16 Replies Latest reply on Oct 21, 2011 2:08 AM by Michelle Farley
    Importing IMX50  footage into Premiere Pro CS5.5
    Michelle Farley
      I've been trying to import a  Final Cut 6 project into Premiere Pro CS 5.5 without any success. The footage is originally  imx 50 codec.  I do an xml import and I get a error message saying it cant read the .mov codec. It can see the sequence but can't associate any of the footage to it.  I also tried transcoding the FCP sequnce to prores and then doing an xml export but with exactly the same result! Can anybody help?
        • 1. Re: Importing IMX50  footage into Premiere Pro CS5.5
          Colin Brougham Level 6
          Is Premiere Pro on a Mac or PC? Do you have QuickTime Player 7 installed? IMX50 won't work on a PC, at least in a QuickTime container, but ProRes should be fine, so long as you have QT Player installed.
          • 2. Re: Importing IMX50  footage into Premiere Pro CS5.5
            Michelle Farley Level 1
            Hi Colin,
            Premiere Pro is running on a PC. I know I have QT installed but not sure if it is v.7 or not will check.  Thanks for the quick response BTW
            • 3. Re: Importing IMX50  footage into Premiere Pro CS5.5
              Yep, with QT7 (just Player, you don't need Pro) the ProRes files should work just fine on a PC and, by proxy, in Premiere Pro. I'm guessing you must have an older version installed (or none at all), if they're being rejected.
              The IMX50 MOVs won't work since there is no decoder included in QT7; even on a Mac, I believe you'd need a Pro App, like FCP, installed. There are third-party codecs you can get, like QuickTime IMX for QuickTime and DirectShow|nanocosmos, but they're not cheap/free.
              The MOVs could be rewrapped as MXF files, which Premiere Pro would ingest natively, but then you'd have to go through a tedious relinking. Of course, you might be able to hack the FCP XML to make it work... but we'll cross that bridge when we come to it
              • 4. Re: Importing IMX50  footage into Premiere Pro CS5.5
                Hi Colin,
                I am running Quicktime player v 7.7 (the free version- do i need QT pro?). The project failed to import with an error message "unsupporte format or damaged file".
                Any suggestions?
                • 5. Re: Importing IMX50  footage into Premiere Pro CS5.5
                  QT Player (free) is, or should be, fine. Can you play the MOVs (the ProRes versions) in QuickTime Player? The IMX50 versions probably (99.99999% likelihood) will not play.
                  That said, are you talking about the XML import failing, or the media? Are you trying to import an FCP project file, or an exported FCP XML? You can't do the former; Premiere Pro doesn't support FCP project files. You need to export an FCP XML from FCP itself, which--in most cases--will import into Premiere Pro relatively smoothly. Check the help file for some more information on this: Importing XML project files from Final Cut Pro
                  I don't mean to assume anything, but we need to rule out all possibilities
                  • 6. Re: Importing IMX50  footage into Premiere Pro CS5.5
                    Hi Colin,
                    I will try to play the movs in QT and let you know how I get on.
                    Regarding your other notes:
                    I am importing an exported XML file rather than a project file.
                    The edit time line will come in will all the correct subclip names (ie file 01304.mov has been renamed CU Dave etc) But Prem Pro asks me to identify the media in the rushes folder, offering the filetype window as MPEG2. When I select the file it has for, it returns the error message "unsupported format or damaged file". Wierdly I can see the .mov files in the borwser but when I try to load them into the source window it returns the error message "Unsupported codec".
                    • 7. Re: Importing IMX50  footage into Premiere Pro CS5.5
                      Hi Colin,
                      Sothe results:
                      I tried playing each of the four shots in sequence through QT player. Two played fine. The other two returned an error message 2048: "couldn't open the file because that is not a file that quicktime understands." So they appear to be corrupted or incorrectly transcoded  by FCP.
                      I then tried importing the two files that would play in QT into Prem Pro (without the XML file of course) as though they were rushes. Voila they appeared in the project panel and I was able to add them to the time line and edit them perfectly.
                      No I just have to figure out waht happened with the transcoding. I will try two things.
                      1. I'll try transcoding IMX to AVI with the same sequence and see if that makes any difference.
                      2. I'll try importing another XML sequence from FCP in case the files on that project were corrupted.
                      Please let me know if there are any further steps you think might help.
                      • 8. Re: Importing IMX50  footage into Premiere Pro CS5.5
                        Hey Michelle,
                        Interesting--the plot thickens.
                        Please grab MediaInfo for your OS and use it to analyze one of the files that works, and one that doesn't. If you flip into Text view mode, you can copy and paste those results here. I want to have a look at the guts of the files...
                        • 9. Re: Importing IMX50  footage into Premiere Pro CS5.5
                          Great Colin,
                          Will do. It'll be Monday before I have those so have a great weekend and thanks for all the help this week.
                          • 10. Re: Importing IMX50  footage into Premiere Pro CS5.5
                            Hi Colin,
                            Here's the analyis you were looking for. I'll run those other test today and see what happens.
                            MEDIA INFO ANALYSIS begins:
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2317 master tk2.mov
                            Format                           : MPEG-4
                            Format profile                   : QuickTime
                            Codec ID                         : qt
                            File size                        : 389 MiB
                            Duration                         : 50s 960ms
                            Overall bit rate mode            : Variable
                            Overall bit rate                 : 64.0 Mbps
                            Encoded date                     : UTC 2011-10-12 11:17:39
                            Tagged date                      : UTC 2011-10-12 21:28:46
                            Writing library                  : Apple QuickTime
                            Original source medium           : 001
                            ©TSC                             : 25
                            ©TSZ                             : 1
                            Video
                            Format                           : ProRes
                            Format profile                   : High
                            Codec ID                         : apch
                            Bit rate mode                    : Variable
                            Bit rate                         : 62.5 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Display aspect ratio             : 5:4
                            Frame rate mode                  : Constant
                            Frame rate                       : 25.000 fps
                            Standard                         : PAL
                            Color space                      : YUV
                            Chroma subsampling               : 4:2:2
                            Scan type                        : Interlaced
                            Scan order                       : Top Field First
                            Bits/(Pixel*Frame)               : 6.026
                            Stream size                      : 380 MiB (98%)
                            Language                         : English
                            Tagged date                      : UTC 2011-10-12 11:18:10
                            Audio
                            Format                           : PCM
                            Format settings, Endianness      : Little
                            Format settings, Sign            : Signed
                            Codec ID                         : sowt
                            Bit rate mode                    : Constant
                            Bit rate                         : 1 536 Kbps
                            Channel(s)                       : 2 channels
                            Sampling rate                    : 48.0 KHz
                            Bit depth                        : 16 bits
                            Stream size                      : 9.33 MiB (2%)
                            Language                         : English
                            Menu
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:18:10
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2317 pu1 tk1.mov
                            File size                        : 27.6 MiB
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2319 master tk2
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 2.00 GiB
                            Duration                         : 7mn 13s
                            Overall bit rate                 : 39.6 Mbps
                            Encoded date                     : UTC 2011-10-12 11:23:04
                            Tagged date                      : UTC 2011-10-12 11:27:39
                            Original source medium           : 02319
                            Media/UUID                       : 2EA70F55-C743-4789-ADBF-AA22D4838336
                            Media/History/UUID               : 13421430-7675-40B8-B283-EBA8CAE840C2
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 7mn 13s
                            Bit rate                         : 62.4 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 6.014
                            Stream size                      : 3.15 GiB
                            Language                         : English
                            Source                           : SCENES 17-21\radharc 2319 master tk2-av.mov1
                            Source_Info                      : Missing
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 7mn 13s
                            Bit depth                        : 16 bits
                            Stream size                      : 79.4 MiB (4%)
                            Language                         : English
                            Menu
                            Duration                         : 7mn 13s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:27:39
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2319 pu1 tk1
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 1.32 GiB
                            Duration                         : 2mn 55s
                            Overall bit rate                 : 64.6 Mbps
                            Tagged date                      : UTC 2011-10-12 11:29:31
                            Media/UUID                       : C0F8E421-089F-4DF8-84FD-C3282A9D7550
                            Media/History/UUID               : 74A70F26-2E2B-42FF-8FAF-12AD13F96E6E
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 2mn 55s
                            Bit rate                         : 63.0 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 6.080
                            Stream size                      : 1.29 GiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 2mn 55s
                            Bit depth                        : 16 bits
                            Stream size                      : 32.1 MiB (2%)
                            Language                         : English
                            Menu
                            Duration                         : 2mn 55s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:29:31
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2320  pu1 tk1
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 1.64 GiB
                            Duration                         : 3mn 45s
                            Overall bit rate                 : 62.2 Mbps
                            Tagged date                      : UTC 2011-10-12 11:31:52
                            Original source medium           : 26
                            Media/UUID                       : 4E246055-0EF9-48C7-8A35-2364AD090B75
                            Media/History/UUID               : A8DBFD8F-7069-44AC-8378-033005B0A581
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 3mn 45s
                            Bit rate                         : 60.7 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 5.852
                            Stream size                      : 1.60 GiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 3mn 45s
                            Bit depth                        : 16 bits
                            Stream size                      : 41.4 MiB (2%)
                            Language                         : English
                            Menu
                            Duration                         : 3mn 45s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:31:52
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2320  pu1 tk2
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 186 MiB
                            Duration                         : 25s 120ms
                            Tagged date                      : UTC 2011-10-12 11:32:07
                            Media/UUID                       : CD6679BE-8909-4A1E-91D6-30ACB7D0787B
                            Media/History/UUID               : 2ED88EE8-565C-4AD9-8C49-22E7361338AB
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Bit rate                         : 60.6 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 5.848
                            Stream size                      : 182 MiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Bit depth                        : 16 bits
                            Stream size                      : 4.60 MiB (2%)
                            Language                         : English
                            Menu
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:32:07
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2321 pu1 tk1
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 1.02 GiB
                            Duration                         : 2mn 12s
                            Overall bit rate                 : 66.1 Mbps
                            Tagged date                      : UTC 2011-10-12 11:33:33
                            Media/UUID                       : 388B8B8B-1D1E-41DA-925A-EE667EA4BB62
                            Media/History/UUID               : 13755F55-1589-4033-8411-90D565DE4F17
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 2mn 12s
                            Bit rate                         : 64.5 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 6.225
                            Stream size                      : 1 021 MiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 2mn 12s
                            Bit depth                        : 16 bits
                            Stream size                      : 24.3 MiB (2%)
                            Language                         : English
                            Menu
                            Duration                         : 2mn 12s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:33:33
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2321 pu2 cam2 tk1
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 262 MiB
                            Duration                         : 35s 720ms
                            Overall bit rate                 : 61.6 Mbps
                            Tagged date                      : UTC 2011-10-12 11:33:55
                            Media/UUID                       : 0BA3D2D7-2464-4BB6-92BB-54560243ECB9
                            Media/History/UUID               : 7FD2FBCF-C17F-42AE-BF5D-90F1805E5DE6
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Bit rate                         : 60.0 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 5.790
                            Stream size                      : 256 MiB (97%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Bit depth                        : 16 bits
                            Stream size                      : 6.54 MiB (2%)
                            Language                         : English
                            Menu
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:33:55
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2321 pu2 tk1
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 1.27 GiB
                            Duration                         : 2mn 50s
                            Tagged date                      : UTC 2011-10-12 11:35:43
                            Media/UUID                       : C138D770-ED74-4FEA-865D-681D34ABAE7D
                            Media/History/UUID               : CA3A07FF-5DEE-4C3E-96B4-0BCD1EE5633E
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 2mn 50s
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 6.019
                            Stream size                      : 1.24 GiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 2mn 50s
                            Bit depth                        : 16 bits
                            Stream size                      : 31.1 MiB (2%)
                            Language                         : English
                            Menu
                            Duration                         : 2mn 50s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:35:43
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2321 tk3
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 526 MiB
                            Duration                         : 1mn 8s
                            Overall bit rate                 : 64.2 Mbps
                            Tagged date                      : UTC 2011-10-12 11:36:27
                            Media/UUID                       : 8FF7D341-111A-4535-AAB3-36F641389640
                            Media/History/UUID               : AE250985-6D04-4D27-B1C8-8D590F8AB65B
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 1mn 8s
                            Bit rate                         : 62.6 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 6.039
                            Stream size                      : 513 MiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 1mn 8s
                            Bit depth                        : 16 bits
                            Stream size                      : 12.6 MiB (2%)
                            Language                         : English
                            Menu
                            Duration                         : 1mn 8s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:36:27
                            General
                            Complete name                    : D:\Video Editing\Video Projects\RnR Rushes\RNR SERIES 16 EP 21 PRO RES\SCENES 17-21\radharc 2321 tk4
                            Format                           : MPEG-4
                            Codec ID                         : qt
                            File size                        : 1.39 GiB
                            Duration                         : 3mn 7s
                            Overall bit rate                 : 63.6 Mbps
                            Tagged date                      : UTC 2011-10-12 11:38:24
                            Media/UUID                       : 250A8C23-93E8-4FD5-B529-19095DA598DA
                            Media/History/UUID               : 06CF860D-F780-4876-A302-03AB6B1C851E
                            Video
                            Format                           : ProRes
                            Codec ID                         : apch
                            Duration                         : 3mn 7s
                            Bit rate                         : 62.0 Mbps
                            Width                            : 720 pixels
                            Height                           : 576 pixels
                            Standard                         : PAL
                            Color space                      : YUV
                            Bits/(Pixel*Frame)               : 5.981
                            Stream size                      : 1.35 GiB (98%)
                            Language                         : English
                            Audio
                            Format                           : PCM
                            Codec ID                         : sowt
                            Duration                         : 3mn 7s
                            Bit depth                        : 16 bits
                            Stream size                      : 34.3 MiB (2%)
                            Language                         : English
                            Menu
                            Duration                         : 3mn 7s
                            Language                         : English
                            Encoded date                     : UTC 2011-10-12 11:38:24
                            • 11. Re: Importing IMX50  footage into Premiere Pro CS5.5
                              Hi Colin,
                              Tried importing same sequence as avi - same result. Loading xml of the sequence caused prompts to link to media. When the correct media was identified, an error message displayed regarding the codec. Also tried importing another sequence in case the original files were corrupted but same result. My friend who exported the footage for me loaded a trial version of the mac version of Prem Pro and tried the the xml export for himself and the sequence imported perfectly. of course in his case its much eaier as the there is no need to copy the source media and therefore the linking stays intact So it seems the issue is two-fold: firstly moving media and xml betweeen two machines rather than two NLEs on the same computer and secondly trnasitioning  a project from Mac to PC. Any thoughts?
                              • 12. Re: Importing IMX50  footage into Premiere Pro CS5.5
                                Could you post/link to the XML you're using? Which of the MOVs worked and which didn't? They all appear to be the same flavor of ProRes, so if one works, they all should (unless the files themselves are broken somehow).
                                If you skip past one of the files during the relink that you know is not working, can you relink to one that does work? You can also skip the relinking completely when importing the XML, and then attempt a manual relink--right-click a file, and select Link Media, and then navigate to the file that is requested. That might tell us if it's just the broken files that are borking the whole process, or if the XML itself is wonky.
                                • 13. Re: Importing IMX50  footage into Premiere Pro CS5.5
                                  Will do. BTW: what we've been doing is transcoding the sequence to ProRes File-Export-XML then copying the XML and the source clips to a folder which is then copied to an external drive which I in turn copy to my media drive on my PC. In Prem Pro I then go File- Import, etc. Sound OK?
                                  • 14. Re: Importing IMX50  footage into Premiere Pro CS5.5
                                    Yep; there's really only one way to get the FCP XML into Pr, and that's to import it. Pr will do the translation when you import.
                                    • 15. Re: Importing IMX50  footage into Premiere Pro CS5.5
                                      Hi Colin,
                                      Sorry about the delay in getting back to you. So now here are the reults of my tests.
                                      I got two new sequences. The first - a straight cut sequence of about 2 mins -  imported the time line as previous attempts and again as before asked for each of the media clips. When I selected the correct file it returned "codec missing or unavailable". BTW the filetype it selects each time for import is MPEG2 even though I know the codec is Quicktime Prores. I've tried selecting clips with both options but same negative result. I followed your suggestion of trying to link them afterward but it made no difference.
                                      So without many expectation a tried the second clip - a series of five shots two of which had greenscreen elements. Did exactly the same again but when I selected the first shot requested: Bada Bing! It worked. Perfectly. I sat in stunned silence. It stared back. I blinked.
                                      I had all my media.  The cuts and layers had been preserved. I was able to use the keyer in Prem pro on the first shot nad just for the sheer hell of it , I exported the second clip to After Effects where i pulled the key there. Why did this work and all the others didnt? It was pro res in exactly the asme way as the others. What changed?
                                      Now, two interesting codas to that.
                                      1. When I exported the project to adobe media encoder the resulting video is black- no pictures. it's my first time using it however and I have probably forgot to select something but ...
                                      2. I created a new project and tried importing the screen footage again. This time it pulled in the sequnce with pictures/audio but the data in the time line. Which is to say that the sequence in this case is one continous grey line whereas on the first import you could see each of the shots and diffrent layers. What Sherlock Holmes called "a three pipe problem". On import it returned "Please check the FCP translation report for possible issues".
                                      Over to you...
                                      • 16. Re: Importing IMX50  footage into Premiere Pro CS5.5
                                        Hi again,
                                        Solved the media encoder "problem'. The problem was my stupidity. When I clicked to play the file, it selected Windows Media Player instead of Quicktime. When played in the correct application, it was seemless. Oh dear...
