4 Replies Latest reply on Oct 14, 2011 11:24 PM by dopamine100
    Cannot single video to normal time in same time space
    dopamine100
      Hi there,
      I am SO frusterated,
      I have a video.
      This video is available at:
      http://klikchik.com/seanpics/HDMI_20111013_0051.ts
      This video refuses to export at a normal speed, while maintaining the entire video.
      Either I lose half of the video at normal speed, or I have a near 2x speed video.
      I have tried close to, if not more than, 50 times to get this thing to render out at a normal speed, while maintining a proper length.
      I am new to premiere and after effects so have no clue what the fruit is wrong.
      Every time I try to spit this thing out at the correct speed, and without cutting it off, I destroy it.
      Please.  Ask me anything.  It is 4 AM and I am desperate.
      YAY!
        • 1. Re: Cannot single video to normal time in same time space
          Jon-M-Spear Level 4
          You need to give more details:
          1. Edited in AE or PP
          2. Format of source material
          3. Video preset used for timeline
          4. Frame rate
          5. Export size/format/frame rate
          • 2. Re: Cannot single video to normal time in same time space
            dopamine100 Level 1
            Edited in both After Effects and Premiere.
            I tried ditching everything.  I opened a new project in premiere.  Put this video in, and exported it.  The timing was appx half speed.
            1. Format of source material
            .ts which I am unfamilair with.  If I open the original .ts using Media Player Classic or any other video player, it plays as expected.  If I run it through Premiere in the very least, it renders out to play at appx half speed.
            1. Video preset used for timeline
            I do not know what that means, but it sounds perhaps like something I need to learn.
            1. Frame rate
            29.97 as input and as expected output
            1. Export size/format/frame rate
            Untitled-1.jpg\\\
            Thank you for taking some time to ask questions.
            Honestly, I am so exhausted right now I am probably not making any sense.
            *edit*
            Let me be clear.  I do not know what terms I should be using.  (Speed, time, duration, length)
            Let me provide a hypothetical example.
            I import a video which lasts X seconds.
            I export this video expecting it to last X seconds. (After Effects Or Premiere)
            I get a video that DOES last X seconds, but it is slowed down and I get only approxamatly half of the video.
            Again,
            Thank you.
            • 3. Re: Cannot single video to normal time in same time space
              Jim_Simon Level 8
              This is not standardized media form a supported camera.  Stick to using that inside of PP, and things should fare better for you.
              • 4. Re: Cannot single video to normal time in same time space
                dopamine100 Level 1
                I am stuck using captured video from a capture card hooked up to my iPhone so I can demo our application.
                After 2 days of trying everything I could think of, I finally came up with a crude work around.
                If I want a 60 second video at normal speed, record what I want for 60 second duration, and then allow the recording to continue to record garbage for another 60 seconds.  When I import it, I get approximatly what I want.
                I find it hard to believe that premiere cannot provide standardized media from non standard footage.
                Oh well!
                Thank you guys for your responses.
