2 Replies Latest reply on Oct 28, 2011 8:37 AM by oldMster
    Some random strings becoming 0 from http request
    Stephcook22
      Hi
      I have been getting some very weird things happening with a token system i am using and i think i have worked out why but dont know how to fix it.
      Basically I am using tokens to make sure someone is logged in to give them access to my app.
      I log them in via a http request to a php file which then returns some xml with a token. I acess it as follows:
      xml: <token>1e1242</token>
      private function loginResult(event:ResultEvent):void
           userToken = event.result.token;
      where userToken is a String.
      I get the token from the uniqid() php function
      Sometimes the token becomes infinity or 0 in my application when i can clearly see in my network monitor that it is sending a normal token.
      I have descovered one case when this always happens is when the token begins with '1e'.
      This reads infinity and when i convert to a string returns null.
      I think it is assuming it is a different type but i have no idea how to fix it.
      I have tried using   userToken = event.result.token as String;
      but it just becomes null.
      If anyone has any ideas how to solve this or a different method to use id really apreciate it!
      Thank you in advance
