3 Replies Latest reply on Oct 26, 2011 5:56 AM by gagouclub
    check if a component exists in document thanks to its ID
    gagouclub
      Hi !
      I m using a flex app which communicates with AS/400 server thanks to HTTP Service.
      I'm checking forms with an RPG program which sends me an xml result with the name of incorrect fields.
      I give you an exemple
      myResultXML:XML = result returned by RPG program;
      for i = 0; i < myResultXML.field.length; i++
           i do something with document[myResultXML.field[i]]
      The problem is : if the component with the ID myResultXML.field[i] doesnt exist in document, Flash player gives an error even if i try if(document[myResultXML.field[i]] != null)
      Is there a way to know if a component which ID is the string in myResultXML.field[i] exist in document ? Like an "exists()" method which returned true or false.
      Thanks.
