2 Replies Latest reply on Aug 30, 2006 1:28 AM by popgodabubble
    3d Sky
    extol Level 1
      Hi. I have a 3d game that operates sort of like World Of Warcraft. You move your character and the camera follows. I already have mountainous terrain (a plain with a displace modifier that I made in 3ds Max), but the sky is just the background color of my 3d Member. Are there any tutorials to making a 3d sky that I can add to this (clouds, stars, etc)? Would I be able to add a skybox and keep my existing terrain? Thanks for any help on this!
        • 1. Re: 3d Sky
          Ex Malterra Level 1
          i'm not familiar with world of warcraft (yeah i've been under a rock), so i'm not sure what exactly you're going for. but i started a submarine thing awhile ago that needed a sky that moved with the sub. i used a cylinder primative with no end caps and a sky texture on it. this was fine for me since the camera stays parallel to the xz plane. if you need to allow for the camera looking up you could use a sphere primative with startAngle 0, endAngle 180, rotate z - 90, facing #back and radius whatever is large enough to get the look you want. you just need to script whatever sky you use to move but not rotate with whatever your point of reference is... in my case the sub. terrain won't be an issue, your sky will go right through it. you may want to have a light fog, may add a realistic look and mask the sky going through the terrain.
          • 2. Re: 3d Sky
            popgodabubble Level 1
            Hi there are 3 main methods as far as I can tell for doing skyboxes 2 of which use undocumented lingo.
            1. #XXX_nodepth()
            2. nextCamera()
            3. addCamera()
            A good basic tutorial for a type 1 skybox was written by barry swan a few years back and can be found here: www.inludo.com/tuts/skybox01.htm
            The addCamera system (3) is initialy detailed by at dirGames-L: nuttybar.drama.uga.edu/pipermail/dirgames-l/2005-February/033767.html
            One thing ben did forget is that you need to set your camera rects to be equal.
            If you would like to cater for 3D elments within the skybox itself using a nextCamera / add camera system is more suitable. With both you can your sky set in a seperate 3d member as a bonus, if needed. Also you can use these systems to float an additional layer for overlays etc
            sorry cant track down a link at moment for type 2 and too biz at moment to search my archives.
            hope this is of some help, pop
