3 Replies Latest reply on Oct 22, 2011 9:44 AM by Shongrunden
    Event issues with Spark Rect
    jroy-54200
      I'm quite new to Flex and ActionScript, and I'm trying to do an application whose purpose is simply to be able to dynamically create rectangles (Spark Rects) on a panel: on mouse down the rectangle is created and updated on mouse move events (left button hold down), then the rectangle is achieved with mouse up. Here is the code:
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                               xmlns:mx="library://ns.adobe.com/flex/mx"
                                                               width="550" height="400"
                                                               creationComplete="this.onCreationComplete(event);">
                    <fx:Declarations>
               <!-- Place non-visual elements (e.g., services, value objects) here -->
                    </fx:Declarations>
                    <fx:Script>
               <![CDATA[
                                        import mx.collections.ArrayCollection;
                                        import mx.controls.Alert;
                                        import mx.events.FlexEvent;
                                        import mx.graphics.SolidColor;
                                        import spark.primitives.Graphic;
                                        import spark.primitives.Rect;
                                        public static const WIDTH:int = 480;
                                        public static const HEIGHT:int = 300;
                                        public static const BACKGROUND:int = 0xEFEFEF;
                                        public static const CURRENT_FILL:SolidColor = new SolidColor(0x00AA00, 0.75);
                                        protected var rectangles:ArrayCollection = null;
                                        protected var currentRect:Rect = null;
                                        protected var dragging:Boolean = false;
                                        protected function onCreationComplete(event:FlexEvent):void
                                                  this.rectangles = new ArrayCollection();
                                                  this.sprite.graphics.beginFill(BACKGROUND);
                                                  this.sprite.graphics.drawRect(0, 0, this.sprite.width, this.sprite.height);
                                                  this.sprite.graphics.endFill();
                                                  this.sprite.addEventListener(MouseEvent.MOUSE_DOWN, this.onMouseDown);
                                                  this.sprite.addEventListener(MouseEvent.MOUSE_UP, this.onMouseUp);
                                        protected function onMouseDown(event:MouseEvent):void
                                                  this.currentRect = new Rect();
                                                  this.currentRect.y = 10;
                                                  this.currentRect.height = this.sprite.height - (10 * 2);
                                                  this.currentRect.x = event.localX;
                                                  this.currentRect.width = 1;
                                                  this.panel.addElement(this.currentRect);
                                                  this.dragging = true;
                                                  this.sprite.addEventListener(MouseEvent.MOUSE_MOVE, this.onMouseMove);
                                        protected function onMouseUp(event:MouseEvent):void
                                                  if (this.dragging)
                                                            this.sprite.removeEventListener(MouseEvent.MOUSE_MOVE, this.onMouseMove);
                                  // this.currentRect.addEventListener(MouseEvent.RIGHT_CLICK, this.onMouseRightClick);
                                                            this.rectangles.addItem(this.currentRect);
                                                            this.dragging = false;
                                        protected function onMouseMove(event:MouseEvent):void
                                                  if (this.dragging)
                                                            this.currentRect.width = event.localX - this.currentRect.x;
                        protected function onMouseRightClick(event:MouseEvent):void
                              trace("Right click");
                    </fx:Script>
                    <s:Panel id="panel" x="10" y="10" title="Calendar">
                              <s:SpriteVisualElement id="sprite" width="{WIDTH}" height="{HEIGHT}" />
                    </s:Panel>
          </s:WindowedApplication>
      The sprite is used only for drawing some shapes in background, the created Rects are added to the Panel using addElement. All works fine but now I want to do some actions when the user right clicks on a rectangle. I tried to add an event listener on each created rectangle (see the comment in onMouseUp), but the corresponding method is never executed...
      What's the problem?
      Thanks...
