3 Replies Latest reply on Oct 18, 2011 1:35 AM by Sameer Bhatt
    Compile in it_IT
    RiccardoB. Level 1
      I'm trying to compile a AIR project using Flash Builder 4.5 and the compiler stops with an error:
      "Unable to open ...\Adobe\Adobe Flash Builder 4.5\eclipse\plugins\com.adobe.flexbuilder.project.nl1_4.5.1.313231\nl\it_IT\dcradSwcs\4.5 \locale"
      I see other locales like fr_FR or de_DE inside the /nl folder but not it_IT.
      Anyone knows how to add the italian language?
        • 1. Re: Compile in it_IT
          Sameer Bhatt Adobe Employee
          This issue is already discussed here http://forums.adobe.com/message/2315815
          Please have a look.
          • 2. Re: Compile in it_IT
            RiccardoB. Level 1
            Thanks for the link.
            Inside that post I've found a post of yours saying:
            "As Chris mentioned FB 4 supports 6 locales while SDK supports more locales.
            And the libraries (like fiber.swc, fds.swc and serializers.swc) which gets added when using the modeler plugin or the Data Centeric features are a part of FB 4 and hence they are supported for the 6 locales that FB 4 supports.
            That's why, you were getting the error of locale not found for these libraries.
            This error can be resolved by providing a locale swc for that language.
            Note that you need to create the locale swc (resource bundle swc) and provide it to FB 4 to get things working."
            But it doesn't explain "where" find the locale .swc to provide to FB and "how" to provide it to FB.
            Could you explain this a bit more?
            PS: the topic is FB 4 related, I'm on FB 4.5
            • 3. Re: Compile in it_IT
              Have you changed the locale in the project -> properties -> Flex Compiler -- compiler arguments to it_IT?
              You can try the eclipse.ini method to set the locale to en_US and see whether that works in your case. If it works, you don't need to do anything.
              If you want to create a locale swc for it_IT locale, you can follow these steps -
              Note that these steps are required for every swc - serializers_rb.swc, fds_rb.swc and fiber_rb.swc.  I'm writing the steps for serializers_rb.swc
              1. Goto ...\Adobe\Adobe Flash Builder 4.5\eclipse\plugins\com.adobe.flexbuilder.project.nl1_4.5.1.313231\nl \en_US\dcradSwcs\4.5\locale folder and extract serializers_rb.swc
              If you don't find en_US folder, then goto
              ...\Adobe\Adobe Flash Builder 4.5\eclipse\plugins\com.adobe.flexbuilder.project_4.5.1.313231\dcradSwcs\4.5\locale folder
              2. Create a new folder - bundle\it_IT  and from the extracted files, copy locale\en_US\serializer.properties file to this new folder.
              3. Open the file and translate the values to Italian language if you want.
              4. Execute this command -
              SDK_FOLDER\bin\compc.exe -output "serializers_rb.swc" -compiler.source-path "bundle\it_IT" -external-library-path SDK_FOLDER\frameworks\libs\player\PLAYER_VERSION\playerglobal.swc SDK_FOLDER\frameworks\libs\framework.swc SDK_FOLDER\frameworks\libs\rpc.swc -include-resource-bundles serializer -locale it_IT
              Here SDK_FOLDER is the folder where you've the 4.5 SDK
              And PLAYER_VERSION is folder name where playerglobal.swc is located. You can goto the SDK_FOLDER and see the PLAYER_VERSION folder - I think it'll be "10.2" for 4.5 SDK
              5. This will create the serializers resource bundle for it_IT locale.
              6. Copy the newly created serializers_rb.swc to the ...\Adobe\Adobe Flash Builder 4.5\eclipse\plugins\com.adobe.flexbuilder.project.nl1_4.5.1.313231\nl \it_IT\dcradSwcs\4.5\locale folder.
              7. Follow similar steps for fds_rb.swc and fiber_rb.swc. fiber_rb.swc is located in fiberSwcs folder.
              More on resource bundles here - http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7fcf.html
