2 Replies Latest reply on Oct 19, 2011 10:49 AM by Don Kerr
    GridItemEditor DropDownList
    Don Kerr Level 3
      How do I use a dropdownlist with ArrayCollection dataProvider, inside a spark DataGrid GridItemEditor?  [The ComboBoxGridItemEditor doesn't work with ArrayCollections].
      my dropDownlist dataProvider, officesDP, contains ID, name for each office
      my grid's dataProvider contains officeID.
      I need the  dropdownlist's selectedItem (ID) to be set to the grid's data.officeID value.  When a new office is selected, it should update the grid's dataProvider to reflect the new officeID.
      I get the dropdown populating no problem using the code below.  However, I get a warning that binding to data.officeID won't be detected.  Why does data not exist?
      <s:GridColumn dataField="office" headerText="office">
        <s:itemEditor>
        <fx:Component>
        <s:GridItemEditor>
        <s:DropDownList  labelField="name" selectedItem="{data.officeID}"    dataProvider="{FlexGlobals.topLevelApplication.officesDP}">
        <fx:Script>
        <![CDATA[
        import mx.core.FlexGlobals;
        </fx:Script>
        </s:DropDownList>
        </s:GridItemEditor>
        </fx:Component>
        </s:itemEditor>
        </s:GridColumn>
      How do I set and change the selectedItem in the grid's dataProvider?
      Thanks!
      Don
        • 1. Re: GridItemEditor DropDownList
          Don Kerr Level 3
          for some reason GridItemEditor doesn't support binding to data.  Had to go with GridItemRenderer.
          I would have expected the selectedItem property of the dropdown or combobox to bind to the row's value by default. But, I couldn't get it to work.
          to solve this problem, I ended up using my BindableSparkComboBox component.
          Here is the working code.
          <s:GridColumn dataField="office"  rendererIsEditable="true" headerText="office">
            <s:itemRenderer>
            <fx:Component>
            <s:GridItemRenderer>
        <fx:Script>
        <![CDATA[
        import mx.events.FlexEvent;
        import spark.events.IndexChangeEvent;
        protected function pickme():void
        data.officeID = cb.selectedItem.ID;
        data.office = cb.selectedItem.name;
        </fx:Script>
        <local:BindableSparkComboBox xmlns:local="*"  change="pickme();"
        dataProvider="{FlexGlobals.topLevelApplication.officesDP}" id="cb" requireSelection="true" prompt="Office"
        selectedItem="{data.officeID}"  valueField="ID" labelFields="[name]"/>
            </s:GridItemRenderer>
            </fx:Component>
            </s:itemRenderer>
            </s:GridColumn>
