1 Reply Latest reply on Oct 13, 2011 1:58 PM by bucpatr1
    problem updateDisplayList in itemRenderer
    dablamar6
      Hello!
      I directed at you, because I'm a little lost.
      (Sorry for my English)
      I'm relatively new to Flex and I'm finding some
      problems, which I try out.
      One of the biggest I have is the following:
      I made a custom chart, from a
      <mx:LineChart> with different rendereres. In the method
      updateDisplayList () for each one, drawing the elements that need.
      The graph contains data of a measure, for the last 3 months
      but only shows 20 days. You can scroll through the graph
      clicking an arrow I added outside of the graph.
      When I create the graph, passed several times by the updateDisplayList ();
      CustomAxisHorizontalRenderer (2 times)
      CustomAxisVerticalRenderer (2 times)
      CustomGridRenderer (1 time)
      CustomCircleItemRenderer (40 times for the 40 data
      I have three months)
      Not because he needs to spend 40 times by the
      CustomCircleItemRenderer.updateDisplayList if I only see 10 data, and if
      is because when I move one day backward, re-
      call again around the same time renderers.
      Not if you have something to do with cacheAsBitmap or invalidateDisplayList
      I am not using.
      All this is making the application (and I use this component
      enough) is slow, and I this desperate with Flex.
      Hopefully you can help me
