1 Reply Latest reply on Oct 28, 2011 2:23 PM by Adam-C
    How can i communicate xml with lingo?
    Igor R. Gomes
      I create a menu in flash that communicate with director, and use this code..
      on (release) {
                  //Goto Webpage Behavior
                getURL("lingo: set the Filename of member \"container\" to \"pg/54.pdf\" ");
                //End Behavior
      And this works fine...
      But bow, i create a better menu that uses xml, and i dont know how comunicate the menu with director.
      Anyone can help me?
      The code of my xml is simple..
      <FILE NAME="GO TO" LINK="my lingo code" />
        • 1. Re: How can i communicate xml with lingo?
          Adam-C Level 2
          Personally I wouldn't bother using XML to send such a small message to Director from Flash. I construct a string in Flash that can then be converted to to a propList in Director using a "do" command, and then handled by a case block. For example:
          IN FLASH:
          function sendAMessageToDirector() {
               var theMessage:Text = '[#buttonClicked: #' + this.buttonId + ']';
               getURL(theMessage);
          IN DIRECTOR BEHAVIOR SCRIPT ATTACHED TO THE FLASH SPRITE
          on getURL me, flashString
               flashData = void
               do "flashData =" && flashString
               case flashData.getPropAt(1) of
                    #buttonClicked:
                         put "the button clicked was " & flashData[1]
                    #anotherMessage:
                         --etc.
               end case
          end
          To do what you ask with XML:
          IN FLASH
          on (release) {
               getURL('<FILE NAME="GO TO" LINK="myLingoCode" />');
          IN DIRECTOR BEHAVIOUR ATTACHED TO FLASH SPRITE
          on getURL me, xmlString
               xmlParser = new xtra("xmlparser")
               xmlParser.parseString(xmlString)
               xmlPropList = xmlParser.makeList()
               case xmlPropList[1]["FILE"]["!ATTRIBUTES"]["NAME"] of
                    "GO TO":
                     do xmlPropList[1]["FILE"]["!ATTRIBUTES"]["LINK"]
               end case
          end
          To understand this script you may need to study the way the XML data structure converts into a propList data structure via Director's XML Parser. Also, pay close attention to the way I've used single and double quotes within Flash.
          BTW - just a suggestion - but I don't advise you use capitals for your XML tag names - much better to use lower case so you can use upper-case to denote the start of a word in the tag-name. For example "<myTag>" is much more readable than "<MYTAG>"
