR = C:\Program Files\Common Files\Adobe\HelpCfg\uk_UA\
                                      Property(C): COMMON_LINGUISTIC = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\
                                      Property(C): COMMON_ADOBE_PROVIDERS = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\
                                      Property(C): COMMON_ADOBE_PROVIDERS_PROXIMITY = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\
                                      Property(C): COMMON_ADOBE_PROVIDERS_PROXIMITY_1100 = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\
                                      Property(C): COMMON_ADOBE_PROVIDERS_PROXIMITY_1100_NCL3S4PNTX = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\NC-L3S4PNTX\
                                      Property(C): COMMON_LINGUISTIC_LANGUAGENAMES = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\LanguageNames2\
                                      Property(C): CommonFiles64Folder = C:\
                                      Property(C): DOCSETTINGS = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\
                                      Property(C): DOCSETTINGS_PORTFOLIO = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\
                                      Property(C): DOCSETTINGS_PORTFOLIO_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHS\
                                      Property(C): DOCSETTINGS_PORTFOLIO_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHT\
                                      Property(C): DOCSETTINGS_PORTFOLIO_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CZE\
                                      Property(C): DOCSETTINGS_PORTFOLIO_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DAN\
                                      Property(C): DOCSETTINGS_PORTFOLIO_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DEU\
                                      Property(C): DOCSETTINGS_PORTFOLIO_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ENU\
                                      Property(C): DOCSETTINGS_PORTFOLIO_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ESP\
                                      Property(C): DOCSETTINGS_PORTFOLIO_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\FRA\
                                      Property(C): DOCSETTINGS_PORTFOLIO_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HRV\
                                      Property(C): DOCSETTINGS_PORTFOLIO_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HUN\
                                      Property(C): DOCSETTINGS_PORTFOLIO_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ITA\
                                      Property(C): DOCSETTINGS_PORTFOLIO_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\JPN\
                                      Property(C): DOCSETTINGS_PORTFOLIO_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\KOR\
                                      Property(C): DOCSETTINGS_PORTFOLIO_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NLD\
                                      Property(C): DOCSETTINGS_PORTFOLIO_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NOR\
                                      Property(C): DOCSETTINGS_PORTFOLIO_POL = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\POL\
                                      Property(C): DOCSETTINGS_PORTFOLIO_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\PTB\
                                      Property(C): DOCSETTINGS_PORTFOLIO_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUM\
                                      Property(C): DOCSETTINGS_PORTFOLIO_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUS\
                                      Property(C): DOCSETTINGS_PORTFOLIO_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SKY\
                                      Property(C): DOCSETTINGS_PORTFOLIO_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SLV\
                                      Property(C): DOCSETTINGS_PORTFOLIO_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SUO\
                                      Property(C): DOCSETTINGS_PORTFOLIO_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SVE\
                                      Property(C): DOCSETTINGS_PORTFOLIO_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\TUR\
                                      Property(C): DOCSETTINGS_PORTFOLIO_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\UKR\
                                      Property(C): DesktopFolder = C:\Users\Public\Desktop\
                                      Property(C): ESL_DIR = C:\Program Files\Adobe\Reader 10.0\Esl\
                                      Property(C): FONT = C:\Program Files\Adobe\Reader 10.0\Resource\Font\
                                      Property(C): FavoritesFolder = C:\Users\LocalAdmin\Favorites\
                                      Property(C): FontsFolder = C:\Windows\Fonts\
                                      Property(C): GlobalAssemblyCache = C:\
                                      Property(C): IDTEMPLATES = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\
                                      Property(C): IDTEMPLATES_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CAT\
                                      Property(C): IDTEMPLATES_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHS\
                                      Property(C): IDTEMPLATES_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHT\
                                      Property(C): IDTEMPLATES_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CZE\
                                      Property(C): IDTEMPLATES_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DAN\
                                      Property(C): IDTEMPLATES_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DEU\
                                      Property(C): IDTEMPLATES_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ENU\
                                      Property(C): IDTEMPLATES_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ESP\
                                      Property(C): IDTEMPLATES_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\EUQ\
                                      Property(C): IDTEMPLATES_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\FRA\
                                      Property(C): IDTEMPLATES_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HRV\
                                      Property(C): IDTEMPLATES_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HUN\
                                      Property(C): IDTEMPLATES_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ITA\
                                      Property(C): IDTEMPLATES_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\JPN\
                                      Property(C): IDTEMPLATES_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\KOR\
                                      Property(C): IDTEMPLATES_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NLD\
                                      Property(C): IDTEMPLATES_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NOR\
                                      Property(C): IDTEMPLATES_POL = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\POL\
                                      Property(C): IDTEMPLATES_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\PTB\
                                      Property(C): IDTEMPLATES_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUM\
                                      Property(C): IDTEMPLATES_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUS\
                                      Property(C): IDTEMPLATES_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SKY\
                                      Property(C): IDTEMPLATES_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SLV\
                                      Property(C): IDTEMPLATES_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SUO\
                                      Property(C): IDTEMPLATES_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SVE\
                                      Property(C): IDTEMPLATES_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\TUR\
                                      Property(C): IDTEMPLATES_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\UKR\
                                      Property(C): READER_9.0 = C:\Program Files\Adobe\Reader 10.0\
                                      Property(C): JAVASCRIPTS = C:\Program Files\Adobe\Reader 10.0\Reader\Javascripts\
                                      Property(C): LEGAL = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\
                                      Property(C): LEGAL_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CAT\
                                      Property(C): LEGAL_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHS\
                                      Property(C): LEGAL_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHT\
                                      Property(C): LEGAL_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CZE\
                                      Property(C): LEGAL_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DAN\
                                      Property(C): LEGAL_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DEU\
                                      Property(C): LEGAL_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ENU\
                                      Property(C): LEGAL_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ESP\
                                      Property(C): LEGAL_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\EUQ\
                                      Property(C): LEGAL_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\FRA\
                                      Property(C): LEGAL_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HRV\
                                      Property(C): LEGAL_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HUN\
                                      Property(C): LEGAL_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ITA\
                                      Property(C): LEGAL_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\JPN\
                                      Property(C): LEGAL_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\KOR\
                                      Property(C): LEGAL_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NLD\
                                      Property(C): LEGAL_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NOR\
                                      Property(C): LEGAL_POL = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\POL\
                                      Property(C): LEGAL_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\PTB\
                                      Property(C): LEGAL_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUM\
                                      Property(C): LEGAL_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUS\
                                      Property(C): LEGAL_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SKY\
                                      Property(C): LEGAL_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SLV\
                                      Property(C): LEGAL_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SUO\
                                      Property(C): LEGAL_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SVE\
                                      Property(C): LEGAL_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\TUR\
                                      Property(C): LEGAL_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\UKR\
                                      Property(C): LOCALE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\
                                      Property(C): LOCALE_CA_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\
                                      Property(C): LOCALE_CS_CZ = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\
                                      Property(C): LOCALE_DA_DK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\
                                      Property(C): LOCALE_DE_DE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\
                                      Property(C): LOCALE_ES_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\
                                      Property(C): LOCALE_EU_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\
                                      Property(C): LOCALE_FI_FI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\
                                      Property(C): LOCALE_FR_FR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\
                                      Property(C): LOCALE_HR_HR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\
                                      Property(C): LOCALE_HU_HU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\
                                      Property(C): LOCALE_IT_IT = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\
                                      Property(C): LOCALE_JA_JP = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\
                                      Property(C): LOCALE_KO_KR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\
                                      Property(C): LOCALE_NB_NO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\
                                      Property(C): LOCALE_NL_NL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\
                                      Property(C): LOCALE_PL_PL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\
                                      Property(C): LOCALE_PT_BR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\
                                      Property(C): LOCALE_RO_RO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\
                                      Property(C): LOCALE_RU_RU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\
                                      Property(C): LOCALE_SK_SK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\
                                      Property(C): LOCALE_SL_SI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\
                                      Property(C): LOCALE_SV_SE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\
                                      Property(C): LOCALE_TR_TR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\
                                      Property(C): LOCALE_UK_UA = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\
                                      Property(C): LOCALE_ZH_CN = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\
                                      Property(C): LOCALE_ZH_TW = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\
                                      Property(C): LocalAppDataFolder = C:\Users\LocalAdmin\AppData\Local\
                                      Property(C): MOZILLA_1 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_2 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_3 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_4 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_5 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_6 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_7 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MOZILLA_8 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): MPP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\
                                      Property(C): MPP_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_CZE\
                                      Property(C): MPP_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HRV\
                                      Property(C): MPP_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HUN\
                                      Property(C): MPP_POL = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_POL\
                                      Property(C): MPP_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUM\
                                      Property(C): MPP_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUS\
                                      Property(C): MPP_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SKY\
                                      Property(C): MPP_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SLV\
                                      Property(C): MPP_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_TUR\
                                      Property(C): MPP_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_UKR\
                                      Property(C): MULTIMEDIA_MPP_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_JAPN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MULTIMEDIA_MPP_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
                                      Property(C): MyPicturesFolder = C:\Users\LocalAdmin\Pictures\
                                      Property(C): NETSCAPE_3 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): NETSCAPE_4 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
                                      Property(C): ONLINE_HELP = C:\Program Files\Common Files\Adobe\Help\
                                      Property(C): ONLINE_HELP_CA_ES = C:\Program Files\Common Files\Adobe\Help\ca_es\
                                      Property(C): ONLINE_HELP_CA_ES_RDR = C:\Program Files\Common Files\Adobe\Help\ca_es\reader\
                                      Property(C): ONLINE_HELP_CA_ES_RDRX = C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\
                                      Property(C): ONLINE_HELP_CA_ES_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\using\
                                      Property(C): ONLINE_HELP_CS_CZ = C:\Program Files\Common Files\Adobe\Help\cs_cz\
                                      Property(C): ONLINE_HELP_CS_CZ_RDR = C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\
                                      Property(C): ONLINE_HELP_CS_CZ_RDRX = C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\
                                      Property(C): ONLINE_HELP_CS_CZ_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\using\
                                      Property(C): ONLINE_HELP_DA_DK = C:\Program Files\Common Files\Adobe\Help\da_dk\
                                      Property(C): ONLINE_HELP_DA_DK_RDR = C:\Program Files\Common Files\Adobe\Help\da_dk\reader\
                                      Property(C): ONLINE_HELP_DA_DK_RDRX = C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\
                                      Property(C): ONLINE_HELP_DA_DK_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\using\
                                      Property(C): ONLINE_HELP_DE_DE = C:\Program Files\Common Files\Adobe\Help\de_de\
                                      Property(C): ONLINE_HELP_DE_DE_RDR = C:\Program Files\Common Files\Adobe\Help\de_de\reader\
                                      Property(C): ONLINE_HELP_DE_DE_RDRX = C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\
                                      Property(C): ONLINE_HELP_DE_DE_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\using\
                                      Property(C): ONLINE_HELP_EN_US = C:\Program Files\Common Files\Adobe\Help\en_us\
                                      Property(C): ONLINE_HELP_EN_US_RDR = C:\Program Files\Common Files\Adobe\Help\en_us\reader\
                                      Property(C): ONLINE_HELP_EN_US_RDRX = C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\
                                      Property(C): ONLINE_HELP_EN_US_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\using\
                                      Property(C): ONLINE_HELP_ES_ES = C:\Program Files\Common Files\Adobe\Help\es_es\
                                      Property(C): ONLINE_HELP_ES_ES_RDR = C:\Program Files\Common Files\Adobe\Help\es_es\reader\
                                      Property(C): ONLINE_HELP_ES_ES_RDRX = C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\
                                      Property(C): ONLINE_HELP_ES_ES_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\using\
                                      Property(C): ONLINE_HELP_EU_ES = C:\Program Files\Common Files\Adobe\Help\eu_ES\
                                      Property(C): ONLINE_HELP_EU_ES_RDR = C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\
                                      Property(C): ONLINE_HELP_EU_ES_RDRX = C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\
                                      Property(C): ONLINE_HELP_EU_ES_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\using\
                                      Property(C): ONLINE_HELP_FI_FI = C:\Program Files\Common Files\Adobe\Help\fi_fi\
                                      Property(C): ONLINE_HELP_FI_FI_RDR = C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\
                                      Property(C): ONLINE_HELP_FI_FI_RDRX = C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\
                                      Property(C): ONLINE_HELP_FI_FI_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\using\
                                      Property(C): ONLINE_HELP_FR_FR = C:\Program Files\Common Files\Adobe\Help\fr_fr\
                                      Property(C): ONLINE_HELP_FR_FR_RDR = C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\
                                      Property(C): ONLINE_HELP_FR_FR_RDRX = C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\
                                      Property(C): ONLINE_HELP_FR_FR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\using\
                                      Property(C): ONLINE_HELP_HR_HR = C:\Program Files\Common Files\Adobe\Help\hr_hr\
                                      Property(C): ONLINE_HELP_HR_HR_RDR = C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\
                                      Property(C): ONLINE_HELP_HR_HR_RDRX = C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\
                                      Property(C): ONLINE_HELP_HR_HR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\using\
                                      Property(C): ONLINE_HELP_HU_HU = C:\Program Files\Common Files\Adobe\Help\hu_hu\
                                      Property(C): ONLINE_HELP_HU_HU_RDR = C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\
                                      Property(C): ONLINE_HELP_HU_HU_RDRX = C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\
                                      Property(C): ONLINE_HELP_HU_HU_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\using\
                                      Property(C): ONLINE_HELP_IT_IT = C:\Program Files\Common Files\Adobe\Help\it_it\
                                      Property(C): ONLINE_HELP_IT_IT_RDR = C:\Program Files\Common Files\Adobe\Help\it_it\reader\
                                      Property(C): ONLINE_HELP_IT_IT_RDRX = C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\
                                      Property(C): ONLINE_HELP_IT_IT_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\using\
                                      Property(C): ONLINE_HELP_JA_JP = C:\Program Files\Common Files\Adobe\Help\ja_jp\
                                      Property(C): ONLINE_HELP_JA_JP_RDR = C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\
                                      Property(C): ONLINE_HELP_JA_JP_RDRX = C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\
                                      Property(C): ONLINE_HELP_JA_JP_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\using\
                                      Property(C): ONLINE_HELP_KO_KR = C:\Program Files\Common Files\Adobe\Help\ko_kr\
                                      Property(C): ONLINE_HELP_KO_KR_RDR = C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\
                                      Property(C): ONLINE_HELP_KO_KR_RDRX = C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\
                                      Property(C): ONLINE_HELP_KO_KR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\using\
                                      Property(C): ONLINE_HELP_NB_NO = C:\Program Files\Common Files\Adobe\Help\nb_no\
                                      Property(C): ONLINE_HELP_NB_NO_RDR = C:\Program Files\Common Files\Adobe\Help\nb_no\reader\
                                      Property(C): ONLINE_HELP_NB_NO_RDRX = C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\
                                      Property(C): ONLINE_HELP_NB_NO_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\using\
                                      Property(C): ONLINE_HELP_NL_NL = C:\Program Files\Common Files\Adobe\Help\nl_nl\
                                      Property(C): ONLINE_HELP_NL_NL_RDR = C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\
                                      Property(C): ONLINE_HELP_NL_NL_RDRX = C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\
                                      Property(C): ONLINE_HELP_NL_NL_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\using\
                                      Property(C): ONLINE_HELP_PL_PL = C:\Program Files\Common Files\Adobe\Help\pl_pl\
                                      Property(C): ONLINE_HELP_PL_PL_RDR = C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\
                                      Property(C): ONLINE_HELP_PL_PL_RDRX = C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\
                                      Property(C): ONLINE_HELP_PL_PL_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\using\
                                      Property(C): ONLINE_HELP_PT_BR = C:\Program Files\Common Files\Adobe\Help\pt_br\
                                      Property(C): ONLINE_HELP_PT_BR_RDR = C:\Program Files\Common Files\Adobe\Help\pt_br\reader\
                                      Property(C): ONLINE_HELP_PT_BR_RDRX = C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\
                                      Property(C): ONLINE_HELP_PT_BR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\using\
                                      Property(C): ONLINE_HELP_RO_RO = C:\Program Files\Common Files\Adobe\Help\ro_ro\
                                      Property(C): ONLINE_HELP_RO_RO_RDR = C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\
                                      Property(C): ONLINE_HELP_RO_RO_RDRX = C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\
                                      Property(C): ONLINE_HELP_RO_RO_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\using\
                                      Property(C): ONLINE_HELP_RU_RU = C:\Program Files\Common Files\Adobe\Help\ru_ru\
                                      Property(C): ONLINE_HELP_RU_RU_RDR = C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\
                                      Property(C): ONLINE_HELP_RU_RU_RDRX = C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\
                                      Property(C): ONLINE_HELP_RU_RU_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\using\
                                      Property(C): ONLINE_HELP_SK_SK = C:\Program Files\Common Files\Adobe\Help\sk_sk\
                                      Property(C): ONLINE_HELP_SK_SK_RDR = C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\
                                      Property(C): ONLINE_HELP_SK_SK_RDRX = C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\
                                      Property(C): ONLINE_HELP_SK_SK_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\using\
                                      Property(C): ONLINE_HELP_SL_SI = C:\Program Files\Common Files\Adobe\Help\sl_si\
                                      Property(C): ONLINE_HELP_SL_SI_RDR = C:\Program Files\Common Files\Adobe\Help\sl_si\reader\
                                      Property(C): ONLINE_HELP_SL_SI_RDRX = C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\
                                      Property(C): ONLINE_HELP_SL_SI_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\using\
                                      Property(C): ONLINE_HELP_SV_SE = C:\Program Files\Common Files\Adobe\Help\sv_se\
                                      Property(C): ONLINE_HELP_SV_SE_RDR = C:\Program Files\Common Files\Adobe\Help\sv_se\reader\
                                      Property(C): ONLINE_HELP_SV_SE_RDRX = C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\
                                      Property(C): ONLINE_HELP_SV_SE_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\using\
                                      Property(C): ONLINE_HELP_TR_TR = C:\Program Files\Common Files\Adobe\Help\tr_tr\
                                      Property(C): ONLINE_HELP_TR_TR_RDR = C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\
                                      Property(C): ONLINE_HELP_TR_TR_RDRX = C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\
                                      Property(C): ONLINE_HELP_TR_TR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\using\
                                      Property(C): ONLINE_HELP_UK_UA = C:\Program Files\Common Files\Adobe\Help\uk_ua\
                                      Property(C): ONLINE_HELP_UK_UA_RDR = C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\
                                      Property(C): ONLINE_HELP_UK_UA_RDRX = C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\
                                      Property(C): ONLINE_HELP_UK_UA_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\using\
                                      Property(C): ONLINE_HELP_ZH_CN = C:\Program Files\Common Files\Adobe\Help\zh_cn\
                                      Property(C): ONLINE_HELP_ZH_CN_RDR = C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\
                                      Property(C): ONLINE_HELP_ZH_CN_RDRX = C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\
                                      Property(C): ONLINE_HELP_ZH_CN_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\using\
                                      Property(C): ONLINE_HELP_ZH_TW = C:\Program Files\Common Files\Adobe\Help\zh_tw\
                                      Property(C): ONLINE_HELP_ZH_TW_RDR = C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\
                                      Property(C): ONLINE_HELP_ZH_TW_RDRX = C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\
                                      Property(C): ONLINE_HELP_ZH_TW_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\using\
                                      Property(C): PFM = C:\Program Files\Adobe\Reader 10.0\Resource\Font\PFM\
                                      Property(C): PLUGINS_3D = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\
                                      Property(C): PLUGINS_3D_PRC = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\prc\
                                      Property(C): PLUG_INS_ACROFORM = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\
                                      Property(C): PLUG_INS_ACROFORM_PMP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\PMP\
                                      Property(C): PersonalFolder = C:\Users\LocalAdmin\Documents\
                                      Property(C): PrimaryVolumePath = C:\
                                      Property(C): ProgramFiles64Folder = C:\
                                      Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                                      Property(C): SASIPREP = C:\Program Files\Adobe\Reader 10.0\Resource\SaslPrep\
                                      Property(C): SERVICES = C:\Program Files\Adobe\Reader 10.0\Reader\Services\
                                      Property(C): SERVICES_CA_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\Services\
                                      Property(C): SERVICES_CS_CZ = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\Services\
                                      Property(C): SERVICES_DA_DK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\Services\
                                      Property(C): SERVICES_DE_DE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\Services\
                                      Property(C): SERVICES_ES_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\Services\
                                      Property(C): SERVICES_EU_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\Services\
                                      Property(C): SERVICES_FI_FI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\Services\
                                      Property(C): SERVICES_FR_FR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\Services\
                                      Property(C): SERVICES_HR_HR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\Services\
                                      Property(C): SERVICES_HU_HU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\Services\
                                      Property(C): SERVICES_IT_IT = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\Services\
                                      Property(C): SERVICES_JA_JP = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\Services\
                                      Property(C): SERVICES_KO_KR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\Services\
                                      Property(C): SERVICES_NB_NO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\Services\
                                      Property(C): SERVICES_NL_NL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\Services\
                                      Property(C): SERVICES_PL_PL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\Services\
                                      Property(C): SERVICES_PT_BR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\Services\
                                      Property(C): SERVICES_RO_RO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\Services\
                                      Property(C): SERVICES_RU_RU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\Services\
                                      Property(C): SERVICES_SK_SK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\Services\
                                      Property(C): SERVICES_SL_SI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\Services\
                                      Property(C): SERVICES_SV_SE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\Services\
                                      Property(C): SERVICES_TR_TR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\Services\
                                      Property(C): SERVICES_UK_UA = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\Services\
                                      Property(C): SERVICES_ZH_CN = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\Services\
                                      Property(C): SERVICES_ZH_TW = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\Services\
                                      Property(C): SPPLUGINS = C:\Program Files\Adobe\Reader 10.0\Reader\SPPlugins\
                                      Property(C): STAMP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\
                                      Property(C): STAMP_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CAT\
                                      Property(C): STAMP_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHS\
                                      Property(C): STAMP_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHT\
                                      Property(C): STAMP_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CZE\
                                      Property(C): STAMP_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DAN\
                                      Property(C): STAMP_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DEU\
                                      Property(C): STAMP_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ENU\
                                      Property(C): STAMP_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ESP\
                                      Property(C): STAMP_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\EUQ\
                                      Property(C): STAMP_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\FRA\
                                      Property(C): STAMP_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HRV\
                                      Property(C): STAMP_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HUN\
                                      Property(C): STAMP_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ITA\
                                      Property(C): STAMP_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\JPN\
                                      Property(C): STAMP_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\KOR\
                                      Property(C): STAMP_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NLD\
                                      Property(C): STAMP_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NOR\
                                      Property(C): STAMP_POL = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\POL\
                                      Property(C): STAMP_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\PTB\
                                      Property(C): STAMP_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUM\
                                      Property(C): STAMP_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUS\
                                      Property(C): STAMP_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SKY\
                                      Property(C): STAMP_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SLV\
                                      Property(C): STAMP_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SUO\
                                      Property(C): STAMP_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SVE\
                                      Property(C): STAMP_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\TUR\
                                      Property(C): STAMP_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\UKR\
                                      Property(C): SendToFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\SendTo\
                                      Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                                      Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                                      Property(C): System16Folder = C:\Windows\system\
                                      Property(C): System64Folder = C:\
                                      Property(C): SystemFolder = C:\Windows\system32\
                                      Property(C): SourceDir = C:\Apps\
                                      Property(C): TRACKER = C:\Program Files\Adobe\Reader 10.0\Reader\Tracker\
                                      Property(C): TYPESPT = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\
                                      Property(C): TYPESPT_UNICODE = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\
                                      Property(C): TYPESPT_UNICODE_ICU = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\ICU\
                                      Property(C): TYPESPT_UNICODE_MAPPINGS = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\
                                      Property(C): TYPESPT_UNICODE_MAPPINGS_ADOBE = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Adobe\
                                      Property(C): TYPESPT_UNICODE_MAPPINGS_MAC = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Mac\
                                      Property(C): TYPESPT_UNICODE_MAPPINGS_WIN = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\win\
                                      Property(C): TempFolder = C:\Users\LOCALA~1\AppData\Local\Temp\
                                      Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                                      Property(C): USERPROFILE = C:\
                                      Property(C): VDKHOME = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\
                                      Property(C): VDKHOME_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\DEU\
                                      Property(C): VDKHOME_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ENU\
                                      Property(C): VDKHOME_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ESP\
                                      Property(C): VDKHOME_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\FRA\
                                      Property(C): VDKHOME_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ITA\
                                      Property(C): VDKHOME_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\NLD\
                                      Property(C): VDKHOME_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\SVE\
                                      Property(C): WindowsFolder = C:\Windows\
                                      Property(C): WindowsVolume = C:\
                                      Property(C): ISSETUPFILESCOMPLETED = Completed
                                      Property(C): SUPPORTDIR = C:\Users\LOCALA~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      Property(C): EXECUTEACTION = INSTALL
                                      Property(C): ACTION = INSTALL
                                      Property(C): UILevel = 5
                                      Property(C): VersionHandler = 5.00
                                      Property(C): WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\
                                      Property(C): SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\system32\
                                      Property(C): WinSxsDirectory.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\
                                      Property(C): payload_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_bcb86ed6ac711f 91\
                                      Property(C): payload.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\
                                      Property(C): WinSxsManifests.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\Manifests\
                                      Property(C): WinSxsPolicies.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\Policies\
                                      Property(C): policydir.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                                      Property(C): policydir_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                                      Property(C): SOURCEDIR = C:\Apps\
                                      Property(C): ALLUSERS = 1
                                      Property(C): Dummy_Microsoft_VC90_CRT_x86.0138F525_6C8A_333F_A105_14AE030B9A54 = 1
                                      Property(C): WinSxsDirectory.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_94 7B287C203A = C:\Windows\winsxs\
                                      Property(C): payload_ul.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287 C203A = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_60a 5df56e60dc5df\
                                      Property(C): WinSxsPolicies.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947 B287C203A = C:\Windows\winsxs\Policies\
                                      Property(C): policydir.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287C 203A = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f 75\
                                      Property(C): WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A = C:\Windows\
                                      Property(C): Dummy_policy_9_0_Microsoft_VC90_CRT_x86.52105B6B_A3EF_3A90_882A_947B287C203A = 1
                                      Property(C): OriginalDatabase = C:\Apps\AdbeRdr1010_en_US.msi
                                      Property(C): DATABASE = C:\Apps\AdbeRdr1010_en_US.msi
                                      Property(C): COMPANYNAME = Microsoft
                                      Property(C): USERNAME = Admin
                                      Property(C): MsiRunningElevated = 1
                                      Property(C): AdminUser = 1
                                      Property(C): RedirectedDllSupport = 2
                                      Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
                                      Property(C): MsiNetAssemblySupport = 4.0.30319.1
                                      Property(C): Date = 11/11/2011
                                      Property(C): Time = 13:54:03
                                      Property(C): TTCSupport = 1
                                      Property(C): ColorBits = 32
                                      Property(C): TextInternalLeading = 3
                                      Property(C): MIN_SYSTEM = C:\Windows\system32\Shdocvw.dll
                                      Property(C): AS_REPAIR_VERSION_LIST = A
                                      Property(C): IE_VERSION = 8.0.7601.17514
                                      Property(C): ProductCode = {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      Property(C): ApplicationUsers = AllUsers
                                      Property(C): AgreeToLicense = No
                                      Property(C): _IsMaintenance = Reinstall
                                      Property(C): SetupType = Typical
                                      Property(C): _IsSetupTypeMin = Typical
                                      Property(C): ARPCONTACT = Customer Support
                                      Property(C): TextHeight = 16
                                      Property(C): ARPHELPLINK = http://www.adobe.com/support/main.html
                                      Property(C): ARPREADME = C:\Program Files\Adobe\Reader 10.0\Readme.htm
                                      Property(C): ARPURLINFOABOUT = http://www.adobe.com
                                      Property(C): ARPURLUPDATEINFO = http://www.adobe.com/products/acrobat/readstep.html
                                      Property(C): DefaultUIFont = Tahoma8
                                      Property(C): ErrorDialog = SetupError
                                      Property(C): INSTALLLEVEL = 100
                                      Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
                                      Property(C): Manufacturer = Adobe Systems Incorporated
                                      Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                                      Property(C): ProductID = none
                                      Property(C): ProductLanguage = 1033
                                      Property(C): ProductName = Adobe Reader X (10.1.0)
                                      Property(C): ProductVersion = 10.1.0
                                      Property(C): ProgressType0 = install
                                      Property(C): ProgressType1 = Installing
                                      Property(C): ProgressType2 = installed
                                      Property(C): ProgressType3 = installs
                                      Property(C): RebootYesNo = Yes
                                      Property(C): ReinstallModeText = omus
                                      Property(C): TRACKINGKEY = Software\Adobe\Acrobat Reader\7.0
                                      Property(C): ARPPRODUCTICON = SC_Reader.ico
                                      Property(C): Cancel = 0
                                      Property(C): RadioGroup = 0
                                      Property(C): TypicalText = 0
                                      Property(C): ARPCOMMENTS =
                                      Property(C): ERROR_MIN_OVER_BIG = Setup has detected that you already have a more functional product installed.  Setup will now terminate.
                                      Property(C): SecureCustomProperties = DEFAULT_VERB;ACTIONPROPERTY;ELEMENTS;RDRMIN;RDRBIG;RDRBIG_8X;RDRBIG_9X;RDRBIG_10X;UT_FRB; UT_FRS;UT_AT;UT_AP1;UT_AP2;UT_AS1;UT_AS2;UT_A3D;UT_6X;UT_7X;UT_MM61;UT_MM62;UT_MM63;UT_EB6 1;UT_EB62;UT_EB63;AS_OPTIMIZE_ENABLED;ACROBAT_APP_PATH;AS_HKCR_EXE;PDFSHELL_LOCALSERVER_CO MMAND;PDF_DEFAULTICON;PDF_PREVIEW_HANDERLER_DLL;PDF_PREVIEW_HANDERLER_HELPDIR;DISABLE_PDFO WNERSHIP_RESTORE;PDF_INPROCSERVER_VIEWERPS;READER_PATH
                                      Property(C): BrandName = Adobe Reader X (10.1.0)
                                      Property(C): ISVROOT_PORT_NO = 0
                                      Property(C): BorderSide = 1
                                      Property(C): IsMinIE_Message = requires Internet Explorer 6.0 or greater.  Please visit www.microsoft.com to upgrade Internet Explorer.
                                      Property(C): ISLANGFLAG = ENU
                                      Property(C): FilesLabel = 0
                                      Property(C): DisallowRunFromSource = 1
                                      Property(C): AppsInUseSilentAbort = A process is running that cannot be shut down by Setup.  Please either close all applications and run Setup again, or restart your computer and run Setup again.
                                      Property(C): ENABLE_CACHE_FILES = YES
                                      Property(C): OLE_VERB_OPEN = &Open,0,2
                                      Property(C): REINSTALLMODE = omus
                                      Property(C): Elevated = 1
                                      Property(C): ENABLE_OPTIMIZATION = YES
                                      Property(C): ERROR_DEFRAG_MSG = Optimizing performance ...
                                      Property(C): ERROR_DEFRAG_ADTEMPLATE = Completed [1]% of process
                                      Property(C): ERROR_CANNOT_OPTIMIZE_DISK = NOTE: Installation was successful. However, because your hard drive is fragmented, this application may not be able to launch as quickly as possible. To optimize performance, please defragment your hard drive and then repair this application under Add or Remove Programs in the Control Panel.
                                      Property(C): EULA_ACCEPT = NO
                                      Property(C): DISABLE_BROWSER_INTEGRATION = NO
                                      Property(C): AcroIEHelper_Description = Adobe PDF Reader Link Helper
                                      Property(C): DEFAULT_VERB = Read
                                      Property(C): ADMIN_INSTALL = NO
                                      Property(C): AdminProperties = ADMIN_INSTALL
                                      Property(C): REMOVE_PREVIOUS = YES
                                      Property(C): SYNCHRONIZER = YES
                                      Property(C): BorderTop = 1
                                      Property(C): OpenWith = Open with Adobe Reader X
                                      Property(C): SetupCacheExport =
                                      Property(C): LC_UNSUPPORTED_OS = This application cannot be installed on this operating system. Setup will now terminate. Please refer to the minimum system requirements at http://www.adobe.com/go/reader_system_reqs.
                                      Property(C): ApplicationList = 0
                                      Property(C): DEFAULT_ATTACHMENT_WHITELIST = version:1|.ade:3|.adp:3|.app:3|.arc:3|.arj:3|.asp:3|.bas:3|.bat:3|.bz:3|.bz2:3|.cab:3|.ch m:3|.class:3|.cmd:3|.com:3|.command:3|.cpl:3|.crt:3|.csh:3|.desktop:3|.dll:3|.exe:3|.fxp:3 |.gz:3|.hex:3|.hlp:3|.hqx:3|.hta:3|.inf:3|.ini:3|.ins:3|.isp:3|.its:3|.job:3|.js:3|.jse:3| .ksh:3|.lnk:3|.lzh:3|.mad:3|.maf:3|.mag:3|.mam:3|.maq:3|.mar:3|.mas:3|.mat:3|.mau:3|.mav:3 |.maw:3|.mda:3|.mdb:3|.mde:3|.mdt:3|.mdw:3|.mdz:3|.msc:3|.msi:3|.msp:3|.mst:3|.ocx:3|.ops: 3|.pcd:3|.pi:3|.pif:3|.prf:3|.prg:3|.pst:3|.rar:3|.reg:3|.scf:3|.scr:3|.sct:3|.sea:3|.shb: 3|.shs:3|.sit:3|.tar:3|.taz:3|.tgz:3|.tmp:3|.url:3|.vb:3|.vbe:3|.vbs:3|.vsmacros:3|.vss:3| .vst:3|.vsw:3|.webloc:3|.ws:3|.wsc:3|.wsf:3|.wsh:3|.z:3|.zip:3|.zlo:3|.zoo:3|.pdf:2|.fdf:2 |.jar:3|.pkg:3|.tool:3|.term:3
                                      Property(C): EXEC_MENU_WHITELIST = Close|GeneralInfo|Quit|FirstPage|PrevPage|NextPage|LastPage|ActualSize|FitPage|FitWidth|F itHeight|SinglePage|OneColumn|TwoPages|TwoColumns|ZoomViewIn|ZoomViewOut|ShowHideBookmarks |ShowHideThumbnails|Print|GoToPage|ZoomTo|GeneralPrefs|SaveAs|FullScreenMode|OpenOrganizer |Scan|Web2PDF:OpnURL|AcroSendMail:SendMail|Spelling:Check Spelling|PageSetup|Find|FindSearch|GoBack|GoForward|FitVisible|ShowHideArticles|ShowHideF ileAttachment|ShowHideAnnotManager|ShowHideFields|ShowHideOptCont|ShowHideModelTree|ShowHi deSignatures|InsertPages|ExtractPages|ReplacePages|DeletePages|CropPages|RotatePages|AddFi leAttachment|FindCurrentBookmark|BookmarkShowLocation|GoBackDoc|GoForwardDoc|DocHelpUserGu ide|HelpReader|rolReadPage|HandMenuItem|ZoomDragMenuItem|CollectionPreview|CollectionHome| CollectionDetails|CollectionShowRoot|&Pages|Co&ntent|&Forms|Action &Wizard|Recognize &Text|P&rotection|&Sign && Certify|Doc&ument Processing|Print Pro&duction|Ja&vaScript|&Accessibility|Analy&ze|&Annotations|D&rawing Markups|Revie&w
                                      Property(C): PDF_Integration = 1
                                      Property(C): Browser_Integration = 2
                                      Property(C): ARPNOREPAIR = 1
                                      Property(C): ActionTextLabel = 0
                                      Property(C): CurrentPdfOwner = 0
                                      Property(C): ReadmeHtml = Readme.htm
                                      Property(C): OprimizeError2 = 0
                                      Property(C): ReaderProcessPopup = 0
                                      Property(C): BrandNameMajorVer = Adobe Reader X
                                      Property(C): DefragResetProgress = No
                                      Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                                      Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                                      Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                                      Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                                      Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                                      Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                                      Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                                      Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                                      Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                                      Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                                      Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                                      Property(C): IS_SQLSERVER_AUTHENTICATION = 0
                                      Property(C): IS_SQLSERVER_USERNAME = sa
                                      Property(C): _5789b66a5ab8e = {AC76BA80-0010-7AD7-0000-000000000000}
                                      Property(C): AttentionCloseReader = 0
                                      Property(C): RunTimeProperties = CACHE_DIR;ProductName;OriginalDatabase;REMOVE;WindowsFolder;SetupCacheExport;ALLUSERS;REI NSTALLMODE;PLUG_INS;DefragResetProgress;ALLUSERS_APPDATA_ADOBE;DEFAULT_VERB;IS_CURRENT_PDF OWNER;ACTIVE_X;Installed;READER;ProductCode
                                      Property(C): DV = 10.0
                                      Property(C): MSIRESTARTMANAGERCONTROL = Disable
                                      Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
                                      Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                                      Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
                                      Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                                      Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                                      Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                                      Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                                      Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                                      Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                                      Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                                      Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                                      Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                                      Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                                      Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                                      Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                                      Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                                      Property(C): RestartManagerOption = CloseRestart
                                      Property(C): AppsInUseUnknownAcrobatApps = Applications that are using Adobe Reader or Adobe Acrobat
                                      Property(C): EmbdUI = 1
                                      Property(C): ADOBE_LINK = http://www.adobe.com
                                      Property(C): _WebLinkChecked = 0
                                      Property(C): CurrentProduct = 0
                                      Property(C): DWUSLINK = CEFB870FBECC80BF79AC97C8298C978FD9DCB78FCEDC5098CE8B974F99DBF0F8CEEC50A809AC
                                      Property(C): PROCESSPATHWITHID = %s with process ID: %d
                                      Property(C): LANG_LIST = ENU,FRA,DEU,JPN,ITA,ESP,NLD,PTB,SVE,DAN,SUO,NOR,CHS,CHT,KOR,BGR,CZE,ETI,HRV,HUN,LTH,LVI,P OL,RUM,RUS,SKY,SLV,TUR,UKR,EUQ,CAT
                                      Property(C): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                                      Property(C): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                                      Property(C): UNKNOWNPROCESSWITHID = Unknown process with process ID: %d
                                      Property(C): Square = 1
                                      Property(C): ISReleaseFlags = ENU,READERBIG
                                      Property(C): DISPLAYPDFOWNERSHIPDLG = 1
                                      Property(C): CaptionHeight = 22
                                      Property(C): ScreenY = 1024
                                      Property(C): ScreenX = 1280
                                      Property(C): SystemLanguageID = 1033
                                      Property(C): Privileged = 1
                                      Property(C): ComputerName = CC-DESK-11
                                      Property(C): UserLanguageID = 1033
                                      Property(C): UserSID = S-1-5-21-187901175-1198847298-2277931997-1006
                                      Property(C): LogonUser = LocalAdmin
                                      Property(C): VirtualMemory = 6099
                                      Property(C): PhysicalMemory = 3548
                                      Property(C): Intel = 6
                                      Property(C): ShellAdvtSupport = 1
                                      Property(C): OLEAdvtSupport = 1
                                      Property(C): GPTSupport = 1
                                      Property(C): RecentFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Recent\
                                      Property(C): PrintHoodFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                                      Property(C): NetHoodFolder = C:\Users\LocalAdmin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                                      Property(C): RemoteAdminTS = 1
                                      Property(C): MsiNTProductType = 1
                                      Property(C): ServicePackLevelMinor = 0
                                      Property(C): ServicePackLevel = 1
                                      Property(C): WindowsBuild = 7601
                                      Property(C): UT_AS2 = {AC76BA86-1033-0000-BA7E-000000000003}
                                      Property(C): VersionMsi = 5.00
                                      Property(C): VersionDatabase = 300
                                      Property(C): PRODUCTLANGUAGE = 1033
                                      Property(C): CLIENTPROCESSID = 2880
                                      Property(C): CLIENTUILEVEL = 0
                                      Property(C): CURRENTDIRECTORY = C:\Apps
                                      Property(C): RestrictedUserControl = 1
                                      Property(C): ProductState = 1
                                      Property(C): PackageCode = {9587FED9-63E2-4D75-B4B2-1F9CDD57B3F5}
                                      Property(C): MsiLogFileLocation = C:\Users\LOCALA~1\AppData\Local\Temp\MSI185e1.LOG
                                      Property(C): CostingComplete = 1
                                      Property(C): SourcedirProduct = {AC76BA86-7AD7-1033-7B44-AA1000000001}
                                      Property(C): OutOfDiskSpace = 0
                                      Property(C): OutOfNoRbDiskSpace = 0
                                      Property(C): PrimaryVolumeSpaceAvailable = 0
                                      Property(C): PrimaryVolumeSpaceRequired = 0
                                      Property(C): PrimaryVolumeSpaceRemaining = 0
                                      === Logging stopped: 11/11/2011  13:54:03 ===
                                      MSI (c) (40:D0) [13:54:03:003]: Grabbed execution mutex.
                                      MSI (c) (40:D0) [13:54:03:003]: Cleaning up uninstalled install packages, if any exist
                                      MSI (c) (40:D0) [13:54:03:003]: MainEngineThread is returning 1603
                                      === Verbose logging stopped: 11/11/2011  13:54:03 ===
                                      • 17. Re: Adobe Reader requires Internet Explorer 6 or higher
                                        LeoAdobeX Adobe Employee
                                        As I mentioned, you need to change your system policy.
                                        Your log keeps showing:
                                        MSI (c) (40:D0) [13:53:17:762]: Machine policy value 'EnableUserControl' is 0
                                        MSI (c) (40:D0) [13:53:17:762]: PROPERTY CHANGE: Adding RestrictedUserControl property. Its value is '1'.
                                        Please read more in the links below:
                                        http://msdn.microsoft.com/en-us/library/windows/desktop/aa368359(v=vs.85).aspx
                                        http://msdn.microsoft.com/en-us/library/windows/desktop/aa371235(v=vs.85).aspx
                                        http://windows-installer-xml-wix-toolset.687559.n2.nabble.com/Property-Secure-when-to-use- td4982590.html
                                        Especially the first link, which describes 'EnableUserControl' property and its location in Registry.
                                        I think it might be set to 0 and you will need to set it to 1 or delete from Registry.
                                        Please delete the log.
                                        Good luck
                                        • 18. Re: Adobe Reader requires Internet Explorer 6 or higher
                                          bltechnical Level 1
                                          It wasn't in the registry. But given that the nature of the problem was user restriction, I decided to disable UAC and try the installer. It worked. I was working with version 10.1.0.534. It never prompted me for elevation when installing with UAC on and I guess since it couldn't get the correct privlidges, it wouldn't install.
