2 Replies Latest reply on Oct 20, 2011 9:29 AM by jchunick
    Declaring Global Variables
    richhemmings
      Hi People, I'm at the minute doing my Dissertation for University (Hand in December of this year), I'm creating a quiz in Director at the moment.
      I did something very simular to the ideas in my second year while at university, when I did this one of mt tutors told me to declair a global variable, but for the life of me I cannot remember how to do this.
      Here is the my code as it it at the moment:-
      on mouseUp
        global testScore
        if  field "test1" = 1/2 then
          put " " into field "test1"
          testScore = testScore + 1
          go to 350
        else
          go to 430
        end if
      end
      When I run the code I get the following message
      Script error: cast member not found
      "test1"
      Sorry to be a pain on my first post but can anyone help me?
      Thanks for any help in advance
      Rich
        • 1. Re: Declaring Global Variables
          Mister MUX Level 2
          It is telling you the problem. There is no field named test1 in your cast. Are you sure you have not typo'd the field name? Are you sure it it is a field and not a text member (they are not the same thing).
          • 2. Re: Declaring Global Variables
            jchunick
            I'm going to show the solution in both verbose and dot syntax (you are using the older verbose syntax):
            -- verbose syntax
            if field "test1" = "1/2" then
            -- dot syntax
            if field("test1").text = "1/2" then
            on mouseUp
              global testScore
                go to 350
              else
                go to 430
              end if
            end
            "test1"
            Rich
