0 Replies Latest reply on Oct 17, 2011 6:27 AM by andres margalef
    Timeouts 30 secs on Air 4.5.1 and older versions
    andres margalef Level 1
      This example always fail at 30 seconds, and trace(event) is
      "[FaultEvent fault=[RPC Fault faultString="Error de solicitud http" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://localhost:8080/MyApplication/test" errorID=2032]. URL: http://localhost:8080/MyApplication/test"] messageId="6C1C6347-E307-7991-AAA4-120966B49909" type="fault" bubbles=false cancelable=true eventPhase=2]"
      Other examples using remoteObject with requestTimeout="99999" the trace(fault) is
      "[RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Failed"]"
      Other example using FileReference, the trace(fault) is
      "[IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2038: File I/O Error. URL: http://localhost:8080/MyApplication/test" errorID=2038]"
      Always at 30 seconds after, why?
      FLEX - AIR CODE
      <s:WindowedApplication
                xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:mx="library://ns.adobe.com/flex/mx"
                <fx:Declarations>
                          <s:HTTPService
                                    id="httpService" url="http://localhost:8080/MyApplication/test"
                                    fault="eventHandler(event)" result="eventHandler(event)" requestTimeout="99999"/>
                </fx:Declarations>
                <fx:Script>
                          <![CDATA[
                                    private var fecha:Date;
                                    private function testHttpService(event:MouseEvent):void {
                                              fecha = new Date();
                                              httpService.send();
                                    private function eventHandler(event:Event):void {
                                              var now:Date = new Date();
                                              trace("time elapsed:" + (now.getTime() - fecha.getTime()));
                                              trace(event);
                </fx:Script>
                <s:Button id="btnHttpService" label="httpServiceTest" click="testHttpService(event)" />
      </s:WindowedApplication>
      JAVA SERVLET:
      public class TestServlet extends HttpServlet {
                @Override
                protected void doGet(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
                          try {
                                    Thread.sleep(60000);
                          } catch (InterruptedException e) {
                                    e.printStackTrace();
