This content has been marked as final.
Show 2 replies
1. Re: CS3 AE: Problem with Template!
Rick Gerard Oct 13, 2011 5:23 PM (in response to pcford)The first thing to do is look at the Edit Comps Image 01 in the Project Panel. You'll see that it's used 2 times. Right click on the comp and it will reveal the two comps that it's used in.
Now check out layer 7 in the Comp1 precomp. That's where all of the animation takes place. There's the second copy of the pre-comp where image 1 is used. There's an error in the template. You could easily fix it by duplicating one of the Image precomps and dropping a new image in it, then replacing Image one in Image 01 Precomp Final 2.
2. Re: CS3 AE: Problem with Template!
pcford Oct 13, 2011 6:50 PM (in response to Rick Gerard)Thanks so much Rick...I will check it out when I get back to work tomorrow.
I love AE...maybe in another 20 years I will be good at it.
