12 Replies Latest reply on Oct 22, 2011 1:23 PM by Peter Spier
    InDesign CS5 suddenly slower...
    Russell Lord Level 1
      In Design CS5 has been running intermittently very slow recently. It will run normally for a while; then in the middle of a simple operation like copying a small piece of text, everything stalls and I get the pinwheel of death for an undetermined amount of time. Never long enought for me to bother force quitting, but happens frequently enough that it's really hindeirng my ability to get work done.
      Have done some heavy work on old, imported files from CS3 and CS4 files lately. Also  have recently installed trial versions of Final Cut Pro X and Adobe Production Premium CS5.5, but "completely" uninstalled those using the correct utilites and re-installed CS5 Design Premium afterwards. There have been some Apple Snow Leopard updates recently too. The kind of behavior I see on my activity monitor makes me think it's looking for something on a network somewhere. Either it takes a while and succeeds or it gives up and eventually moves on to the next thing. No other software being effected noticealbly except Illustrator CS5, but I use it less, so hard to name symptoms. All the CS5 apps used to run lickety split fast on this machine and just cleaned out a bunch of fonts. Things were better for a while, but now slower than before.
      I've looked all over and noone else seems to be having this problem. Thoughts anyone?
      Here's a random sample from the activity monitor:
      Sampling process 496 for 3 seconds with 1 millisecond of run time between samples
      Sampling completed, processing symbols...
      Analysis of sampling CS5ServiceManager (pid 496) every 1 millisecond
      Call graph:
          2467 Thread_8368   DispatchQueue_1: com.apple.main-thread  (serial)
            2467 start
              2467 main
                2467 adobe_csi::ServiceManager::Run()
                  2467 vcfoundation::system::IVCRunLoop::RunGUILoop()
                    2467 -[NSApplication run]
                      2467 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:]
                        2467 _DPSNextEvent
                          2467 BlockUntilNextEventMatchingListInMode
                            2467 ReceiveNextEventCommon
                              2467 RunCurrentEventLoopInMode
                                2467 CFRunLoopRunInMode
                                  2467 CFRunLoopRunSpecific
                                    2467 __CFRunLoopRun
                                      2467 mach_msg
                                        2467 mach_msg_trap
          2467 Thread_8370   DispatchQueue_2: com.apple.libdispatch-manager  (serial)
            2467 start_wqthread
              2467 _pthread_wqthread
                2467 _dispatch_worker_thread2
                  2467 _dispatch_queue_invoke
                    2467 _dispatch_mgr_invoke
                      2466 kevent
                      1 _dispatch_run_timers
                        1 _dispatch_wakeup
                          1 _dispatch_queue_push_list_slow
                            1 _dispatch_wakeup
                                1 _dispatch_wakeup
                                  1 _dispatch_queue_wakeup_global
                                    1 pthread_workqueue_additem_np
                                      1 pick_nextworkqueue_droplock
                                        1 __workq_kernreturn
          2467 Thread_8373
            2467 thread_start
              2467 _pthread_start
                2467 vcfoundation::thread::Thread::ThreadProc(void*)
                  2467 vcfoundation::thread::AbstractThread::Run()
                    2467 vcfoundation::ncomm::NCHost::Server::Run()
                      2467 vcfoundation::ncomm::NCHost::Server::Accept()
                        2467 vcfoundation::io::BSDPipeServer::Accept()
                          2467 vcfoundation::net::Bsd::Accept(int, sockaddr*, int*)
                            2467 accept$UNIX2003
          2467 Thread_8377
            2467 thread_start
              2467 _pthread_start
                    2467 vcfoundation::ncomm::NCHost::Worker::Run()
                      2467 vcfoundation::ncomm::NCHost::Worker::HandleRequest()
                        2467 vcfoundation::ncomm::NCHost::ExecuteRequest(vcfoundation::ncomm::INCHost::IRequest*)
                          2467 adobe_csi::AbstractRequest::Execute()
                            2467 adobe_csi::WaitForGlobalCSXSEventRequest::DoExecute()
                              2467 adobe_csi::CSXSEventQueueManager::PollEvents(vcfoundation::data::IVCString*, int)
                                2467 vcfoundation::thread::VCSynchronized::WaitFor(double)
                                  2467 vcfoundation::thread::Monitor_os::WaitFor(double)
                                    2467 vcfoundation::posix::PThread::cond_timedwait_relative(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, timespec const*)
                                      2467 pthread_cond_timedwait_relative_np
                                        2467 _pthread_cond_wait
                                          2467 semaphore_timedwait_signal_trap
          2467 Thread_8383
            2467 thread_start
              2467 _pthread_start
                        2467 vcfoundation::io::Serializer::Deserialize()
                          2467 vcfoundation::io::Serializer::InternalDeserialize()
                            2467 vcfoundation::io::Serializer::Read()
                              2467 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long)
                                2467 vcfoundation::io::BufferedReader::Read(void*, unsigned long)
                                  2467 vcfoundation::io::BufferedReader::InternalRead(char*, long)
                                    2467 vcfoundation::io::BufferedReader::Fill()
                                      2467 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long)
                                        2467 vcfoundation::net::Bsd::Recv(int, void*, int, int)
                                          2467 recv$UNIX2003
                                            2467 recvfrom$UNIX2003
          854 Thread_14185
            854 start_wqthread
              854 _pthread_wqthread
                854 __workq_kernreturn
      Total number in stack (recursive counted multiple, when >=5):
      Sort by top of stack, same collapsed (when >= 5):
              accept$UNIX2003        2467
              mach_msg_trap        2467
              recvfrom$UNIX2003        2467
              semaphore_timedwait_signal_trap        2467
              kevent        2466
              __workq_kernreturn        855
      Sample analysis of process 496 written to file /dev/stdout
        • 1. Re: InDesign CS5 suddenly slower...
          Here's a sample from when it happens:
          Call graph:
              2676 Thread_8368   DispatchQueue_1: com.apple.main-thread  (serial)
                2676 start
                  2676 main
                    2676 adobe_csi::ServiceManager::Run()
                      2676 vcfoundation::system::IVCRunLoop::RunGUILoop()
                        2676 -[NSApplication run]
                          2676 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:]
                            2676 _DPSNextEvent
                              2676 BlockUntilNextEventMatchingListInMode
                                2676 ReceiveNextEventCommon
                                  2676 RunCurrentEventLoopInMode
                                    2676 CFRunLoopRunInMode
                                      2676 CFRunLoopRunSpecific
                                        2676 __CFRunLoopRun
                                          2676 mach_msg
                                            2676 mach_msg_trap
              2676 Thread_8370   DispatchQueue_2: com.apple.libdispatch-manager  (serial)
                2676 start_wqthread
                  2676 _pthread_wqthread
                    2676 _dispatch_worker_thread2
                      2676 _dispatch_queue_invoke
                        2676 _dispatch_mgr_invoke
                          2676 kevent
              2676 Thread_8373
                2676 thread_start
                  2676 _pthread_start
                    2676 vcfoundation::thread::Thread::ThreadProc(void*)
                      2676 vcfoundation::thread::AbstractThread::Run()
                        2676 vcfoundation::ncomm::NCHost::Server::Run()
                          2676 vcfoundation::ncomm::NCHost::Server::Accept()
                            2676 vcfoundation::io::BSDPipeServer::Accept()
                              2676 vcfoundation::net::Bsd::Accept(int, sockaddr*, int*)
                                2676 accept$UNIX2003
              2676 Thread_8377
                2676 thread_start
                  2676 _pthread_start
                        2676 vcfoundation::ncomm::NCHost::Worker::Run()
                          2676 vcfoundation::ncomm::NCHost::Worker::HandleRequest()
                            2676 vcfoundation::ncomm::NCHost::ExecuteRequest(vcfoundation::ncomm::INCHost::IRequest*)
                              2676 adobe_csi::AbstractRequest::Execute()
                                2676 adobe_csi::WaitForGlobalCSXSEventRequest::DoExecute()
                                  2676 adobe_csi::CSXSEventQueueManager::PollEvents(vcfoundation::data::IVCString*, int)
                                    2676 vcfoundation::thread::VCSynchronized::WaitFor(double)
                                      2676 vcfoundation::thread::Monitor_os::WaitFor(double)
                                        2676 vcfoundation::posix::PThread::cond_timedwait_relative(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, timespec const*)
                                          2676 pthread_cond_timedwait_relative_np
                                            2676 _pthread_cond_wait
                                              2676 semaphore_timedwait_signal_trap
              2676 Thread_8383
                2676 thread_start
                  2676 _pthread_start
                            2676 vcfoundation::io::Serializer::Deserialize()
                              2676 vcfoundation::io::Serializer::InternalDeserialize()
                                2676 vcfoundation::io::Serializer::Read()
                                  2676 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long)
                                    2676 vcfoundation::io::BufferedReader::Read(void*, unsigned long)
                                      2676 vcfoundation::io::BufferedReader::InternalRead(char*, long)
                                        2676 vcfoundation::io::BufferedReader::Fill()
                                          2676 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long)
                                            2676 vcfoundation::net::Bsd::Recv(int, void*, int, int)
                                              2676 recv$UNIX2003
                                                2676 recvfrom$UNIX2003
                  accept$UNIX2003        2676
                  kevent        2676
                  mach_msg_trap        2676
                  recvfrom$UNIX2003        2676
                  semaphore_timedwait_signal_trap        2676
          Sample analysis of process 496 written to file /dev/stdoutScreen shot 2011-10-17 at 9.40.41 PM.png
          • 2. Re: InDesign CS5 suddenly slower...
            John Hawkinson Level 5
            OptionL:
            Please don't post sample process output here. For a process like InDesign, it's way too long for the forum. Upload to http://pastebin.com/ and post a link.
            In any case, your Sample Process is:
            And you need to have InDesign selected to run the sample for it. The CS5ServiceManager doesn't look lke it's stuck or using much CPU. In fact, it looks like its not doing anything, which is unsurprising. It just sits around waiting for something to call it.
            • 3. Re: InDesign CS5 suddenly slower...
              Thanks John,
              Sorry I had the wrong process selected. Here's a pastebin view of a legitimate InDesign sample...
              Thanks much for your fast reply! Appreciate the help very much...
              • 5. Re: InDesign CS5 suddenly slower...
                This is all in CoolType, ergo you have some sort of font problem. Try removing all of your fonts and see if it fixes it. If so, add them in by halves until you find the culprit.
                • 6. Re: InDesign CS5 suddenly slower...
                  Thanks John,
                  I'm not sure if this one-hundred percent fixed it, but uninstalled Linotype Font Explorer X, and things seem to be working a bit better. Appreciate your help...
                  Russell
                  • 7. Re: InDesign CS5 suddenly slower...
                    Glad that helped you out -- yes, 3rd party software can be an issue.
                    Please edit your post to remove your personal information (telephone number) -- that appears on the Internet for everyone to see.
                    • 8. Re: InDesign CS5 suddenly slower...
                      Please delete the autoquote and personal information when replying by email.
                      • 9. Re: InDesign CS5 suddenly slower...
                        Hi Peter,
                        Thought I did...
                        RL
                        • 10. Re: InDesign CS5 suddenly slower...
                          Youu got the phone number, I think, but the autoquote (and your email address) were still there, so I deleted them.
                          • 11. Re: InDesign CS5 suddenly slower...
                            @Adobe
                            I do think this also had something to do with the trail version of Adobe Prodcution Premium CS5.5 that I tried out. Things started acting weirdly after the newest version of Adobe Air installed. I uninstalled the trial software and had to spend a lot of time scrubbing my user prefs and application support directories to get rid of this. Decined when Adobe Story volunteered to update Air again, and feel things are less glitchy. Had to reinstall CS5 design premium more than once, but hopefully running right for a while now.
                            Overall, I'm unhappy with the CS5.5 release, as it has upgraded only certain components. Wish Adobe would have waited until a full new release was possible. Think this has complicated things unnecessarily.
                            Anyways, thanks to John for the help, and Abobe for still making the best software available and supporting creatives... also for having a very good tech support blog. Sorry for not knowing the correct etiquette.
                            RL
                            • 12. Re: InDesign CS5 suddenly slower...
                              OptionL wrote:
                              @Adobe
                              Nice sentiments. You know that unless you see an Adobe Employee badge, nobody you are interacting with here actually has any sort of official connection to Adobe, and it would only be accidental that a post here makes it to anyone at Adobe with the ability to make any sort of change based on what you've said, right?
