Mike -
I will try to provide a more comprehensive answer.
So.. limiting access.. Usually it will depend on what web
server you're running on, and also to some extent what platform
you're developing on. The easiest way is to restrict file level
permissions to some directories. In Windows, this is done at the
file level, and in the web server you must tell the system to use
basic authentication and restrict anonymous access for those
directories you're protecting. In this case, it's best to create
users on the web server with very limited rights to the machine -
typically only read access to those directories you want them to be
viewing. Then in the web server management console, disable
anonymous access for those directories you want to restrict.
It's possible to do the same thing programatically. With ASP,
the effort is pretty great. You'll need a database with a list of
users and some way of assigning rights to them (either by defining
roles for which the users are members, or doing something more
tightly coupled to the content, such as defining what directories
or folders they'd have access to. These definitions would be in the
database. Something like a Users table and a Roles table or a Users
table and a Files/directories table.). Then, in each of the ASP
pages, the opening code on each page would need to check the users
cookie or session variable for a username, and then compare that to
the access rights that were defined in the database tables.
In new ASP.Net (1.1, 2.0), the process is much simpler. It
has "providers" that really make web authentication very simple -
nearly drag and drop with little to no special configuration of the
web server other than making sure it supports the .net. There are
some good links to the web on how to do this, and some free tools
for writing an asp.net application (
ASP Web Matrix, for
instance).
As for the search engine, it would depend on how you're
indexing content, and how the engine functions. Robohelp's search
will work, but controlling access based on users will demand more.
Many search engines will have an indexing service running as an
uber-user, so that it can see everything, but for searching, users
only get results for those items to which they have access.
