2 Replies Latest reply on Oct 15, 2011 2:30 AM by Themida
    BorderContainer vs Canvas
    Themida
      I am in the process of converting a large project from an earlier SDK to 4.5.1. all has went well up until earlier this morning.
      Source and a few comments can be found here:
      http://www.mediawizard.tv/problem/index.html
      The code is straight forward - I'm giving a couple illustrations below to better explain the problem.
      Thanks for any insight on this.
      Regards,
      Shawn Tomovick
      Correct image insert with Canvas - inserted image is on top of the orange background (Canvas) and under both the left and right margin objects.
      Bad insert with BorderContainer - inserted image is on top of the orange background - inserted image is also under the left margin (using index 0 of the addElementAt method fixed this from being on top of the gray GUI area)
      however, the inserted image is above the right margin - this is the bad part and needs to be fixed.  Any correct way of doing this? and still keep the BorderContainer?
        • 1. Re: BorderContainer vs Canvas
          Shongrunden Adobe Employee
          mx:Canvas had clipping enabled by default, but spark containers do not.
          You will want to use a custom BorderContainer skin that sets clipAndEnableScrolling="true", for example:
          CustomBorderContainerSkin.as:
          package
              import spark.skins.spark.BorderContainerSkin;
              public class CustomBorderContainerSkin extends BorderContainerSkin
                  public function CustomBorderContainerSkin()
                      super();
                      clipAndEnableScrolling = true;
          Main.mxml:
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                 xmlns:s="library://ns.adobe.com/flex/spark">
              <s:BorderContainer width="50" height="50" backgroundColor="red">
                  <s:Button label="looooonngg" />
              </s:BorderContainer>
              <s:BorderContainer width="50" height="50" backgroundColor="red" skinClass="CustomBorderContainerSkin" y="60">
          </s:WindowedApplication>
          • 2. Re: BorderContainer vs Canvas
            Themida Level 1
            Thanks much!  Was hoping i'd not have to come up with a hack...
            appreciate the thorough answer.
