1 Reply Latest reply on Oct 19, 2011 7:52 AM by naval joshi
    problem in flex charts
    naval joshi
      this is my code..my application takes in a customer no input and shows a graph of arrival and departure of cutomers on some calcualtion done...i am unable to put the departure line...arrival line is coming up.  image at- http://asdfshare.com/tycoix6jm7iq/snap.bmp.html
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      public var ia:Array=new Array(0,125,250,375,500,625,750,825,1000);// inter arrival cumulative
                   public var st:Array=new Array(100,300,600,850,950,1000);//service cumulative
                   public var interarrival:Array=new Array();
                   public var service:Array=new Array();
                   public var arrival:Array= new Array();
                   public var departure:Array= new Array();
                   //public var display:ArrayCollection= new ArrayCollection([{no:1,Departure:10,arriva:20},{no:2,Departure:23,arriva:20},{no:3,Depart ure:34,arriva:43}]);
                    public var display:ArrayCollection= new ArrayCollection([{no:0,Departure:0,arriva:0}]);
                   public var i:Number;// for the outer loop of no of customers
                   public var n:Number;
                   public var t:Number;//for clock
                   public var iaval:Number;//interarrival lloop increment
                   public var stval:Number;//service loop increment
                   public var d:Number;
                   public var p:Number;
                   public var l:Number;
                   public var m:Number;
                   public var f:Number;
                   public var q:Number=1;//arrival cal
                   public var nn:int;//used in calculating arrival
                   public var arrive:int;
                   public var depart:int;
                   public var wait:Boolean;
                   public var idle:Boolean;
                   public var z:int;
                   public var xx:int=1;
                   public var v:int=1;
                   public var c:int;
              public function randomNumber(low:Number, high:Number):Number//random function
              return Math.floor(Math.random() * (1+high-low)) + low;
               public function calrand():void
                    n=new Number(inp.text);//taking user input for no of users
                    arrival[0]=0;//setting arrival initial
                    trace("service time,inter arrival, arrival time,departure time");
                  for( i=0;i<n;i++)
                    var ianum:Number=randomNumber(0,999);
                  var sernum:Number= randomNumber(0,999);
                //  trace(ianum,sernum);//tracing random numbers
                  //calculating the interarrival time
                  if(ianum>0&&ianum<125)
                  iaval=1;
                  else if(ianum>125&&ianum<250)
                  iaval=2;
                  else if(ianum>250&&ianum<375)
                  iaval=3;
                  else if(ianum>375&&ianum<500)
                  iaval=4;
                  else if(ianum>500&&ianum<625)
                  iaval=5;
                  else if(ianum>625&&ianum<750)
                  iaval=6;
                  else if(ianum>750&&ianum<825)
                  iaval=7;
                  else
                  iaval=8;
                  interarrival[d++]=iaval;
                  nn=nn+iaval;//for arrival
                  arrival[q++]=nn//putting in arrival array
                  //calculating the service time
                  if(sernum>0&&sernum<100)
                  stval=1;
                  else if(sernum>100&&sernum<300)
                  stval=2;
                  else if(sernum>300&&sernum<600)
                  stval=3;
                  else if(sernum>600&&sernum<850)
                  stval=4;
                  else if(sernum>850&&sernum<950)
                  stval=5;
                  else
                  stval=6;
                  service[p++]=stval;
                  departure[f++]=arrival[q-2]+stval;//departure time calculated
                  trace(service[p-1],interarrival[d-1],arrival[q-2],departure[f-1]);
                 // trace(stval);
                 // trace(iaval,stval);//tracing
               for(var ii:int=1;ii<=n;ii++)
                       display.addItemAt({no:ii,Departure:departure[ii],arriva:arrival[ii]},ii);
                       trace(display.getItemAt(ii));
               var ldep:int=departure[f-1];
               trace(ldep);//coorect last departure fr clock
                 arrive++;
             for(t=0;t<ldep;t++)//clock loop
                   trace("AT CLOCK =",t);
              if(t==arrival[z])
                  arrive=arrive+1;
                  z++;
                  trace("naval");
           /*   else if(arrival[x]<=departure[x-1])
                   {//departure will take time n a process arrives
                   wait=true;
                   trace("wait");
                   x++;
             else  if(arrival[v-1]>=departure[v])
                   {//arrival has nt come and the last process ends
                   idle=true;
                   trace("idle");
                   v++;
              else if(t==departure[c])
                   arrive=arrive-1;
                   depart=depart+1;
                   c++;
              else
             // naval();
              linechart.dataProvider=display;//imp line... providing data to chart
              trace("arrival=",arrive,"waiting=",wait,"idle=",idle,"departure=",depart);
              wait=false;
              idle=false;
               public function naval():void
                    trace("i am naval joshi");
               if(arrival[xx]<=departure[xx-1])
                   wait=true;
                   trace("wait");
                   xx++;
                   idle=true;
                   trace("idle");
                   v++;
                   arrive=arrive-1;
                   depart=depart+1;
                   c++;
                   else
                   trace("continue");
      </mx:Script>
      <mx:Label x="17" y="116" text="enter the no of users" width="160" height="38"/>
      <mx:Button x="98" y="203" label="Button" id="btn" click="calrand();"/>
      <mx:TextInput x="236" y="114" id="inp"/>
      <mx:Stroke id = "s1" color="blue" weight="2"/>
      <mx:Stroke id = "s2" color="green" weight="2"/>
      <mx:LineChart id="linechart" height="100%" width="682"
                  paddingLeft="5" paddingRight="5"
                  showDataTips="true"  x="483">
                  <mx:horizontalAxis>
                      <mx:CategoryAxis categoryField="no"/>
                  </mx:horizontalAxis>
                  <mx:series>
                   <mx:LineSeries yField="Departure" form="curve" displayName="Departure" lineStroke="{s2}"/>
                      <mx:LineSeries yField="arriva" form="curve" displayName="Arrival" lineStroke="{s1}"/>
                          </mx:series>
              </mx:LineChart>
              <mx:Legend dataProvider="{linechart}" x="380" y="10" width="95" height="65"/>
      </mx:WindowedApplication>
      the problem seems to be with this portion..the departure array dosent seems to populate the collection..but y??
