2 Replies Latest reply on Jun 22, 2012 3:29 PM by MatteoLegittimo
    AIR - black screen when packaged
    daviiiiiiiiid
      When I run the application from Flash Develop everything is fine, both in Debug and Release.
      After the application is packaged and installed, I just get a black screen when run.
      However if I add a 'debug' file to applicationDirecty\META-INF\AIR\debug the application runs normally.
      What could be causing this? and how can it be solved?
        • 1. Re: AIR - black screen when packaged
          daviiiiiiiiid Level 1
          A debugging utility seemed to be causing the problem in the release build... removing calls to this solved the issue.
          /** Gets the name of the function which is calling */
          public function Log(prefix:String = "", suffix:String = "", params:* = null):void
          var error:Error = new Error();3
          var stackTrace:String = error.getStackTrace();     // entire stack trace
          var startIndex:int = stackTrace.indexOf("at ", stackTrace.indexOf("at ") + 1); //start of second line
          var endIndex:int = stackTrace.indexOf("()", startIndex);   // end of function name
          var lastLine:String = stackTrace.substring(startIndex + 3, endIndex);
          var functionSeperatorIndex:int = lastLine.indexOf('/');
          var ClassSeperatorIndex:int = lastLine.indexOf(':');
          var objectName:String = lastLine.substring(ClassSeperatorIndex+2, functionSeperatorIndex);
          var functionName:String = lastLine.substring(functionSeperatorIndex + 1, lastLine.length);
              trace
          (prefix +" " + "[" + objectName + "]" + " > " + functionName + " " + suffix);
          • 2. Re: AIR - black screen when packaged
            MatteoLegittimo
            im having this problem in a flex mobile project in the release build for ios!
            Im using Flash Builder 4.6
            How ca i solve it?
            Thanks a lot!
