1 Reply Latest reply on Oct 18, 2011 1:21 PM by John Hawkinson
    Placing textFrame below Previous named textFrame
    swingcarlos
      I have several textframes that need to be placed one on top of each other.
      How do I go about placing a new frame whose dimensions(WxH) are known to just below the bottom of the previous frame.
      I'm getting the previous frame correctly using:
      prevFrame = myDocument.textFrames.item("A");
      var bottom = prevFrame.visibleBounds[2];
      I'm just not convinced that getting bottom/y2 this way is correct.  The values that are coming
      out of this do not come close to the expected values.
      1) How do I get the bottom frame so I can plug it into the new frame creation which uses:
      bounds[0] = bottom + spacer;
      bounds[2] = bounds[0] + width;
      tmpFrame.geometricBounds = bounds;
      2) Would you use a different method of assigning width/height and then calling a 'move' function?
      Thanks for any help.
      Carlos
        • 1. Re: Placing textFrame below Previous named textFrame
          John Hawkinson Level 5
          Hi, Carlos.
          If the values from your visibleBounds array do not match what you see on the rulers, then something is wrong. Perhaps you have selected the wrong frame.
          I will say, I always find the bounds arrays horribly confusing and I use these helper functions:
          // fromBounds(gB) and toBounds(obj):
          // Helper functions for dealing with InDesign's geomericBounds and
          // visibleBounds properties. fromBounds() returns a JavaScript Object
          // with y1/x1/y2/x2 properties for easy referencing, and toBounds converts
          // it back to an array with the proper order. The intent here is to avoid
          // scripts having to keep track of the ordering of fields.
          // Also return width/height properties, though they ought to be
          // readonly (and aren't: xxx).
          // Example usage: {
          //   var s = app.selection[0];
          //   var sb = fromBounds(s.geometricBounds);
          //   $.writeln("(x1,y1) of selection are ("+sb.x1+','+sb.y1+")");
          //   sb.x2 = sb.x2+sb.width;       // double the width (in our copy)
          //   s.geometricBounds = toBounds(sb); // assign it for real
          function fromBounds(gB) {
          return { y1: gB[0], x1: gB[1], y2: gB[2], x2: gB[3],
          height: gB[2]-gB[0], width: gB[3]-gB[1]};
          function toBounds(obj) {
          return [ obj.y1, obj.x1, obj.y2, obj.x2 ];
          That way, I you can just write:
          var bottom = fromBounds(prevFrame.visibleBounds).y2;
          But I suspect you have the wrong frame. Does app.select(prevFrame); cause the correct frame to be selected?
