6 Replies Latest reply on Oct 25, 2011 11:52 AM by pantelis224466
    Add next and previous button in xml as2 slideshow
    pantelis224466
      Hi there.
      I started a tutorial about creating a flash slideshow. This is the as2 code:
      import mx.transitions.Tween;
      import mx.transitions.easing.*;
      var myShowXML = new XML();
      myShowXML.ignoreWhite = true;
      myShowXML.load("slideshow.xml");
      myShowXML.onLoad = function() {
      _root.myWidth = myShowXML.firstChild.attributes.width;
      _root.myHeight = myShowXML.firstChild.attributes.height;
      _root.mySpeed = myShowXML.firstChild.attributes.speed;
      _root.myImages = myShowXML.firstChild.childNodes;
      _root.myImagesNo = myImages.length;
      total = myShowXML.childNodes.length;
      createContainer();
      callImages();
      function createContainer() {
      _root.createEmptyMovieClip("myContainer_mc",_root.getNextHighestDepth());
      myContainer_mc.lineTo(_root.myWidth,_root.myHeight);
      myContainer_mc._x = (Stage.width-myContainer_mc._width)/2;
      myContainer_mc._y = (Stage.height-myContainer_mc._height)/2;
      function callImages() {
      _root.myMCL = new MovieClipLoader();
      _root.myPreloader = new Object();
      _root.myMCL.addListener(_root.myPreloader);
      _root.myClips_array = [];
      _root.myPreloader.onLoadStart = function(target) {
      _root.createTextField("myText_txt",_root.getNextHighestDepth(),0,0,100,20);
      _root.myText_txt._x = (Stage.width-_root.myText_txt._width)/2;
      _root.myText_txt._y = (Stage.height-_root.myText_txt._height)/1.08;
      _root.myText_txt.autoSize = "center";
      _root.myPreloader.onLoadProgress = function(target){
      _root.myText_txt.text = "Loading.. "+_root.myClips_array.length+"/"+_root.myImagesNo+" Completed";
      _root.myPreloader.onLoadComplete = function(target) {
      _root.myClips_array.push(target);
      target._alpha=0;
      if (_root.myClips_array.length == _root.myImagesNo) {
      myText_txt._alpha=0;
      moveSlide();
      myShowInt = setInterval(moveSlide, (_root.mySpeed*1000)+1000);
      for (i=0; i<_root.myImagesNo; i++) {
      temp_url = _root.myImages[i].attributes.url;
      temp_mc = myContainer_mc.createEmptyMovieClip(i, myContainer_mc.getNextHighestDepth());
      _root.myMCL.loadClip(temp_url,temp_mc);
      function moveSlide() {
      current_mc = _root.myClips_array[_root.target_mc];
      new Tween(current_mc, "_alpha", Strong.easeOut, 100, 0, 1, true);
      _root.target_mc++;
      if (_root.target_mc>=_root.myImagesNo) {
      _root.target_mc = 0;
      next_mc = _root.myClips_array[_root.target_mc];
      new Tween(next_mc, "_alpha", Strong.easeOut, 0, 100, 1, true);
      //I have created 2 buttons - NEXT with instance name:next_btn and PREV
      //with instance name:prev_btn and these are the on(release) functions:
      previous_btn.onRelease = function() {
      prevImage();
      next_btn.onRelease = function() {
      nextImage();
      The images load from xml file and change through moveSlide function.
      And now i need to create those 2 new functions in order to give the user the opportunity to change the images by him/herself.
      I found somewhere a piece of code about this kind of functions:
      p = 0;
      function nextImage() {
          if (p<(total-1)) {
              p++;
              if (loaded == filesize) {
              picture._alpha = 0;
              picture.loadMovie(image[p], 1);
              picture_num();
      function prevImage() {
      if (p>0) {
      p--;
      picture._alpha = 0;
      picture_num();
      function picture_num() {
      current_pos = p+1;
      pos_txt.text = current_pos+" / "+total;
      The link i got these functions is this:
      http://kirupa.com/developer/mx2004/xml_flash_photogallery.htm
      How can i adjust these functions to my slideshow?
      P.S. Sorry, but i am not an as2 expert but any help is welcomed.
      Thanks in advance
        • 1. Re: Add next and previous button in xml as2 slideshow
          createContainer();
          callImages();
          _root.createEmptyMovieClip("myContainer_mc",_root.getNextHighestDepth( ));
          _root.createTextField("myText_txt",_root.getNextHighestDepth(),0,0,100 ,20);
          target._alpha=0;
          moveSlide();
          _root.target_mc++;
          _root.target_mc=Math.max(-1,_root.target_mc-2);
          clearInterval(myShowInt);
          moveSlide();
          moveSlide();
          • 2. Re: Add next and previous button in xml as2 slideshow
            pantelis224466 Level 1
            Hi there.
            Thank you very much for your reply. I used the code for the onRelase functions you suggested and i get this result:
            The gallery starts playing. If i push next button then i move to the next slide and if i wait a bti then the slide continuous (Ok)
            If i click previous button then nothing happens and the slide stops. If then, i click next i get a quick view of the next pic and then back to current pic. (Like the previous button has a kind of problem)
            Any ideas?
            P.S. Also, how can i make these buttons show at front of the image slideshow and not hiding behind the images?(I have placed the buttons at top layer but nothing happens.)
            • 3. Re: Add next and previous button in xml as2 slideshow
              my error.  use:
              var nextBool:Boolean = true;
              if(nextBool){
              _root.target_mc=(_root.target_mc+1)%_root.myImagesNo;
              } else {
              _root.target_mc=(_root.target_mc+_root.myImagesNo-1)%_root.myImagesNo;
              nextBool=false;
              moveSlide();
              nextBool=true;
              moveSlide();
              p.s.  if you're using movieclip buttons use swapDepths() to move them above your slide.  if they're simple buttons i think you can use swapDepths after defining it:
              Button.prototype.swapDepths=MovieClip.prototype.swapDepths;
              • 4. Re: Add next and previous button in xml as2 slideshow
                To be completely correct, i had to use this:
                before if(nextBool) to work.
                I really appreciate your help!
                As for swapDepths, my buttons are movieclips with instance names previous_btn and next_btn and if i use at the start of the code this:
                previous_btn.swapDepths(current_mc);
                next_btn.swapDepths(current_mc);
                it doesn't work
                • 5. Re: Add next and previous button in xml as2 slideshow
                  use:
                  previous_btn.swapDepths(_root.getNextHighestDepth());
                  next_btn.swapDepths(_root.getNextHighestDepth());
                  • 6. Re: Add next and previous button in xml as2 slideshow
                    Thank you very much for your help!
                    I apreciate it!
