6 Replies Latest reply on Jan 11, 2016 3:16 PM by UXgun.com
    Remove purple grid without removing my grid?
    grimkarklud Level 1
      Hi
      I'm new in InDesign. How do I remove the purple grid that was already there when I made my document, WITHOUT removing ALL my grids?
      Regards
        • 1. Re: Remove purple grid without removing my grid?
          Eugene Tyson Adobe Community Professional & MVP
          View>Grids and Guides> Hide Guides
          Unfortunately the Purple one is linked to the blue ones (ruler guides) as well as other ones, you can't turn just one off, as far as I know.
          These are just Guides and don't output unless you tick the "Print Visible Guides and Baseline Grids" in the File>Print dialog box.
          • 2. Re: Remove purple grid without removing my grid?
            BobLevine MVP & Adobe Community Professional
            Are you referring to the margin guides? Either hide them change them.
            Here’s my standard newbie advice:
            1.       Sandee Cohen’s Visual Quick Start Guide. Best newbie book on the market: http://amzn.to/k2bkxg
            2.       Check out Lynda.com. This link will get you a free one week trial http://bit.ly/fcGpiI
            Bob
            • 3. Re: Remove purple grid without removing my grid?
              M Blackburn Level 3
              I'm assuming you are talking about the column guides (not margin guides, eh Bob).
              Adobe insists on having both margin and column guides in the document, it's been like that since PageMaker. I've never been able to find a practical use for the movable column guides that didn't seem a bit contrived, but if you add a couple of columns to your layout, you will likely see the logic. The magenta margins are page margins and as such constrain page elements, the purple column guides contrain the text.
              As Bob mentions you can change the colour of the column margins to be  magenta the same as the page margins, then you wouldn't notice them, but that would likely lead to more confusion. The best solution is to accept them for what they are, and ignore them if you don't find them useful.
              And by the way, it's not just the columns and margins that are linked in the display: all document guides, including bleed and slug, are similarly linked.
              • 4. Re: Remove purple grid without removing my grid?
                Purple, magenta? What’s a bit a red between friends? J
                Bob
                • 5. Re: Remove purple grid without removing my grid?
                  Mediatopia Level 1
                  I had exactly the same problem and even found this thread in my Google search.
                  I solved it myself by clicking on nearly every function.
                  To solve the purple lines from appearing all over your document, quite simply:-
                  1. Look top left hand corner where you can see the emblem of Indesign - id
                  2. On the right of the emblem you will see 5 icons, the first one is Br which is Bridge - then 4 icons with drop downs
                  3. Got to the second icon and click the drop down, untick Guides and then they will disappear.
                  Simple! Job done!
                  • 6. Re: Remove purple grid without removing my grid?
                    UXgun.com Level 1
                    You can get the page and column guides out of sight by changing the screen mode. View > Screen Mode > Preview (instead of Normal)
