Expand my Community achievements bar.
SOLVED
\/process_data/taskContext/object/assignedUser/@initials
Avatar
Former Community Member
What's in the /process_data/taskContext/object/assignedUser/@initials ?
is it meant for the middle initial of user's name? or what?
how do I use AdminUI to populate that field?
1 Accepted Solution
Avatar
Correct answer by
Hi
The initials field is one of the values that can be set in your LDAP.
It can represent the middle name of the user.
You won't be able to use the adminui to populate that field.
You would have to create the user in LDAP and set the initials and then sync it.
Diana
View solution in original post
Avatar
Correct answer by
Hi
Diana
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
